2017 Silverado 1500, front & rear diff with Amsoil Severe Gear', Transfer case with Valvoline fluid. The truck has 31k miles. The fluid in both differentials looked as one would expect, dark but still doing it's job.
The transfer case plug had the most metal shavings, fluid looked O.K..
After I was done I thought about a new rear diff cover, with the drain plug. Not a bad idea if one plans to keep the truck & do a handful of fluid changes.
I also put on a metal skid plate, about $238 from an eBay seller.
