2013 Escape 2.0 Ecoboost surge
by HoosierJeeper - 01/19/20 10:36 AM
European Tools via Amazon - New Lug Wrench
by JHZR2 - 01/19/20 09:57 AM
Samsung 32 inch 4K curved monitor at Costco
by Cujet - 01/19/20 09:55 AM
2009 corolla 1.8
by Bettez88 - 01/19/20 09:41 AM
Remote key - OEM vs aftermarket
by AZjeff - 01/19/20 08:13 AM
Toyota Tundra Warranty
by Tundra73 - 01/19/20 08:10 AM
Shell Rotella gas truck oil change intervals?
by gtrplr71 - 01/19/20 07:12 AM
Ford Focus belt idler puller bolt ?
by rkpatt - 01/19/20 06:51 AM
Havoline 5w20 $1.72/quart
by Villalobos - 01/19/20 05:42 AM
Amazon 5qt PUP 5w-20 $16.24
by Matt1980 - 01/19/20 03:42 AM
US Miltary News - F22
by ZeeOSix - 01/19/20 03:09 AM
OEM to Ravenol
by graphine - 01/19/20 02:38 AM
D905 Brake Pads: Bosch vs. Centric vs. Akebono
by The Critic - 01/19/20 01:55 AM
Dodge dart running issues after filling up fuel
by ram_man - 01/19/20 12:58 AM
Akebono ProAct brake pads now include hardware
by The Critic - 01/19/20 12:43 AM
16 Audi S3 G13 Coolant - 40,500 miles
by agpatel - 01/19/20 12:43 AM
BMW “G3” Axle Alternatives?
by E365 - 01/19/20 12:20 AM
Scan Tool recommendation
by zmelli - 01/18/20 11:57 PM
Keyless Entry Help Needed
by DeafBrad - 01/18/20 11:55 PM
75/140 owners manual vs 75/90 tag
by BigGee - 01/18/20 11:36 PM
madjid, michWB, Brianhefty, JimBremer, Katdaddy
70471 Registered Users
94 registered members (4WD, alchargo, ArrestMeRedZ, AlienBug, aircooled, Alfred_B, 8 invisible), 2,497 guests, and 20 spiders.
Topics300,313
Posts5,173,065
Members70,471
Most Online3,728
Jan 11th, 2020
Viscosity Calculator predictions... #5086651 04/26/19 01:22 AM
Shannow Offline OP
Was messing with this paper in my spare time today
https://www.sciencedirect.com/science/article/pii/S1110062117300673#f0010
Take a base oil, add viscosity modifiers to it, and measure the properties.
Some recent discussion has been as to how the viscosity calculators work with non pure, non Newtonian oils....fortunately the paper gives for the various combinations the KV40, and KV100 of a handful of the mixes...then fills it in with the KV60 and KV80...
I've tabled them below, and then used the Widman Calculator to predict what these intermediate viscosities are...
If it's the truth....it can handle the pressure !!!
Re: Viscosity Calculator predictions... [Re: Shannow] #5087195 04/26/19 12:21 PM
G
Gokhan Offline
G
I think you're wasting your time by using this paper as a reference.
Polymers additive for improving the flow properties of lubricating oil
S. I. Shara, E. A. Eissa, and J. S. Basta, Egyptian Petroleum Research Institute, Analysis and Evaluation Department, Egypt
They start from a 4.28 cSt base oil but KV100 hardly moves with 2% VII content and even 4% VII content. This is not what we see in real oils. Typically you get 15% boost in viscosity (KV100) for every 1% of an OCP VII. I'm not sure what's going on but I'm not confident about the results in this paper.
2020 Toyota Prius Prime XLE plug-in hybrid, 2ZR-FXE engine, ~ 2,000 mi
TGMO 0W-16 SN/RC Japan
OEM spin-on oil filter Japan
Re: Viscosity Calculator predictions... [Re: Gokhan] #5091497 04/30/19 10:21 AM
MolaKule Offline
Global Moderator
Global Moderator
What we have in finished oils are single, binary, ternary or n-ary mixtures of base oil viscosities, but I see nothing wrong with the paper.
