Filter Forum rules
by dnewton3. 06/16/19 12:09 PM
My daughter shooting
by Eosyn. 06/16/19 12:04 PM
Window Privacy Film (Tint)
by Warstud. 06/16/19 11:52 AM
Anyone got a Fireworks stash?
by Vern_in_IL. 06/16/19 11:25 AM
Oil Themed Tool Kit
by javacontour. 06/16/19 10:41 AM
Carfax reveals cursed vehicle
by Elkins45. 06/16/19 09:38 AM
We love our ethanol!
by SevenBizzos. 06/16/19 09:36 AM
LSPI Event - ?
by josephp732. 06/16/19 08:39 AM
'09 Honda Metropolitan hit 15k this morning
by Lawn_Care. 06/16/19 08:17 AM
16 y/o car w/98k, switch oil?
by Ricky_Samsonia. 06/16/19 08:13 AM
Ultrasonic Cleaner
by ET16. 06/16/19 06:27 AM
Best Shell/Pennzoil is?
by Dragon44. 06/16/19 01:22 AM
Getting the the boat ready for summer holidays
by Snagglefoot. 06/15/19 10:57 PM
Fram: With Even More Protection
by TheLawnRanger. 06/15/19 10:01 PM
More kid pictures
by Marco620. 06/15/19 09:34 PM
Pennzoil Platinum 5W30 : Does It Hold Up ?
by ChrisD46. 06/15/19 09:16 PM
SyedTribo, bagyoau, frank57, gheewala114, Rob_Jeff
68413 Registered Users
77 registered members (aquariuscsm, 86lxjunker, 007, Al, 2003f7, 8 invisible), 2,032 guests, and 34 spiders.
Topics290,272
Posts4,987,474
Members68,413
Most Online2,967
Mar 10th, 2019
Tire leak with new wheels. What would YOU do? #5086116
04/25/19 04:20 PM
04/25/19 04:20 PM
Canada
Lolvoguy Offline OP
Lolvoguy  Offline OP
Canada
Some of you may recall that on the Lexus below, I installed a brand spankin' new set of Lexus F Sport wheels last summer.
All has been going well with them. Considering the car only has about 50 k miles the wheels REALLY make the car look MUCH newer than it is.
My problem is with one of my rear tires. I seem to have a SLIGHT leak in it which is causing a 5 PSI leak over a one month period.
I've closely followed all the other tires and they all seem to be holding PSI's relatively consistent.
I don't think it's the wheels that are are fault, but maybe the bead? or maybe the TPMS? or the tire has a nail in it? Not sure really
Considering the leak is so small, I almost doubt I'd be able to find it with soapy water in a spray bottle.
Should I have this tire taken in to have the leak repaired?
I could just keep topping it off monthly and in doing so prevent any scratches etc. caused by the tire shop.
I'd also save the money since we hardly drive this car at all (about 3k miles per year).
What are your thoughts?
06 Lexus IS350- Wife
88 BMW 325is- Mistress
Say "no" to Turbo!
Re: Tire leak with new wheels. What would YOU do? [Re: Lolvoguy] #5086120
04/25/19 04:26 PM
04/25/19 04:26 PM
Lyndhurst NJ
Audios Offline
Audios  Offline
Lyndhurst NJ
Spray it down with soapy water and trace the leak. Take the valve cap off and check that also, sometimes the valve cores leak.
2002 VW Golf TDI-Mobil 1 5/40 TDT
2007 Mercedes GL320 CDI- M1 0/30 ESP
2005 BMW M3 BMW Twin Power 10/60
2003 BMW M5-Fuchs 5/40
1998 BMW M3/4/5 Fuchs 5/40
Re: Tire leak with new wheels. What would YOU do? [Re: Lolvoguy] #5086121
04/25/19 04:26 PM
04/25/19 04:26 PM
KS
FordBroncoVWJeta Offline
KS
I bet you would find it if you took it off the car and sprayed it with some soapy water or put it in a tank with some water. There is probably a small nail somewhere or a small bead leak. You will find it IF you put in a little time.
2017 Volkswagen Jetta 1.4T - 2015 Honda CRV 2.4 - 2012 Volkswagen Jetta 2.0 - 2007 Chevy Trailblazer 4.2 - 2003 Ford Taurus 3.0 Vulcan
Re: Tire leak with new wheels. What would YOU do? [Re: Lolvoguy] #5086123
04/25/19 04:29 PM
04/25/19 04:29 PM
iowa
Traction Offline
Traction  Offline
iowa
I would be looking for a hole. Screws, and nails start off as tiny leaks, then the hardware keeps getting driven in deeper and leak more. Spray it down with soapy water, and it might be obvious where the problem is. Then decide what to do.
Certified Tire Service Instructor since 2009
50 Chevy Fire Truck
13 Tahoe Pursuit
97 C5 Corvette
00 BMW M Roadster
02 Camry
12 Camry
81 Camaro
55 Chevy C4
Re: Tire leak with new wheels. What would YOU do? [Re: Traction] #5086135
04/25/19 04:43 PM
04/25/19 04:43 PM
Raleigh NC
MrMoody Offline
MrMoody  Offline
Raleigh NC
Yes, what they said, and add that a rear tire leaking almost always has something in it: the front tire rolls over it and kicks it up.
