Do you use gas brand exclusively ?
by MetalSlug - 09/17/19 04:58 AM
Mobil 15w30
by Chadders99 - 09/17/19 02:20 AM
2018 VW Atlas 3.6 4 Motion Reliability?
by GZRider - 09/16/19 11:48 PM
Account and posts removal
by newbe46 - 09/16/19 10:00 PM
Yamaha EF2800i break-in
by Uregina09 - 09/16/19 09:43 PM
Adding TCW3 to Gas Tank?
by maverickfhs - 09/16/19 08:45 PM
Motul 75w90 1L 12 pack $13.25
by wkcars - 09/16/19 08:36 PM
2019 Ford Fusion vs used?
by FL-400S - 09/16/19 08:33 PM
What is the reasoning for 2-fuel tanks on a rv?
by RazorsEdge - 09/16/19 07:54 PM
Thoughts and opinions on family haulers
by ram_man - 09/16/19 07:53 PM
2018 Silverado 5.3L M1 AFE 0W-20 5,065
by K20FA5 - 09/16/19 07:43 PM
18 Jeep 3.6 PPU 0w20 5k OCI
by IndyFan - 09/16/19 07:06 PM
Federal 9mm 115g FMJ Brass - $7.97/50 @ Walmart
by blupupher - 09/16/19 06:47 PM
Motorcraft FL-1995W different than than non-W?
by Cubey - 09/16/19 05:31 PM
1973 Bronco w/original 302
by BKinSD - 09/16/19 05:18 PM
B&S 21hp burning oil
by Mike141 - 09/16/19 04:28 PM
Prime Guard POF2222 C&P...
by AnthemBassMan - 09/16/19 03:36 PM
R0CKETMAN, Southbend9, Bigaledge32, emilio15, Kokopelli34179
69303 Registered Users
76 registered members (Astro_Guy, ArrestMeRedZ, 2010Civic, 2015_PSD, Bighorn2500, 4WD, 5 invisible), 984 guests, and 21 spiders.
Topics294,672
Posts5,064,258
Members69,303
Most Online3,532
Jul 30th, 2019
servicing a 2018 GM 6speed transmission #5085800 04/25/19 10:23 AM
gotnogunk Offline OP
I just bought a new to me 2018 Cadillac XTS with 3.6 and 6-speed transmission. Most say you can only drain around 3 Qts from the plug. I really haven't checked it out so looking for advice on preventive maintenance. present mileage is 29,000.
2018 Cadillac XTS 3.6
2014 Ford F150 3.7 supercrew
Re: servicing a 2018 GM 6speed transmission [Re: gotnogunk] #5085807 04/25/19 10:35 AM
J
Jimzz Offline
J
Same setup as the Impala and may other FWD 3.6/6-speed vehicles. I was able to get about 4 last time I did one.
I would do a drain/fill every 30-35k on those. I used Maxlife and it works well, that and only $18 gallon at walmart.
yup
Re: servicing a 2018 GM 6speed transmission [Re: gotnogunk] #5085808 04/25/19 10:36 AM
Dave Sherman Offline
Wife's 6-speed Equinox and my former Traverse would give up about 3.5 quarts. Wife's car doesn't have the dipstick and just the fill plug on the side. You'll need to have the engine running to fill it properly, you'll only get about 2 quarts in before it overflows if you don't.
2015 Honda Pilot EX AWD Valvoline 0W-20 Bosch filter
1977 MG Midget Valvoline VR-1 20W-50 Bosch Filter
Re: servicing a 2018 GM 6speed transmission [Re: gotnogunk] #5085848 04/25/19 11:06 AM
slacktide_bitog Offline
That 3 quarts will be enough.
Do a drain and fill every 60k or so and you will be fine. Of course, you can always do it more often if you wish since the drain plug makes it so easy smile
Re: servicing a 2018 GM 6speed transmission [Re: gotnogunk] #5085943 04/25/19 12:52 PM
Snagglefoot Offline
Mine has a 6 speed 6L90. I was able to pull only 3-1/2 quarts out through the fill tube with a vacuum-based transfer pump. Surprisingly, the transmission only holds 6-1/2 quarts according to the owners manual.
If you want the job done right......do it yourself.
Re: servicing a 2018 GM 6speed transmission [Re: gotnogunk] #5085949 04/25/19 01:08 PM
M
metroplex Offline
M
Is this the 6-speed front wheel drive transmission (6Txx)? My Fords have the 6F55 (which is probably GM's GT80) and the drain plug drops out 4-4.5 quarts of Mercon LV / Dexron VI. This is the largest version of the joint-venture transaxle though.
Re: servicing a 2018 GM 6speed transmission [Re: metroplex] #5085963 04/25/19 01:35 PM
W
Whimsey Offline
W
I have the smaller 6F35 in our Explorer which I believe was also part of the joint GM-Ford joint venture design. Every time I do a drain and fill it's 4 quarts out always. But I do it cold after it sat over night. It's ridiculously easy to do cold drain and fills with this transmission as there is no pan, just a drain plug in the bottom of the casing. I fill it through the vent tube in the engine bay with the 4 quarts cold. The transmission hold 9 quarts total according to the owners manual.
Whimsey
Re: servicing a 2018 GM 6speed transmission [Re: gotnogunk] #5086327 04/25/19 07:08 PM
Thanks to all, like most of us I will probably service early, and often. We do love our lube.
Re: servicing a 2018 GM 6speed transmission [Re: gotnogunk] #5086403 04/25/19 08:14 PM
dave1251 Offline
After you get the break in oils out there is no need to do frequent changes DEXRON VI is a very good fluid.
don't use.
Re: servicing a 2018 GM 6speed transmission [Re: gotnogunk] #5086832 04/26/19 08:32 AM
R
repairman54 Offline
R
If you have AWD don't forget to service the transfer case. Fluid change on that is really simple also and regular fluid changes there will keep it alive for a very long time. I service my 16 NOX 3.6 buy the severe Duty maintenance schedule as I like to run my vehicles to at least 200k
John
Anything you say can & will be misquoted & used against you
'16 Equinox 3.6 AWD
'11 Tahoe LTZ
'09 2.4 Malibu
FLHR
Doo 1200 GSX
Sea Doo GSX
