Alignment questions: is camber/caster not usually touched?
by FordBroncoVWJeta - 01/26/20 10:47 PM
Pricing used tires
by PumpPusher - 01/26/20 10:21 PM
STP Motor Oil at HF
by kstanf150 - 01/26/20 10:07 PM
9 years for the 4 cylinder Eco-boost
by Snagglefoot - 01/26/20 09:39 PM
So I picked this up..
by Mad_Hatter - 01/26/20 08:49 PM
New here and question about oil.
by Sunstealth - 01/26/20 08:42 PM
Looking for a car for $4k or less
by SVTCobra - 01/26/20 08:09 PM
I'm looking for a 2017 Camry LE in Pgh. PA area
by JimPghPA - 01/26/20 07:59 PM
just bought a lift!
by agarb - 01/26/20 07:54 PM
09 Mercury Grand Marqyus fix or dump?
by John_K - 01/26/20 07:14 PM
Any Castrol Edge EP Users ?
by ChrisD46 - 01/26/20 07:06 PM
Good inexpensive smart charger?
by dvancleve - 01/26/20 06:12 PM
top fuel flames.
by red7404 - 01/26/20 05:24 PM
What say you?
by Mad_Hatter - 01/26/20 05:18 PM
2006 Cadillac CTS: worth looking into or run away?
by 53' Stude - 01/26/20 04:07 PM
2012 Elantra battery running at 11.7 volts
by schuylkill - 01/26/20 03:31 PM
Chevron Supreme no longer at Costco
by OilUzer - 01/26/20 03:18 PM
tampasaint, rdmjone, BigGeo, apham8, Sunstealth
70535 Registered Users
39 registered members (65convertible, 1WildPig, ArrestMeRedZ, 69GTX, AC1DD, 2strokeNorthstar, 4 invisible), 2,090 guests, and 21 spiders.
Topics300,617
Posts5,179,386
Members70,535
Cut Open - Mazda OEM @ 7,000kms #5086040 04/25/19 01:50 PM
M
mcwilly Offline OP
M
Another well made filter off the CX3.
[Linked Image]
[Linked Image]
[Linked Image]
[Linked Image]
[Linked Image]
[Linked Image]
2016 Mazda CX3 48,000km
2010 Subaru Sti 77,000km
2007 Buick Rendezvous 105,000km
2001 Toyota Echo 262,000km
Re: Cut Open - Mazda OEM @ 7,000kms [Re: mcwilly] #5086045 04/25/19 01:54 PM
R
RamFan Offline
R
Looks good. When did Mazda stop putting end caps on these? I've cut open a few off the CX-5 and they've all had metal end caps.
18 Giulia Ti Sport Q4
  • 2.0T I4 - 22k - PP Euro LX 0w30 - PureOne - 10k/1yr
16.5 CX-5 Touring AWD
  • 2.5L I4 - 67k - Castrol Edge EP 0w20 - Denso - 7.5k/1yr
Re: Cut Open - Mazda OEM @ 7,000kms [Re: mcwilly] #5086052 04/25/19 02:02 PM
M
mcwilly Offline OP
M
Not sure this is the second one I have cut, both the same:
https://www.bobistheoilguy.com/foru...5010-7600-7-700kms-2016-cx-3#Post4964645
Re: Cut Open - Mazda OEM @ 7,000kms [Re: RamFan] #5086054 04/25/19 02:03 PM
Z
ZeeOSix Offline
Z
Probably when Denso started making them.
Re: Cut Open - Mazda OEM @ 7,000kms [Re: mcwilly] #5086076 04/25/19 02:26 PM
B
Bill_W Offline
B
The previous ones had metal end caps. No Skyactiv oil filter has a ADBV either. You would think bad oil would sneak around on the ends to the good side. A closer look shows the ends are glued. Nice thick media. Different, but still good.
Slick
Re: Cut Open - Mazda OEM @ 7,000kms [Re: mcwilly] #5086129 04/25/19 03:36 PM
The Critic Offline
Are these the real OE Mazda filters or is it one of their "value line" filters?