They may have wanted to experiment with a LV oil to show the VII polymer did what was predicted.
As starting points, you have to have data on the base oil properties and then characterize the resulting mix, which is what they did.
EPDM's have been used as a Multi-functional VII-PPD's.
Charlie Eppes: "What do you think we should do now?"
Don Eppes: "The same thing when I was in school and I didn't know the answer – fake it." From NUMB3RS
Re: Viscosity Calculator predictions... [Re: Shannow] #5091814 04/30/19 03:30 PM
SonofJoe Offline
Shannow,
I had a very quick squint at this paper...
I think I must have tested every commercial liquid VII, ever produced at 10 wt% in Esso 150SN (Group I, KV100 about 5.5 cst). It was one of the quick & dirty 'look-see' tests I did to anything & everything that came through the lab door.
Although there was some variation depending on SSI, dilution ratio, chemical type, straight or functionalised, etc, but typically 10% liquid VII will give you a KV100 bump of 5.5 cst & a KV40 lift of 40 cst. The variation is 'dampened' by the fact that most commercial liquid VII are cut-back to a KV100 of around 1,000 cst (think thick but handleable).
With this in mind, the numbers in the study look strange. However this might be explainable by the fact that...
a) they cut the EPDM back in xylene (which is ultra low viscosity!), not base oil.
b) they don't actually state the 'active' (ie solid) concentration of the VII (I suspect it must be VERY dilute!)
c) they blend the VII into base oil cold which is terrible practice! The rule with VIIs is always store hot, pump hot & blend hot. Only once the VII is 'in' can you let the oil cool to ambient.
As I recall, VIIs, along with all other additive components behave predictability with temperature from about 0°C upwards. HTHS is something of a special case because you're applying lots of shear. Take away the shear at 150°C & it's KV is predictable using the classic double log relationship. Below -10°C however, that's when wax typically starts to precipitate (regardless of whether you add PPD or not) & things become seriously non-Newtonian. You will always massively under-predict CCS viscosity however hard you try.
Re: Viscosity Calculator predictions... [Re: Shannow] #5091871 04/30/19 04:18 PM
Shannow Offline OP
Good info gents,
thanks
Re: Viscosity Calculator predictions... [Re: Shannow] #5091984 04/30/19 05:46 PM
G
Gokhan Offline
G
Regarding the error in KV, several years ago, Doug Bogart, STLE CLS, Laboratory Director, Wear Check USA, had replied to me as:
"Normally +/- 2 cSt for given SAE. With new oils, it’s less than +/- 0.5 cSt, not much significance."
If we take the absolute error as ±0.5 cSt, this corresponds to a ±5% relative error for KV100 = 10 cSt.
Therefore, it looks like the the KV values reported in the paper satisfy ASTM D341 well within the error bars.
Re: Viscosity Calculator predictions... [Re: Gokhan] #5092032 04/30/19 06:23 PM
G
Garak Offline
G
For the extrapolated values, that won't hold.
Plain, simple Garak.
Re: Viscosity Calculator predictions... [Re: Garak] #5092056 04/30/19 06:39 PM
G
Gokhan Offline
G
OK, rather than opposing everything without doing any calculation yourself, why don't you extrapolate the KV100 from the KV40 and KV80 values in the above table and then see if it holds or not?
Re: Viscosity Calculator predictions... [Re: Gokhan] #5092184 04/30/19 08:50 PM
G
Gokhan Offline
G
It actually takes only a minute or two. All you have to do is to stick the values in:
https://www.widman.biz/English/Calculators/Operational.html
The answer is, yes, the extrapolation works. You get similar results to what Shannow got for the interpolation.
I'm not too worried about ASTM D341 being applicable to finished oils with VII and DI or not. It's one of the better tools we have. The data here seems to confirm it.
