Do downstream O2 ever get poisoned?
by PandaBear. 06/17/19 03:51 PM
Sharing files
by Chester11. 06/17/19 03:25 PM
Fumoto valves
by cwilliamsws6. 06/17/19 03:12 PM
Who goes to beaches for vacation?
by 53' Stude. 06/17/19 02:35 PM
What would make BITOG better?
by Hastrup. 06/17/19 01:44 PM
Adhesive sealant FTW!
by mclasser. 06/17/19 01:29 PM
1985 Toyota Camry.. Any tips?
by spavel6. 06/17/19 01:20 PM
AAP 25% off
by rollinpete. 06/17/19 12:52 PM
TCW3 and direct injection
by ARB1977. 06/17/19 12:45 PM
Brake bleeding procedure
by painfx. 06/17/19 11:28 AM
5W20 walmart Full Syn bad smell
by ragtoplvr. 06/17/19 11:18 AM
Leaving Amsoil Ea15k filter for 2 oil changes?
by metroplex. 06/17/19 11:15 AM
Just did my 1st CVT fluid change
by Char Baby. 06/17/19 10:24 AM
Saab 9-3 Carrier Bolts - 155 ft lbs
by ET16. 06/17/19 09:15 AM
Fran CA11480
by jcartwright99. 06/17/19 08:43 AM
Recommend oil for 2020 Kia Soul 2.0L
by Hoot_r. 06/17/19 08:40 AM
Why does Amsoil market the way it does?
by Redright9. 06/17/19 08:36 AM
'11 CTSV - M1EP 10w30 - 8K Built LSA - ~2k sample
by oilnoob32. 06/17/19 08:34 AM
Blue smoke and Mobil 1 Syn High Milage!!
by Kestor. 06/17/19 08:03 AM
Skraeling, Metalmanx48, Cannedcreamcorn, Kestor, Slipcase
68418 Registered Users
91 registered members (Astro_Guy, AlienBug, 1WildPig, ArrestMeRedZ, 53' Stude, 9 invisible), 2,380 guests, and 29 spiders.
Topics290,581
Posts4,988,826
Members68,418
Most Online2,967
Mar 10th, 2019
Honda self propel only spining left wheel #5085890
04/25/19 11:38 AM
04/25/19 11:38 AM
MN
Tundragod Online content OP
Tundragod  Online Content OP
MN
I googled and didn't find anything. When I engage the self propel lever the left wheel spin and drives the mower forward. The mower pull to the right a little because the right wheel is not engage. I tried to go up hill but couldn't. I had no problem going up hill last year. I'm stumped. When I turn one of the wheels manually, the other engaged.
12 Highlander limited, 08 Accord EXL 4, 04 MDX Tour, 02 CRV EX, 1995 Virago.
Re: Honda self propel only spining left wheel [Re: Tundragod] #5085934
04/25/19 12:33 PM
04/25/19 12:33 PM
NE,Ohio
Rand Offline
Rand  Offline
NE,Ohio
What kind of wheels are they, on some non-hondas the wheels have teeth on the inside that strip out.. try taking one off and looking at it.
disclaimer: not familiar with honda OPE.
Re: Honda self propel only spining left wheel [Re: Tundragod] #5085998
04/25/19 02:14 PM
04/25/19 02:14 PM
Chicago, IL
EdwardC Offline
EdwardC  Offline
Chicago, IL
Do you have a model number for the mower?
Re: Honda self propel only spining left wheel [Re: Tundragod] #5086017
04/25/19 02:28 PM
04/25/19 02:28 PM
Jupiter, Florida
Cujet Online content
Cujet  Online Content
Jupiter, Florida
Does it have a differential? If so, that could explain it.
Re: Honda self propel only spining left wheel [Re: Tundragod] #5086020
04/25/19 02:32 PM
04/25/19 02:32 PM
Buffalo, NY
JTK Offline
JTK  Offline
Buffalo, NY
On my older Honda and the ones I've worked on, there's a spur gear at the ends of the rear axle that drive the ring gears that are molded into the rear wheels. A key could have sheared on the spur gear, or that gear isn't meshing with the ring gear?