2011 Toyota Prius 1.8L - 202K - Valvoline Premium Blue Restore 10W-30
2007 Honda Accord 2.4L - 143K - Valvoline Premium Blue Restore 10W-30
Re: Cut Open - Mazda OEM @ 7,000kms [Re: ZeeOSix] #5086183 04/25/19 04:30 PM
blupupher Offline
I hate that I looked at this filter and the first thing I thought was "hmm, a Denso made filter".
The one in the link looks a little different. Biggest difference is the bypass button, in this one it is round, in the one in the link is squarish (or is it just because it is opposite sides?)
So did you put the same thing back on?
'18 Santa Fe: PP 10W-30/OEM
'18 Soul: Synpower 5W-30/PG
'10 Santa Fe: Synpower 5w-30/D+
'04 F150: Magnatec 10w-30/ST
'12 xB: M1EP 0W-20/CQ Blue
'02 F150: Magnatec 5W-20/D+
'94 VT1100: Peak 15W-40/D+
Re: Cut Open - Mazda OEM @ 7,000kms [Re: The Critic] #5086265 04/25/19 05:34 PM
PimTac Offline
The value line filters are manufactured in Mexico. These are Thailand made filters. These are considered a step up from the value line.
2017 Mazda CX5
Valvoline Advanced Synthetic 0w20
Roki OEM filter.
Re: Cut Open - Mazda OEM @ 7,000kms [Re: blupupher] #5086319 04/25/19 06:01 PM
Z
ZeeOSix Offline
Z
Denso has a round bypass valve - think the photo gives an optical illusion.
Re: Cut Open - Mazda OEM @ 7,000kms [Re: mcwilly] #5086322 04/25/19 06:06 PM
wemay Offline
Filter looks well made indeed. It's just another OE that doesn't use metal end caps, and in this case, no end caps whatsoever. Makes all those arguments moot.
2019 VW Passat Wolfsburg TSI - Castrol Edge Professional LL IV FE 0W-20, OEM
2013 Hyundai Santa Fe Sport 2.0T - Mobil1 Annual Protection 5W30, M1-104
Re: Cut Open - Mazda OEM @ 7,000kms [Re: mcwilly] #5086330 04/25/19 06:13 PM
P
PotatoFarmer77w Offline
P
Thanks for the cut open thumbsup
1995 Chevrolet K1500 5.7 v8
2007 Ford Ranger 2.3 I4
Re: Cut Open - Mazda OEM @ 7,000kms [Re: ZeeOSix] #5086333 04/25/19 06:16 PM
PimTac Offline
ZeeOSix, have you heard anything definitive that Mazda has or is switching to Denso from Roki? Ever since their Toyota tie up, I suspected that would be the case but have never heard the answer.
It would make sense and additionally, the Toyota alliance was made to give Mazda access to the Toyota supply stream. That may not be across the board though.
2017 Mazda CX5
Roki OEM filter.
Re: Cut Open - Mazda OEM @ 7,000kms [Re: PimTac] #5086385 04/25/19 07:03 PM
Z
ZeeOSix Offline
Z
^^^ Haven't heard anything official, but it's clear that this Mazda OEM filter is Denso by the construction, especially if Mazda and Toyota are collaborating then this filter looks to be a result of that.
Re: Cut Open - Mazda OEM @ 7,000kms [Re: mcwilly] #5086393 04/25/19 07:08 PM
Mr Nice Offline
I like the inlet holes and center tube with nice opening.
I know oil is under pressure but some filters have very small holes.
Re: Cut Open - Mazda OEM @ 7,000kms [Re: mcwilly] #5086421 04/25/19 07:24 PM
DzoG20 Offline
and the $65k question is why not use the Fram Ultra?
Look like the skyactiv certified WIX has the same bypass rating as the latest Ultra(per website specs).
And AFAIK the syntetic should flow better than the paper filter so whats the deal? - besides the warranty concerns ?
What makes this one special ?
