Oil change before car sitting 1 year?
by clarkflower - 08/24/19 12:47 PM
Havoline Smart Change on RB
by Mad_Hatter - 08/24/19 11:54 AM
TFL Truck testing Rotella Gas Truck.
by A_Harman - 08/24/19 11:34 AM
01 Nissan Sentra 2.0 AC issue
by Mark72 - 08/24/19 11:21 AM
I should have bought that Daewoo
by 5AcresAndAFool - 08/24/19 10:24 AM
Any one tried one of these ?
by WyrTwister - 08/24/19 10:02 AM
Correct Temps to Check ATF Fill
by Gebo - 08/24/19 09:48 AM
Wonder how much $ ice cream trucks make?
by Chris142 - 08/24/19 09:45 AM
Like tinkering on cars? Start young.
by BMWTurboDzl - 08/24/19 09:14 AM
Pumkin
by Eddie - 08/24/19 09:02 AM
Any GTO Owners On Here?
by oilpsi2high - 08/24/19 08:34 AM
Does Anyone Sim-Race?
by RayCJ - 08/24/19 06:56 AM
Oil recommendation for 2014 2.5l Suburu Forester
by tomartomau - 08/23/19 11:32 PM
Castrol 5W50
by Snagglefoot - 08/23/19 11:29 PM
Camry Broke Down
by Nick1994 - 08/23/19 10:51 PM
Pumpkin Beer
by Capt - 08/23/19 09:26 PM
Possible bad Iridium plug
by Eric Smith - 08/23/19 08:57 PM
Boogyman, GeoffPD, CabanaBanana, tblack, goldenjava
69048 Registered Users
96 registered members (anl0109, AZjeff, 2015_PSD, ArrestMeRedZ, 16 invisible), 2,468 guests, and 24 spiders.
Topics293,730
Posts5,045,783
Members69,048
Most Online3,532
Jul 30th, 2019
Page 2 of 3 1 2 3
Re: need brake job but ... [Re: Bluebonnet] #5086307 04/25/19 06:56 PM
E
eljefino Offline
E
In addition to all the other anti-Midas drama, they *have to* buy all their brake supplies through corporate, giving you poor quality at high prices.
If you ever rode a bicycle and maintained its brakes, jumping to a car is very little drama. As said in the thread, stuff's easy.
Re: need brake job but ... [Re: Bluebonnet] #5086321 04/25/19 07:05 PM
slacktide_bitog Online Content
Online Content
Your regular mechanic can do them with no problem smile
Re: need brake job but ... [Re: Bluebonnet] #5086332 04/25/19 07:15 PM
DuckRyder Offline
Midas is close to the last place I’d let touch my brakes...
Robert
  • 2019 Volkswagen Jetta R-Line
  • 2005 Honda Civic Sedan
  • 1972 F100 Ranger XLT (390/C6/9” 3.50 Truetrac)
  • 2002 Ford Ranger XLT 4D Supercab 3.0L
Re: need brake job but ... [Re: Bluebonnet] #5086392 04/25/19 08:07 PM
M
mk378 Offline
M
On most cars, swapping out brake pads and rotors is only slightly more complicated than an oil change. It is something that a shop would have one of their less talented and/or lower paid mechanics do.
There are exceptions though.
Re: need brake job but ... [Re: Bluebonnet] #5086406 04/25/19 08:17 PM
H
hallstevenson Offline
H
Originally Posted by Bluebonnet
Brakes are a speciality repair....
No they're not. After oil changes, they're probably the 2nd most common auto repair/service work.
Re: need brake job but ... [Re: Bluebonnet] #5086521 04/25/19 09:58 PM
Donald Offline
Around here you can go to Mavis and get a brake job for $69.95 per axle. But they will try and up sell you rotors and other extras. They will be using cheap pads that may not even be as good as the original.
My mechanic uses the Akebono pads I bring in (Wagner rotors) and spends some time cleaning all the rust off the caliper brackets so the pads will move properly. Unsure if Mavis or Midas would really do a good cleaning job to get the rust off. In other areas rust may not be an issue.
In most vehicles the front brakes wear out before the rear. In my Subaru Crosstrek the rear brake pads are tiny and wore out before the front pads. Not sure if this is a trend or not with tiny rear pads.
2015 Ford F250 w/Powerstroke
Re: need brake job but ... [Re: Donald] #5086600 04/25/19 11:41 PM
Skippy722 Offline
I know on my 300 it can alter the front/rear brake bias on the fly to prevent the rear end from sliding around. It also uses the brakes to act like a limited slip differential. The Durango and Grand Cherokee use the same thing. Not sure how Subaru does their torque vectoring though.
2016 Chrysler 300S v6
2018 Dodge Grand Caravan GT
Slight Mopar obsession
Re: need brake job but ... [Re: Donald] #5086623 04/26/19 12:32 AM
G
geeman789 Offline
G
My Subaru Impreza was the same. Rear brakes lasted 50 000 miles, fronts went 70 000 miles. Maybe an all wheel drive thing, more rear brake bias ... traction control ... stability assist ... who knows ?
2011 SUBARU Impreza 5-door manual / 2016 HONDA Pilot / 2011 MAZDA 2 auto
Re: need brake job but ... [Re: Bluebonnet] #5086732 04/26/19 06:59 AM
supton Offline
Going to pile on and agree that this is "easy" and simple work. And that I'd skip Midas.
No reason that front and back have to be done at the same time. If anything it's rare for both to go out at the same time--fronts usually do more work, and usually wear out at twice the rate as the rears. Usually, although there are exceptions (my Jetta wore rear brakes at twice the speed of the fronts).
Now doing left side and right side at the same time is what is recommended--do the pair of brakes on the same axle.
