Post your latest oil change
2011 Chevy 1500 4.8 Vortec
182,679 miles
5 quarts M1 EP 10W30, 1 quart M1 HM 10W30
Fram TG10060
drain plug 18 ft lbs
My buddys truck that Ive been changing the oil on every 5-6k miles since 40k. We live about 50 miles away from each other now so I dont see him as often. He went the longest he ever has gone on an oci since this truck is new, 9200k on this last oil change and the OLM was at 15 %. I used M1 TDT 5W40, it burned a quart in 6k and then I added a quart of cheap 10W30 and it burned another quart by the time I changed it at 9200k. not bad 2 quarts in 9200k miles. He said he wont go that long again.
2018 Hyundai Elantra SEL 2.0L
4,515 mi. 3,007 miles 3 1/2 mo. on OCI
Out: QS HM syn blend 5W20, Hyundai oil filter
In: 3-QS HM syn blend 5W20
1-QSUD full synthetic 5W20, Hyundai oil filter.
2010 Toyota Corolla Corolla LE 1.8L
71,389 miles on unit
5,683 miles on oil
Out: Amsoil XL 0w20, Toyota filter 4152-YZZA6
In: Phillips 66 Shield Choice 10w30, Toyota filter 4152-YZZA6
Bought the car last summer. Sending the XL off to Blackstone to see if there are any surprises. My 4 year old grandmonster wanted to help.
[Linked Image]
2017 GMC 2500 6.0L 1380 hours, 66,000 kms
out; Fast lube place gaga 5w30.
In Mobil 10W30 Delvac & Wix 6.2L long filter.
Front & rear diffs; Chevron 80W140.
Yes, they come under filled in my opinion.
2018 KIA Sportage 2.4 AWD
Out: Mobil1 HM 10W-30, OEM
In: GTX Ultraclean 5W-20, PH9688
2013 Hyundai Santa Fe Sport 2.0T
Out: Pennzoil Platinum EuroL 5W-30, OEM
In: GTX Magnatec 5W-30, PH9688
What are your thoughts on the M1 in the Sportage? Thanks...
My thoughts are Wemay went from steak to hamburger.
Went from Domaine Georges & Christophe Roumier Musigny Grand Cru 1990 to Trader Joe's Charles Shaw Blend.
Just playin' with you Wemay. Gotta' luv-me-some Castrol. (Korean signature)
2012 Mitsubishi Galant w/2.4L. 134.5K miles. 11K OCI with approx 1/2 Qt top off oil needed.
Out - PP 5w-30 w/Wix 57092
In - Napa Syn 5w-30 and Napa Gold 7092
2010 Ford Edge Limited AWD
Out: 5.5qts Trop Arctic 5w20 Syn Blend & MC FL500S
In: 5.5qts Shields Choice 5w20 Syn Blend & Champion COS10575
Approx 5k on oil. 70k on vehicle. Sticking to 5k OCIs
2007 Toyota Matrix 1.8L 174,892 miles
Miles on Oil: Approx 8,000. 3/4 quart make-up oil.
Out:
Milesyn 5/30 SB
STP XL4967
In: Same
Oil sample sent to Blackstone on 4/28/2019
Lol, not a problem, Triple'. A good burger has its place. ðŸ»
It ran just fine, no complaints. At first I wasn't sure but the higher HTHS made it feel ever so slightly more sluggish but I chalk that up to placebo.
Originally Posted by Ponchinizo
I have the same engine and was wondering why did you decide on a 10W-30 this time? Thanks.
No particular reason. Just part of what I had leftover from my once large stash.
2014 Subaru Forester XT
100,500 miles
OCI ~1000 miles (see below)
Out - mix of Subaru (Idemitsu) 5W30, M1 5W30 ESP, M1 5W30, M1 0W30 (see below)
In - M1 10W30 HM SN+ with M1 5W30 ESP to top off
OK, the reason for the weirdness here is that I took my car in to a Subaru dealer for a late 90kmile service and also asked them to change the plugs (which were changed at the 40kmile LSPI recall) and replace the PCV valve. I asked to NOT change the oil and they did it anyway...I guess I wonder if they may have "had" to change the oil with what it takes to do the plugs on these boxer engines, but they didn't mention anything to me when the service was being planned. Anybody who pays any attention to my posts here knows that I like to obsess about LSPI, and the only info I could find about Idemitsu 5W30 suggested that it is high in calcium. As I drove back to work after picking the car up waiting for me engine to grenade itself (hee hee, I'm exaggerating a bit), I pondered how to approach this unexpected situation.
I knew that it was going to bother me to have this oil in my car long term, and I knew I had a handful of random quarts of what I thought was "safe" oil in the garage...and I also had noticed that Target was clearing out M1 quarts. I decided to pick up a couple of clearance M1 5W30 quarts at Target, use my extractor to take out as much of the Subaru oil as I could, and refill with my quarts. I wanted to do an intake valve cleaning with my Subaru tool/fluids before long anyway and always like to change the oil right after that, so I did just that after about 1000 miles on the brew and got back on my usual oil change schedule (every 5000 miles). Before putting the 10W30 in, I pulled the plug as usual and did a full drain.
I know plenty on here will think/say I'm being obsessive-compulsive about this as well as being wasteful...they're probably right, but I did it anyway and worried less as a result (I am a bit OCD, I admit it).
Oh, another weird thing was that the dealer dumped fuel injector cleaner in the tank even though it was only about 1/3 full. I filled it up on the way home from work after noticing the item on their bill, seems like a strange thing to do without telling me. I know some people run concentrated doses of FIC and I doubt that it hurts anything....but, IDK, what if I had maybe 1/10th of a tank? Would they have done the same thing in that case, and would that have been a problem? Can you run a car on straight FIC?
2007 Jeep Grand Cherokoee 3.7:
Out: Unknown Oil M1 Extended performance Oil filter
In: 5 qts UP 5w-30 and Fram TG Filter
2006 Jeep Commander 3.7
Oil was really old and a little sludgey. Glad I got it out. Lets watch Pennzoil clean up the engines now!
