Do you use gas brand exclusively ?
by MetalSlug - 09/17/19 04:58 AM
Mobil 15w30
by Chadders99 - 09/17/19 02:20 AM
2018 VW Atlas 3.6 4 Motion Reliability?
by GZRider - 09/16/19 11:48 PM
Account and posts removal
by newbe46 - 09/16/19 10:00 PM
Yamaha EF2800i break-in
by Uregina09 - 09/16/19 09:43 PM
Adding TCW3 to Gas Tank?
by maverickfhs - 09/16/19 08:45 PM
Motul 75w90 1L 12 pack $13.25
by wkcars - 09/16/19 08:36 PM
2019 Ford Fusion vs used?
by FL-400S - 09/16/19 08:33 PM
What is the reasoning for 2-fuel tanks on a rv?
by RazorsEdge - 09/16/19 07:54 PM
Thoughts and opinions on family haulers
by ram_man - 09/16/19 07:53 PM
2018 Silverado 5.3L M1 AFE 0W-20 5,065
by K20FA5 - 09/16/19 07:43 PM
18 Jeep 3.6 PPU 0w20 5k OCI
by IndyFan - 09/16/19 07:06 PM
Federal 9mm 115g FMJ Brass - $7.97/50 @ Walmart
by blupupher - 09/16/19 06:47 PM
Motorcraft FL-1995W different than than non-W?
by Cubey - 09/16/19 05:31 PM
1973 Bronco w/original 302
by BKinSD - 09/16/19 05:18 PM
B&S 21hp burning oil
by Mike141 - 09/16/19 04:28 PM
Prime Guard POF2222 C&P...
by AnthemBassMan - 09/16/19 03:36 PM
R0CKETMAN, Southbend9, Bigaledge32, emilio15, Kokopelli34179
69303 Registered Users
35 registered members (billt460, bruckus, bradepb, BillyE, Amenhotep, carviewsonic, 5 invisible), 679 guests, and 23 spiders.
Topics294,672
Posts5,064,238
Members69,303
Most Online3,532
Jul 30th, 2019
Drain and fill 08 Kia Rio. #5086050 04/25/19 02:59 PM
J
Jetsfan421 Offline OP
J
Was wondering if I have to do a relearn after doing a drain and fill. I'm using idemitsu sp3 fluid. I bought 4 quarts, drain and fill is supposed to be 3.5 so should be enough. Unit has been maintained very well over the years with solid Carfax reporting.
Re: Drain and fill 08 Kia Rio. [Re: Jetsfan421] #5086051 04/25/19 03:01 PM
Char Baby Offline
I'd just drive normally.
"Retired"
'15 Nissan Altima 2.5 SV
'15 Honda Civic 1.8 LX
Re: Drain and fill 08 Kia Rio. [Re: Jetsfan421] #5086065 04/25/19 03:13 PM
F
FordBroncoVWJeta Offline
F
no
2017 Volkswagen Jetta 1.4T - 2015 Honda CRV 2.4 - 2012 Volkswagen Jetta 2.0 - 2007 Chevy Trailblazer 4.2 - 2003 Ford Taurus 3.0 Vulcan
Re: Drain and fill 08 Kia Rio. [Re: Jetsfan421] #5086154 04/25/19 05:04 PM
slacktide_bitog Offline
No, you do not need to do any kind of relearn smile
Simply drain the fluid, measure how much came out, and refill with the same amount
Re: Drain and fill 08 Kia Rio. [Re: Jetsfan421] #5086594 04/25/19 11:37 PM
dubber09 Offline
Make sure the fluids are at same or about same temp. After refill go thru all gears with engine on staying in each gear (brake on) for 3-5 secs, repeat 2-3 times.
Kia Sportage 2014 GDI 2.4L
Kia Forte 2014 MPI 1.8L
Re: Drain and fill 08 Kia Rio. [Re: Jetsfan421] #5086648 04/26/19 02:14 AM
J
J
Dubber09 I will make sure to cycle all the gears, thanks for the heads up. I plan on doing the d&f on my next oil change. Probably in June.
Re: Drain and fill 08 Kia Rio. [Re: Jetsfan421] #5087075 04/26/19 11:55 AM
dubber09 Offline
When refilling ATF, and if your car has ATF cooler, it'll be much faster and spill free if you detach hose between cooler and transmission, there are two of them - one goes from transmission into cooler and one coming out of cooler and back into transmission, they may have red and yellow paint marks on them where red is the one going into the cooler, detach that one to allow air to escape while refilling. Don't forget to put it back on and secure with its clump when done.