2018 Hyundai Kona 1.6T DCT
2006 Pontiac (Holden) GTO AT
2001 Pontiac Grand Prix GT 3.8 NA (beater)
2005 Toyota Matrix FWD (ultra beater)
"Fob" and "Noack" are not acronyms.
Re: Tire leak with new wheels. What would YOU do? [Re: Lolvoguy] #5086149
04/25/19 05:00 PM
04/25/19 05:00 PM
San Antonio, TX
das_peikko Offline
das_peikko  Offline
San Antonio, TX
There was a recent thread where somebody discovered a barcode sticker inside the tire right where the sealing bead is; maybe that's your problem?
Re: Tire leak with new wheels. What would YOU do? [Re: Lolvoguy] #5086180
04/25/19 05:26 PM
04/25/19 05:26 PM
pa
benjy Offline
benjy  Offline
pa
cast wheels can have a bit of porous metal. the cure for my new reproduction 64 knockoffs was a coat of shellac in them on the inside, it worked!
Re: Tire leak with new wheels. What would YOU do? [Re: Lolvoguy] #5086237
04/25/19 06:17 PM
04/25/19 06:17 PM
Canyon County Idaho
CT8 Offline
CT8  Offline
Canyon County Idaho
Pull the wheel off of the car fill it with max air pressure and dunk the tire in a tank and watch for bubbles.
2015 F150 2.7
2018 F350 6.2
Re: Tire leak with new wheels. What would YOU do? [Re: MrMoody] #5086238
04/25/19 06:18 PM
04/25/19 06:18 PM
iowa
Traction Offline
Traction  Offline
iowa
I have fixed hundreds of flats, and more often than not it is the right rear tire. Most of the debris is on the right side of the road, and the front tire stands it up just in time. You run over stuff all of the time and nothing happens. Just try to not hit a bungee cord, they make a mess.
50 Chevy Fire Truck
13 Tahoe Pursuit
97 C5 Corvette
00 BMW M Roadster
02 Camry
12 Camry
81 Camaro
55 Chevy C4
Re: Tire leak with new wheels. What would YOU do? [Re: CT8] #5086267
04/25/19 06:34 PM
04/25/19 06:34 PM
Suburban Washington DC
atikovi Offline
atikovi  Offline
Most people don't have tanks but they do have bathtubs.
Re: Tire leak with new wheels. What would YOU do? [Re: atikovi] #5086296
04/25/19 06:50 PM
04/25/19 06:50 PM
Joplin
Cressida Offline
Cressida  Offline
Joplin
Agree that most people do not have a tank large enough for a tire.
I think my wife will not be happy if she sees me lugging a 16" mounted tire through the house headed toward the bathroom. Similar to when you try and put your valve covers in the dishwasher.
Re: Tire leak with new wheels. What would YOU do? [Re: Lolvoguy] #5086312
04/25/19 06:58 PM
04/25/19 06:58 PM
ME
eljefino Offline
eljefino  Offline
ME
Who mounted them? Road hazard coverage generally includes bead leaks. And if not they may still warranty their work for free somehow.
Re: Tire leak with new wheels. What would YOU do? [Re: Lolvoguy] #5086323
04/25/19 07:06 PM
04/25/19 07:06 PM
Northern KY
Elkins45 Offline
Elkins45  Offline
Northern KY
I tubed the rear tires of my mower but one of them failed. Doing the work involved a horrible wrestling match with screwdrivers and crowbars, so when the tube failed I bought two new tires. I’ve only mounted one, and won’t mount the second one until the other tube fails. I just about knocked myself out when a pry bar slipped and whacked me in the head.
When I mounted the new one I couldn’t get the bead sealed. I had to resort to the lighter fluid explosion method to get it seated and I thought it was going to melt itself because the difference between too little fluid and too much fluid is surprisingly small.
In retrospect I would gladly have paid someone to do the work. I have one of those Harbor Freight manual tire mounters, but a mower wheel won’t go over the center post because it just has a 1” hole for a keyed shaft. Mounting tires isn’t for the weak!
Re: Tire leak with new wheels. What would YOU do? [Re: Lolvoguy] #5086401
04/25/19 08:12 PM
04/25/19 08:12 PM
USA
mk378 Offline
mk378  Offline
USA
Find the leak first. The best way is to remove the wheel and submerge it. There are some rim leaks that will only leak when the car is parked with the bad spot down, so the tire is flexed from the weight. Those are hard to find.
Re: Tire leak with new wheels. What would YOU do? [Re: atikovi] #5086451
04/25/19 08:56 PM
04/25/19 08:56 PM
Phoenix
dishdude Offline
dishdude  Offline
Phoenix
Maybe a trashcan? No way I'm putting a tire in my bathtub.
2018 Challenger SRT 392 PUP 0w-40 Wix 57899XP
2018 GTI
