15w40 in my automatic trans.
by Ursatdx - 09/17/19 03:16 PM
Update on my Stihl BG 86
by 1978elcamino - 09/17/19 03:11 PM
Offset print oil
by Matt_Pill - 09/17/19 03:06 PM
Which 508.00 oil would you choose?
by Vigg - 09/17/19 02:55 PM
Any BMW LL04 recommendations?
by M3m3x5 - 09/17/19 02:18 PM
5W30 Suggestions/Subaru
by Motoretro - 09/17/19 02:18 PM
Recommend Costco tires
by henni - 09/17/19 01:58 PM
Castrol SRF Shortage
by kyoo - 09/17/19 01:26 PM
All aftermarket drums and shoes = junk?
by nthach - 09/17/19 12:38 PM
Synthetic ISO 32 Hydraulic Fluid for BL-7000SLX
by 05UFCaptain - 09/17/19 11:51 AM
TPS only seeing 3.7v at WOT
by joegreen - 09/17/19 11:39 AM
Granite Countertops Are Magnetic. Who Knew ?
by Dwight_Frye - 09/17/19 09:44 AM
2019 J.D. Power VDS
by buster - 09/17/19 09:05 AM
Possible to add catch can?
by cwilliamsws6 - 09/17/19 09:02 AM
Update on GF-6
by buster - 09/17/19 08:40 AM
motul eco-lite 5w30
by avi1777 - 09/17/19 07:47 AM
Hyundai sonata 2.4l burning oil
by Grambo - 09/17/19 07:22 AM
Mazda CX5 2.5 oil question
by Tallman - 09/17/19 06:54 AM
Can I use 10W40 gtx HM in cold winter like -5F?
by Cheburashka - 09/17/19 06:43 AM
BMW Longlife-04: Evolving Performance Requirements
by Bjornviken - 09/17/19 06:40 AM
thetransman, SamBilbrey, williamfoster060, kappa8, jayrod65
69308 Registered Users
99 registered members (4WD, 1978elcamino, 03s, 2004tdigls, 007, 72sub, 16 invisible), 2,366 guests, and 33 spiders.
Topics294,693
Posts5,064,706
Members69,308
Most Online3,532
Jul 30th, 2019
Red battery light came on, Ford E150. #5086085 04/25/19 03:34 PM
L
laserred96gt Offline OP
L
Battery light came on today on my way home from work, I started thinking bad alternator so turned off the AC and radio and opened the windows waiting for the engine to die but luckily I made it home, ( I've been stranded by bad alternators twice before, not fun ). What do you guys think? Thanks.
2017 4Runner Limited, 50k
04 E-150, 4.6, 240K, Synblend 5w20.
11 Camry 2.5, 70K, PU 5w20.
Re: Red battery light came on, Ford E150. [Re: laserred96gt] #5086098 04/25/19 03:57 PM
O
Oily_Thing Offline
O
I think you need to put a voltmeter on the battery with the engine off, and with the engine running.
2013 Cadillac XTS4 3.6
2015 Dodge Durango Limited 3.6
Re: Red battery light came on, Ford E150. [Re: laserred96gt] #5086099 04/25/19 03:57 PM
P
Pelican Offline
P
Could be Battery or Alternator, have it checked
Re: Red battery light came on, Ford E150. [Re: laserred96gt] #5086110 04/25/19 04:08 PM
J
JC1 Offline
J
How old is the truck and how old is the battery?
I would try to get both the alternator and battery load tested.
Are the terminal posts clean? What about battery level (if it's the type of battery that can have water added I'd check that too).
2015 Grand Caravan SXT Plus 5w-30 Valvoline White Bottle/Fram Ultra Filter
1997 Honda Civic CX 5w-30 Shell Conventional/Fram Ultra Filter
Re: Red battery light came on, Ford E150. [Re: laserred96gt] #5086112 04/25/19 04:11 PM
1
1978elcamino Online Content
Online Content
1
same thing happened to my 02 f150. To trouble shoot the first thing I did was get my son in the drivers seat watching the light, I tapped on the alternator with a hammer. The light went away but after a two mile test drive it came back. So, a reman alternator went on and to this day 60k later my brother in law is driving the truck today with no charging issues. Lots of f series among my friends and family, around 200k is when they begin failing. If I remember correctly, mine failed around 218k.
2018 F150 5.0
2016 Ford Fusion 2.5
Re: Red battery light came on, Ford E150. [Re: laserred96gt] #5086127 04/25/19 04:33 PM
L
L
Battery is platinum from a from advance Auto parts, 3.5 year old, I just pulled the alternator out to get it tested , it's a motorcraft so I'm assuming it's the original.
Re: Red battery light came on, Ford E150. [Re: laserred96gt] #5086128 04/25/19 04:33 PM
01rangerxl Offline
It probably needs an alternator, but do get the battery tested too.
The alternator in my 2002 Ranger went out just before 200K miles. Same symptom...battery light came on while driving and I could see on the Scangauge that it wasn't charging.
2002 Ford Ranger XLT | 3.0 V6 Auto 2WD | 231K miles
1994 Ford Ranger STX | 4.0 V6 Manual 4X4 | 201K miles
1994 Ford Explorer XLT | 4.0 V6 Auto 4X4 | 250K miles
Re: Red battery light came on, Ford E150. [Re: laserred96gt] #5086233 04/25/19 06:13 PM
J
JLTD Offline
J
Sudden failure I'd check the belts first, then alt and battery.
I use the overseas manual to choose my oil viscosity.
Using AMSOIL
Hers: 2008 Jeep Liberty 149k, SS5w30/Amsoil
His: 2015 4Runner 55k, SS 5w20/Amsoil
Re: Red battery light came on, Ford E150. [Re: laserred96gt] #5086239 04/25/19 06:20 PM
CT8 Offline
Bob is my battery light is on guy.
2015 F150 2.7
2018 F350 6.2
Re: Red battery light came on, Ford E150. [Re: CT8] #5086256 04/25/19 06:29 PM
L
L
Haha yeah, it was the a bad alternator, got the new one in.
I was waiting for it to fail and I was hoping to not get stranded. Thanks for the replies guys.
Re: Red battery light came on, Ford E150. [Re: JLTD] #5086410 04/25/19 08:19 PM
T
talest Online Content
Online Content
T
Yes. Belt snap, alternator stops charging, battery light comes on. That is the most common cause, battery light indicates charging system problem, and the car will run fine until the battery goes dead.
The RC number on your battery is supposed to indicate how long in minutes this will be, given alternator failure, to get your vehicle to safety where it can be serviced by an automotive professional.
Re: Red battery light came on, Ford E150. [Re: laserred96gt] #5086854 04/26/19 08:55 AM
1
Online Content
1
so how about a follow up returning from the alt test, would like closure.
when I replaced mine I went shopping online to find one locally since I couldent wait to order one. I found pepboys to be the least expensive using their online coupon code. I think it was about 69 bucks, everyone else was over 100, and that was for a reman. Opening the box I was shocked at that price it even came with the pulley
2018 F150 5.0