Need to pull the rear wheels off to investigate. The system is simple to work on. Some wrenches and a pair of snap ring pliers is basically all you need.
2017 Ram 1500 4x4, 3.6L. 2016 Nissan Quest SV (Babe magnet IV)
Re: Honda self propel only spining left wheel [Re: Tundragod] #5086097
04/25/19 03:53 PM
04/25/19 03:53 PM
MN
MN
From my eyes, to my brain, somehow it didn't transfer to my fingers. I thought I entered the model number. Anyhow, its HRR2169VKA. Same as this one but 4 years older. https://www.homedepot.com/p/Honda-2...ower-with-Auto-Choke-HRR216VKA/308769340
Last year, I took out the wheels and cleaned the half-moon, spline thingy because the wheels wouldn't turn when going backward. I'll take it apart and clean it again this weekend since it'll be snowing anyway.
Re: Honda self propel only spining left wheel [Re: Tundragod] #5086108
04/25/19 04:05 PM
04/25/19 04:05 PM
Slovenia EU
Kamele0N Offline
Kamele0N  Offline
Slovenia EU
You need either new wheel(s) or a new gearbox/differential...or even both...
Speaking for other brands (Stiga, Al-ko, Snapper)
Wheel (the one with a gears inside) is between 50-100euro (it depends on wich price range for a mower are we talking)...gearboxes are between 100-150euros...
2008 Toyota Yaris 1ND-TV 1.4 D4-D Elf FullTech FE 5w30
1997 Toyota Landcruiser KZJ95 3.0 TD Shell Rimula R6M 10w40
Re: Honda self propel only spining left wheel [Re: Tundragod] #5086169
04/25/19 05:16 PM
04/25/19 05:16 PM
San Antonio, TX
das_peikko Offline
das_peikko  Offline
San Antonio, TX
Are you sure it's not HRR216K9-VKAA ?
Because that's a lot easier to find on the internet.
https://peparts.honda.com/powerequipment#/browse/lm/hrr/hrr216/HRR216K9-VKAA
Re: Honda self propel only spining left wheel [Re: Tundragod] #5086425
04/25/19 08:26 PM
04/25/19 08:26 PM
USA
mk378 Online content
mk378  Online Content
USA
There's also a one way clutch between the shaft and the small gear. This lets the outside wheel spin forward rapidly when you make a 180 turn at the end of a row. If the clutch fails that wheel won't ever get power.
Re: Honda self propel only spining left wheel [Re: Tundragod] #5086783
04/26/19 07:50 AM
04/26/19 07:50 AM
NC
BigD1 Offline
BigD1  Offline
NC
Yup mine does that every now and then. Did you get the spring installed? It can jump out, and never be seen again. The spring and spring hole need to be de-greased and then greased along with the other parts at the wheel.
I had to adjust the drive cable on mine the other week. That's the second time I have had to adjust it over the years. There is a drive cable check test, and then instructions on how to adjust the cable in the manual.
1992 Toyota Pickup--Quaker State Advanced Durability 10W-30--Motorcraft 910S
Re: Honda self propel only spining left wheel [Re: mk378] #5088308
04/27/19 02:26 PM
04/27/19 02:26 PM
Buffalo, NY
JTK Offline
JTK  Offline
Buffalo, NY
^ This and you should hear a "click-click-click..." from each wheel when freewheeling indicating these dog clutches (or what ever you want to call them) are functioning.
The other issue with Honda self propelled mowers is the axle bushings.. and I may sound like broken record on those, but those will loose their lubricity and begin to bind up on you at some point. The problem is you cant tell unless you hear squeaking or the transaxle cooks from the stress of not being able to turn the drive axle easily. The bushings have to be removed and replaced, or you can get away with a good clean and re-grease of them for a few years. They are those sintered (sp?) bushings with lube built into them.
