75w85 VS 75w90
ottawa
Hey Everyone,
Our 2019 Santa Fe specs 75w-85 in the transfer case and rear diff.
In the past I have used 75w-90.
I was wondering if you all think the 90 weight would be better for longevity VS .005 mileage increase for the 85.
Thanks
Super Tech 75W90 Full Synthetic $5.86/qt API GL-5 and MT-1, SAE J2360
Ive never seen proof of 'longevity'.. but those specs and price are impossible to beat.
I would assume the 85 is more shear stable performance for the X-fer case. I would imagine its same as 90 but with less VM. Depends on the below freezing performance - maybe the 75W85 flow MUCH better.. My Nissan hated the dealer installed HD 80W90 MOBIL
Just Valvoline or Pennzoil or Castrol or Supertech 75w90 in the rear would be fine.
I put supertech 75W90 in the wife's Crosstrek with a noisy rear and .... its not noisy now! I though the dealer didn't change it when last requested, but the fluid looked
new and no metal fuzz on the drain plug magnet.
Maybe just a fluke.
Originally Posted by nicholas
Hey Everyone,
Thanks
I have same dilemma. I wanna use Redline, but Redline offers 75W85 for TC and differentials, while Toyota wants 75W90.
Most 75w85 seems to be conventional while most 75w90 is synthetic now.
I would run the 75w90 myself.
Redline 75W85 is full synthetic.
I am looking at Redline for both 85 and 90 weights.
What do you y'all think?
I would pick RL 90 then.
Are you sure 75W-85 can be had in a conventional? My understanding of the recommendation of 75W-85 was to actually force people into a synthetic gear lube because there is still some conventional spec's 75W-90 out there.
That being said, I have used a synthetic 75W-90 in place of the 75W-85 gear oil call outs in all my Toyota's with no issue.
Originally Posted by ad244
Where's the 110 Crowd?
Nice SUV vehicle.
Why use a SAE 110 if it doesn't need it?
With the 2.XL engines you develop an average of 180+ Lb.ft of torque.
I am not downplaying this vehicle by any means but this is not exactly a Cummins axle-torque-twisting engine.
I would say the Redline https://www.redlineoil.com/Content/files/tech/75W85_GO_PROD_INFO.pdf gear oil would work just fine.
I use Amsoil Severe Gear 75w-110 in my Tahoe. I switched to it from 75w-90, before I joined here, because I figured it would help with the towing I do. I tow a 6,000 lbs load about 200 miles round trip twice a month. I'm not sure if it helps or not.
I have a 2019 Santa Fe(AWD) also and decided to go with what Hyundai recommends... 75w85 and picked up two bottles of Red Line 75w85..
Hey Everyone,
Thanks
