original '05 Chrysler trans pan gasket material ?
by visitor - 07/03/20 06:16 PM
rock auto can't ship to Calif????
by 928 - 07/03/20 06:04 PM
2001 Silverado 1500 T-Case Fluid
by Blang - 07/03/20 05:53 PM
Nasty Car wreck
by ford46guy - 07/03/20 05:53 PM
Best style of condenser?
by ddeflyer - 07/03/20 05:17 PM
Advance Auto now selling Die Hard Batteries
by Kira - 07/03/20 05:01 PM
Ontario Nuclear update - Part 2
by OVERKILL - 07/03/20 04:36 PM
Is this totaled?
by NoNameJoe - 07/03/20 04:23 PM
Burned and boycotting!
by sloinker - 07/03/20 04:23 PM
TGDI, Early OCI and Fuel Dilution
by Gene K - 07/03/20 03:49 PM
Toyota Genuine Motor Oil - old -vs new (latest)
by Ed_Flecko - 07/03/20 03:21 PM
Not trusting orbital buffer -- dilemma ???
by BAJA_05 - 07/03/20 02:44 PM
"New" Raw Water Pump From Amazon
by wings&wheels - 07/03/20 12:39 PM
Best refried beans?
by aquariuscsm - 07/03/20 12:16 PM
Northern hot cold pressure washer - clogged
by Donald - 07/03/20 10:48 AM
Porsche Transaxle Fluid Label
by wings&wheels - 07/03/20 08:52 AM
Ford 7.3 Godzilla Engine
by Snagglefoot - 07/03/20 08:43 AM
MrMoneyMcLube, JeffAR, ThaKid22, Speedeuphoria, 400rwkw
71842 Registered Users
94 registered members (2strokeNorthstar, bbhero, 55hambone, 928, aquariuscsm, ammolab, 9 invisible), 1,952 guests, and 21 spiders.
Topics307,380
Posts5,310,075
Members71,842
Honda self propel only spining left wheel #5085890 04/25/19 11:38 AM
T
Tundragod Offline OP
T
I googled and didn't find anything. When I engage the self propel lever the left wheel spin and drives the mower forward. The mower pull to the right a little because the right wheel is not engage. I tried to go up hill but couldn't. I had no problem going up hill last year. I'm stumped. When I turn one of the wheels manually, the other engaged.
12 Highlander limited, 08 Accord EXL 4, 04 MDX Tour, 02 CRV EX, 1995 Virago.
Re: Honda self propel only spining left wheel [Re: Tundragod] #5085934 04/25/19 12:33 PM
R
Rand Online Content
Online Content
R
What kind of wheels are they, on some non-hondas the wheels have teeth on the inside that strip out.. try taking one off and looking at it.
disclaimer: not familiar with honda OPE.
Re: Honda self propel only spining left wheel [Re: Tundragod] #5085998 04/25/19 02:14 PM
E
EdwardC Offline
E
Do you have a model number for the mower?
Re: Honda self propel only spining left wheel [Re: Tundragod] #5086017 04/25/19 02:28 PM
Cujet Offline
Does it have a differential? If so, that could explain it.
Re: Honda self propel only spining left wheel [Re: Tundragod] #5086020 04/25/19 02:32 PM
J
JTK Offline
J
On my older Honda and the ones I've worked on, there's a spur gear at the ends of the rear axle that drive the ring gears that are molded into the rear wheels. A key could have sheared on the spur gear, or that gear isn't meshing with the ring gear?
Need to pull the rear wheels off to investigate. The system is simple to work on. Some wrenches and a pair of snap ring pliers is basically all you need.
2019 Nissan Pathfinder SV
2017 Ram 1500 4x4, 3.6L.
2015 Nissan Versa 1.6 S
Re: Honda self propel only spining left wheel [Re: Tundragod] #5086097 04/25/19 03:53 PM
T
T
From my eyes, to my brain, somehow it didn't transfer to my fingers. I thought I entered the model number. Anyhow, its HRR2169VKA. Same as this one but 4 years older. https://www.homedepot.com/p/Honda-2...ower-with-Auto-Choke-HRR216VKA/308769340
Last year, I took out the wheels and cleaned the half-moon, spline thingy because the wheels wouldn't turn when going backward. I'll take it apart and clean it again this weekend since it'll be snowing anyway.
Re: Honda self propel only spining left wheel [Re: Tundragod] #5086108 04/25/19 04:05 PM
K
Kamele0N Offline
K
You need either new wheel(s) or a new gearbox/differential...or even both...
Speaking for other brands (Stiga, Al-ko, Snapper)
Wheel (the one with a gears inside) is between 50-100euro (it depends on wich price range for a mower are we talking)...gearboxes are between 100-150euros...
2008 Toyota Yaris 1ND-TV 1.4 D4-D Tech9 (Shell?) 5W30 C3 VW 504/507
1997 Toyota Landcruiser KZJ95 3.0 TD Shell Rimula R6M 10W-40
Re: Honda self propel only spining left wheel [Re: Tundragod] #5086169 04/25/19 05:16 PM
das_peikko Offline
Are you sure it's not HRR216K9-VKAA ?
Because that's a lot easier to find on the internet.
https://peparts.honda.com/powerequipment#/browse/lm/hrr/hrr216/HRR216K9-VKAA
Re: Honda self propel only spining left wheel [Re: Tundragod] #5086425 04/25/19 08:26 PM
M
mk378 Offline
M
There's also a one way clutch between the shaft and the small gear. This lets the outside wheel spin forward rapidly when you make a 180 turn at the end of a row. If the clutch fails that wheel won't ever get power.
Re: Honda self propel only spining left wheel [Re: Tundragod] #5086783 04/26/19 07:50 AM
B
BigD1 Offline
B
Yup mine does that every now and then. Did you get the spring installed? It can jump out, and never be seen again. The spring and spring hole need to be de-greased and then greased along with the other parts at the wheel.
I had to adjust the drive cable on mine the other week. That's the second time I have had to adjust it over the years. There is a drive cable check test, and then instructions on how to adjust the cable in the manual.
1992 Toyota Pickup--SuperTech 10W-30 conventional--Fram PH3614
Re: Honda self propel only spining left wheel [Re: mk378] #5088308 04/27/19 02:26 PM
J
JTK Offline
J
^ This and you should hear a "click-click-click..." from each wheel when freewheeling indicating these dog clutches (or what ever you want to call them) are functioning.
The other issue with Honda self propelled mowers is the axle bushings.. and I may sound like broken record on those, but those will loose their lubricity and begin to bind up on you at some point. The problem is you cant tell unless you hear squeaking or the transaxle cooks from the stress of not being able to turn the drive axle easily. The bushings have to be removed and replaced, or you can get away with a good clean and re-grease of them for a few years. They are those sintered (sp?) bushings with lube built into them.
