Oil recommendation for 2014 2.5l Suburu Forester
by tomartomau - 08/23/19 11:32 PM
Castrol 5W50
by Snagglefoot - 08/23/19 11:29 PM
Camry Broke Down
by Nick1994 - 08/23/19 10:51 PM
Pumpkin Beer
by Capt - 08/23/19 09:26 PM
Possible bad Iridium plug
by Eric Smith - 08/23/19 08:57 PM
Is the 5.7gm engine still made brand new?
by motor_oil_madman - 08/23/19 08:19 PM
Motomaster OEPlus MOPH/MOCH Filters
by gamefoo21 - 08/23/19 07:29 PM
Man's best friend!
by Mad_Hatter - 08/23/19 06:53 PM
2007 Ford Fusion Cam Pics
by tig1 - 08/23/19 05:31 PM
Cloning a Lexus key
by Nayov - 08/23/19 04:23 PM
2011 GMC Acadia Shock/Strut Replacement
by panthermike - 08/23/19 03:49 PM
Confusion on oil to use on BMW 328i 2010
by goldenjava - 08/23/19 03:21 PM
ProSelect 27356 cut open
by Sayjac - 08/23/19 03:04 PM
Electrolux - Dryer reliability warning.
by pezzy669 - 08/23/19 02:37 PM
Microfiber Towels for different applications?
by Quattro Pete - 08/23/19 01:53 PM
Coated vs. painted rotors
by atikovi - 08/23/19 01:13 PM
New spark plugs, occasional misfire
by avacado11 - 08/23/19 12:34 PM
Boogyman, GeoffPD, CabanaBanana, tblack, goldenjava
69048 Registered Users
24 registered members (Char Baby, bmod305, billt460, avi1777, Convert, ctechbob, 4 invisible), 526 guests, and 18 spiders.
Topics293,713
Posts5,045,462
Members69,048
Most Online3,532
Jul 30th, 2019
HONDA AT FINALLY LIKE NEW #5087965 04/27/19 07:58 AM
David1 Offline OP
Ive have had this honda since it had 170K miles on it... It has over 250K miles on it now i think near 8 years... When I bought it years ago i figured the transmission had some wear or perhaps it was on borrowed time b/c if shifted funny from 1st gear to 2nd gear.. Once in a while it would sorta bang into 2nd gear..If I drove it very easy and took off from a stop very slow it would sorta float into 2nd gear and wouldnt do that horrible bang. Now many things improved it like new trans mounts / engine mounts ECT.. Also LubeGaurd Shudder fix. That seemed to help it also.. Finally i started to change the Dual Liner solenoid and that really didn't help but I had a code pop up for the dual liner solenoid so I changed it.. ** DENSO ** The D light was blinking and as soon as I changed the dual liner selenoid the flashing Green D light stopped... I even changed the Torque Converter lock out solenoid.
Well I finally figured it out ** Becasue I was out of things to change **... Honda has 2nd gear and 3 gear Transmission Pressure Switches part # 28600-P7Z-003 and or 28600-P7Z-013 .. So I got real Honda ones from work via World Pac and the trans takes 2 but I only changed the 2nd gear switch and as soon as I drove the car it was like a new transmission.. I was shocked.. I then figued since I have both I might as well change them both so I did the 3rd gear one also..
Its unreal how awesome this transmission shifts now.... So if anyone has a Honda Transmission that sorta bangs into 2nd gear please do yourself a favor and buy
2x Transmission Pressure Switch for Honda Accord 28600-P7Z-003 28600-P7Z-013
They look like the picture below.. Now becareful I seen many knock offs on ebay and amazon.. The non oem have glue on them and the Genuine Honda even the Intermotor was made in Japan and was the exact same thing as the one in the Honda bag...
[Linked Image]
2002 Honda Accord V6 3.0 Automatic Trans 250K Miles
Valvoline Maxx Life FULL SYN 5W30
HAMP or FULL Or HONDA Filtech A01s
Re: HONDA AT FINALLY LIKE NEW [Re: David1] #5088013 04/27/19 08:52 AM
G
Gebo Offline
G
GREAT INFO! Thanks thumbsup
'98 LEX LS400 295K
'02 4Runner 235K
'05 Lex LS430 85K
'07 Lex GX470 65K
SuperTech Oil
Toyota ATF's and Coolant
Amsoil Gear Oil and Grease
(Subject to Change as the Wind Blows)
Re: HONDA AT FINALLY LIKE NEW [Re: David1] #5088014 04/27/19 08:53 AM
J
joekingcorvette Offline
J
Mine shifts great but thanks for the tip. I am sure there are others may benefit from this info. Sounds like your Honda is giving you good service for a lot of miles. I hope mine hangs in there too.
