Which is a better way to program a thermostat? Example: +1 over set temp (set at 81, turns on at 82, shuts off at 80) or just have it turn on at 81 and shut off at 80.
I usually set the span to max. This minimizes short-cycling, allows the HVAC to run more efficiently, and more effectively moves air around the spaces.
