If I have the wheel off and the brake drum off, if I try to spin the wheel bearing hub by grabbing the lug studs----the question is how much resistance should there be? In my case, there is a little bit of resistance. If I were to try to spin it real fast with my hands, as soon as I let go, it would stop. Question is: should a good wheel bearing be able to spin on its own after I give it this push? Because mine do not. There is some slight resistance, does this indicate a bad wheel bearing.
I am asking because this area makes some sound but doesn't sound like humming or a bad wheel bearing, it more like the occasional dragging of various brake parts.
BTW, this is a torsion beam suspension and the this is FWD vehicle, so the wheel hub isn't attached to anything---just spins freely.
I don't what I did exactly to break things but in trying to fit in the new brake shoes, I had to compress and move the wheel cylinder piston around. I don't know what I did wrong but based on the reference pics I took, I did the job right but the brakes are now worse: initially spongy and less bite overall which suggest the front is doing all the braking.
I think the wheel cylinder has to be replaced and possibly the wheel bearings too.
