- Joined
- Jul 2, 2007
- Messages
- 5,294
By clocked the same I mean same rotational position in the hole relative to the other injectors. I noticed on my two cylinder Moto Guzzi motorcycle, which is a 1151cc displacement, that the left hand cylinder's injector's rotational position in the manifold and the right hand cylinder's injector's rotational position were not the same. Apparently they do not lock-in in the manifold port but can be rotated (clocked) freely once installed. Put another way, the power pigtail assembly on the left injector was at 2 o'clock and the right hand cylinder injector's was sitting at about 11 o'clock, rotationally.
I don't know if this might cause a difference in spray pattern left vs right or if it would even matter.
More I think about it, it doesn't matter the positioning. This was a stupid question.