2011 Toyota Camry, base, 2.5L/6MT, 187k, hers
2010 Toyota Tundra DC, 4.6L/6AT, 153k, ours
1999 Toyota Camry LE, 2.2L/4AT, 209k, his
Re: need brake job but ... [Re: mk378] #5087116 04/26/19 12:26 PM
N
nthach Offline
N
From what I hear, brakes on a Tesla are a less complicated affair than a Toyota/Lexus hybrid or a Sensotronic-equipped Mercedes.
Re: need brake job but ... [Re: Donald] #5087120 04/26/19 12:29 PM
N
nthach Offline
N
Seems to a common issue with some cars - the brake force distribution algorithm is using the ABS modulator to adjust brake bias as a simulated proportioning valve. Hondas and Subarus tend to eat their rear brakes early.
Re: need brake job but ... [Re: Bluebonnet] #5087938 04/27/19 07:23 AM
H
HangFire Offline
H
If your regular mechanic is both trusted and brilliant you should be throwing as much work as you can at him to keep him in business, and keep him familiar with your cars, so he can keep them in good shape and keep you informed about them. I do all of my own brake work, but when having some differential work on my pickup (now that's specialty work!), my mechanic said my rear shoes needed replacement, and he already had the wheels off to pull the axles, so yeah I had him do the brakes. Then we got into a discussion about the quality of rotors, he had a short list in his head about which rotors he used for which types of vehicles, he was very particular about his choices! That kind of knowledge doesn't accumulate unless the same cars and customers come back to the same mechanic repeatedly. In chain shops like Midas, the likelihood you'll get the same guy doing your brakes 3 years from now is quite low.
As others here have stated, brakes are not specialty work. It is easy bread and butter work for any shop. However some shops do them much better than others. In particular, better shops use proper lubrication, using quality components and checking runout against spec. Proper lubrication is a big deal. The factory service manuals on my cars spec different kinds of lube for the pins versus the pad backs and ears. Some shops use the same lube on both. Some pad-slap and put on no new lube. Most shops (from my personal experience) check only pin lubrication, and never lube the pad back or ears.
On my Honda you can pad-slap by only removing one of the two caliper pins and swinging the caliper up out of the way. On those brakes some mechanics never check the lube on the other pin, too easy to make more money on saving a few minutes and squeezing in another job, since they are paid book time no matter what the actual time on the job is.
Likewise runout is a big deal. Fresh components will work OK for 10K miles since the caliper floats, but the smallest bit of eccentricity on the mounted rotor (grit or rust on the hub for example) and the high spots will build up pad particles, have increased friction over the rest of the rotor surface, and you get the wubba-wubba feeling of brake shudder. Then you take it back and they blame you for warping the rotors by running them hot through a puddle.
I'm not going to beat down on Midas, how good they are varies. It depends on the local shop, and as you found out, who you get that day. We had one locally but it went out of business some years ago. Meanwhile several local guys have been expanding. That tells you something about that particular Midas shop. On the other hand, I have friends who use chain shops with good luck, they know the owner and have a relationship, and staff turnover is low at the best-run chain shops.
Various musings: http://hangfire.net
Re: need brake job but ... [Re: Bluebonnet] #5087966 04/27/19 08:02 AM
cronk Offline
I avoid using the chain shops. Might be ok for muffler work, but usually overpriced for all other work.
A friend once took his Grand Prix to Monro for a brake job and they quoted him over $1400. Told him the car needed all 4 calipers and pads and rotors all around. No way all 4 calipers were bad, I could see the rears, as those cars were known for that.
A mechanic that takes pride in his work will take the time to clean and lube caliper slide pins,
And remove rust from the bracket where the pads slide. Free moving caliper and pads will make for a long lasting brake job.
2008 Ford F350
2003 Chevy Cavalier
2011 Nissan Quest
1986 Pontiac Trans Am
1940 Ford 9N Tractor
Amsoil lubes and filters!
Re: need brake job but ... [Re: Bluebonnet] #5088049 04/27/19 09:21 AM
stanlee Offline
Jesus [censored], a brake job is the most basic nut and bolt job on a car. 9.5 times out of 10 its literally unfastening 4 bolts (2 caliper bolts to remove pads and 2 caliper brackets bolts to remove rotors if you need rotors), cleaning up a few surfaces with brake clean/brush, and making sure caliper pins are lubed. There is absolutely NOTHING specialty about a brake job. Even bleeding/fluid/caliper replacement is the most basic of concepts(open bleeder valve/pour in fluid until old fluid/air comes out/close valve). Your getting hosed by Midas. If you only need pads they are just using cheap $12 wholesale pads from their local AutoZone, Napa, Carquest (stick around long enough you'll see the deliveries), about 15 minutes of labor with power tools and charging you $150 or more. Don't know if turning rotors is still a thing since basic Chinese rotors they use cost nothing these days but I can only imagine what they charge for a brake and rotor job. Lifetime pad guarantee means nothing because a) last time I went to Midas at about 20 when I just figured I'd learn myself they still charged labor which was 4x what the pads they used cost and b) at $150/axle they could replace your pads multiple times without charging labor and still make a profit. Lastly do you think you are getting top tier mechanics at Midas?
Re: need brake job but ... [Re: Bluebonnet] #5088275 04/27/19 01:44 PM
M
mightymousetech Offline
M
You would trust Midas to do your brakes over your normal mechanic? Well now I have heard everything.
Mighty Mouse Tech
BMW Diagnostic and Alignment Tech
2013 BMW 135i M Sport Edition Motul 0W40, MTL/MT-LV
2010 BMW 328i X-Drive, Castrol 0W40, MT-LV
Page 2 of 3 1 2 3