2005 Chevrolet Corvette
2014 Ford F-150 4x4 supercrew
2014 Jeep Grand Cherokee Limited (wifes)
2012 Honda Civic 4 door (my daily driver)
2007 Lund Tyee Grand Sport Mercury 115HP 9.8HP
Re: HONDA AT FINALLY LIKE NEW [Re: David1] #5088035 04/27/19 09:09 AM
W
WagonWheel Offline
W
I usually get a little flare from 1st to 2nd when the ATF is cold, like below 65F. Goes away after it starts to warm after a few shifts. 2003 Accord 2.4L 148k mi. with Castrol IMVF. What ATF are you running?
Good info to know if I start having similar problems.
2003 Honda Accord 2.4L 5AT - 149k miles
2006 Honda Odyssey 3.5L EX-L 121k miles (S-VCM)
Re: HONDA AT FINALLY LIKE NEW [Re: WagonWheel] #5088062 04/27/19 09:35 AM
eagle23 Offline
My 2007 V6 Accord had two of those as well. I changed both at ~75k miles as preventive measure.
One of the Honda sites I was on (DriveAccord?) pointed out that either of the switches can and usually do begin to fail in ways that are undetectable by the driver and suggested PM replacement. The result of an aging switch(es) is a softer shift than it should be with the result being potentially more internal clutch wear.
I couldn't detect any noticeable change in shifting before or after, but given that the 5 speed auto was not the strongest behind the V6 I decided the PM was the way to go.
Unfortunately I can't tell you if it worked since I traded it at ~119k miles though my earlier plan was to keep it indefinitely.
Glad your fix worked so well! To others, consider the PM replacement.
Re: HONDA AT FINALLY LIKE NEW [Re: David1] #5088098 04/27/19 10:11 AM
M
macarose Offline
M
I just did this on a 2003 Honda CR-V yesterday.
Strange question. Does the transmission need to be reprogrammed in any way once you install it? My mechanic said yes but I would love a second opinion.
Re: HONDA AT FINALLY LIKE NEW [Re: David1] #5088145 04/27/19 10:53 AM
M
mclasser Offline
M
Wow... a 6th gen V6 tranny w/250k is a unicorn!!
Glad she's running smoothly again thumbsup
2018 Hyundai Elantra VE
2013 Honda Pilot EX-L 4WD
2002 Honda Accord EX-L
Re: HONDA AT FINALLY LIKE NEW [Re: Gebo] #5088154 04/27/19 11:02 AM
das_peikko Offline
+1 .......... I feel like I want to go out an buy a Honda just so I can take advantage of this information.
Re: HONDA AT FINALLY LIKE NEW [Re: David1] #5088165 04/27/19 11:13 AM
slacktide_bitog Offline
Wow this is great information thumbsup
Re: HONDA AT FINALLY LIKE NEW [Re: David1] #5088177 04/27/19 11:35 AM
H
HangFire Offline
H
I strongly suspect those 2/3 and 3/4 shift sensors is why I got such a great deal on the 2005 Honda Pilot some years ago. It was a trade-in we bought with 98K miles, I suspect the blinking D was why it was traded-in. I read-up on the topic when I got a blinking D, and replaced both sensors with genuine Honda, mail-ordered for less than $100 total. Worked like new until 210K miles, when the radiator went bad and mixed in a small amount of coolant. It was all downhill from there, but it might have been done already. A sad ending for an otherwise great vehicle, but we got our money's worth out of it.
Various musings: http://hangfire.net
Re: HONDA AT FINALLY LIKE NEW [Re: mclasser] #5088203 04/27/19 11:59 AM
B
benjamming Offline
B
My '02 V6 with 4-speed AT has 247k miles. I appreciate the information on these pressure switches. Which p/n is for 2nd gear & which is for 3rd gear? How did you come about this information?
Re: HONDA AT FINALLY LIKE NEW [Re: benjamming] #5088222 04/27/19 12:28 PM
H
HangFire Offline
H
Just go to any on-line Honda dealer website (Majestic and HandA come to mind), pick your model and and drill down.
Re: HONDA AT FINALLY LIKE NEW [Re: macarose] #5088435 04/27/19 04:15 PM
eagle23 Offline
I would say no. It didn't on my old Accord, and never occurred to me that it would. The way I see it, it's a sensor that is not part of the programming, i.e., it feeds data to the program but doesn't change the program itself.
Re: HONDA AT FINALLY LIKE NEW [Re: WagonWheel] #5088884 04/27/19 11:21 PM
David1 Offline OP
Honda DW1 ... I have settled on that.. I have used IDIMITUS H Plus also.
Re: HONDA AT FINALLY LIKE NEW [Re: benjamming] #5088891 04/27/19 11:29 PM
David1 Offline OP
a video on You tube... the buys OBD2 computer showed 3rd gear clutch switch OFF.. Its a great video... Its not the same AT as mine but the same concept...
It showed all the sensors Ok.. STUCK OFF.. OK.. OK... as in 2nd gear pressure switch Not working... So I said Hmmm let me try this.. It was night and day...
There are many of them on You tube
look at this one.
https://www.youtube.com/watch?v=QfwBUh4H71Y