Re: Viscosity Calculator predictions... [Re: Gokhan] #5092330 05/01/19 02:46 AM
E
edhackett Online Content
Online Content
E
This study was base oil and VII only. The chart holds because VI improvers are hydrocarbons, thus ASTM D341 applies. You can't use this data to prove it works for fully formulated oils, which are not hydrocarbon fluids. ASTM D341 specifically warns that non hydrocarbons do not respond linearly. We don't have a clue what the effect of the multitude of combinations of non hydrocarbon components used in any specific oil fully formulated oil might have on an extrapolated number.
Without measured KV150 numbers you can't even begin the process of empirically validating your equations.
Ed
Never attribute to engineers that into which politicians, lawyers, accountants, and marketeers have poked their fingers.
Re: Viscosity Calculator predictions... [Re: edhackett] #5092343 05/01/19 03:33 AM
G
Gokhan Offline
G
Ed
Hi Ed, you're overinterpreting things.
Exact wordings from ASTM D341:
"It should also be emphasized that fluids other than hydrocarbons will usually not plot as a straight line on these charts."
The way I would interpret it would be "Don't expect it to work it for any fluid" rather than your interpretation "We have this nice oil tool but don't expect it to work if the oil is a finished oil."
I would worry more about the VIIs' effect, which greatly modify the viscosity. The fit function isn't supposed to work well when there are hydrocarbon phase transitions, which is what the VIIs go through in order to modify the viscosity. Therefore, what you said about the hydrocarbons always fitting nicely is also an overinterpretation. Now, you're worried about the DI pack, which has a much smaller effect on the viscosity and should easily be absorbed into the coefficients of the fit function?
Also, if ASTM D341 is completely useless for finished oils, why in the world do they bother documenting the viscosity index (VI) in the PDSs for virtually every finished oil? The viscosity index is based on ASTM D341.
Yes, like every approximation, there is an error in ASTM D341, which varies with the oil and additives. However, to say that it's useless for anything other than pure (neat) base oils is a stretch.
Re: Viscosity Calculator predictions... [Re: Gokhan] #5092349 05/01/19 03:57 AM
Shannow Offline OP
phase transitions ???
Please explain what you mean by phase transitions in the performance of Viscosity Modifiers...
edit...obviously within the range of 0-150C which is what we are talking about...
Re: Viscosity Calculator predictions... [Re: Shannow] #5092359 05/01/19 04:15 AM
G
Gokhan Offline
G
(Quasi) phase transition as in the VII molecules changing their shapes...
Re: Viscosity Calculator predictions... [Re: Shannow] #5092582 05/01/19 08:51 AM
E
emod Offline
E
I just want to emphasize that VII coil size expansion with temperature is not necessary to achieve significant elevation of viscosity index (VI).
The results in this study - How Polymers Behave as Viscosity Index Improvers in Lubricating Oils, show that coil size expansion with temperature is not necessary to achieve significant elevation of viscosity index (VI), but polymers which do expand with temperature have higher VI contributions than those that do not.
As you will see from the study, polymer coil size in solution is relatively invariant with temperature for OCP VIIs. Olefin copolymers thicken base oils by about the same proportion, regardless of temperature. Situation is different for PMA VIIs because they do expand when temperature increases.
You can find the study here - https://www.researchgate.net/public...sity_Index_Improvers_in_Lubricating_Oils
It is also available in .pdf format.
Re: Viscosity Calculator predictions... [Re: emod] #5092850 05/01/19 02:10 PM
G
Gokhan Offline
G
Thanks for this! This is an excellent, high-quality serious recent research article from the Applied Science Department of Warren Buffet's Lubrizol additive company! I've added it to my library.
Quickly glancing at it, one of its conclusions seems to be that the OCP VII has very similar viscosity - temperature relationship to that of pure (neat) base oils.
Given that the OCP VII is by far the most common VII these days because it doesn't leave nearly as much turbocharger deposits, this explains why the ASTM D341 viscosity - temperature calculator for the finished oils and my base-oil-viscosity calculator work so well.
