My goal was to hit something around 10k-11k, but I've been so busy each time I get home that it was easy to push it out even more. Most miles are on rural roads with an occasional trip "down" to Binghamton or "up" to Utica or Syracuse area, so very little stop and go driving. It commutes 6 miles to work (riding the brakes 3 of them while descending into a valley) and 6 miles climbing back home. On weekends, it may haul people, groceries, lumber, grain, hay, horses, cows, ATVs, etc. Whatever is needed, it's certainly used as a truck. This isn't a pretty UOA, but seems reasonable.
11 months (May '18 to April '19)
Odometer: 109781 miles
Oil: 12935 miles
'13 F150 5.0 4x4, crew cab, 6.5ft bed, Leer fiberglass cap, 6450 lbs with half tank fuel
787 gallons of fuel burned (16.435 mpg)
477 hours (unknown idle time, as I can only track total hours for each tank of fuel)
Make-up oil was less than a quart. At just 1400 miles, the oil was down a half quart and I topped it off. At 7900 miles, I added just about 6 more ounces to get it full again. It remained full from there to the time of draining.
Both OCIs below had many miles on them before the winter set in. Like many people, I had always put in fresh oil for the cold weather, but these oils were probably far from their best for the winters they endured. The most recent OCI was at 8k in early December and was over 10k when the coldest weather hit.
The 5W-20 was just SN, without a dexos1 approval. This new one is 5W-30 SN with dexos1 Gen2 approval.
Code
Castrol EDGE Castrol EDGE
5W-30 SN 5w-20 SN
12935 miles 9557 miles
Copper 3 2
Iron 19 17
Chromium 2 0
Aluminum 5 7
Lead 2 0
Tin 0 0
Silicon 10 9
Sodium 11 3
Potassium 3 3
Boron 21 65
Moly 68 65
Nickel 1 0
Silver 0 0
Titanium 9 6
Calcium 833 2207
Magnesium 1391 9
Zinc 817 785
Phosphorus 640 604
Barium 0 0
Oxidation 32% 27%
Nitration 18% 13%
Sulfation 42% 46%
Visc@100°C 11.6 9.7
TAN 5.54 6.19
TBN 2.2 2.3
% fuel 2.82 2.55
PQI 9 6
(Particle Quantifying Index)
Oil: 12935 miles
Code
5W-30 SN 5w-20 SN
Copper 3 2
Iron 19 17
Chromium 2 0
Aluminum 5 7
Lead 2 0
Tin 0 0
Silicon 10 9
Sodium 11 3
Potassium 3 3
Boron 21 65
Moly 68 65
Nickel 1 0
Silver 0 0
Titanium 9 6
Calcium 833 2207
Magnesium 1391 9
Zinc 817 785
Phosphorus 640 604
Barium 0 0
Oxidation 32% 27%
Nitration 18% 13%
Sulfation 42% 46%
Visc@100°C 11.6 9.7
TAN 5.54 6.19
TBN 2.2 2.3
% fuel 2.82 2.55
PQI 9 6
