Thanks for all the responses so far; now to answer questions:
Originally Posted by Garak
Now, I can't speak for what's going on with your warranty, or how picky Toyota can be, or how picky you are. Outside of warranty concerns, any 5w-40 HDEO that is either CK-4/SN or CJ-4/SM or lacks the S spec and is E7, E9 will work fine. If you're concerned about phosphorus, find something with an E6 in it. That would probably be a 5w-30 HDEO, which will have an HTHS closer to 3.5. As you may be aware, I ran Delvac 1 ESP 5w-40 in my G37 for an extended period of time (the spec was for a 5w-30 in SM or newer with ILSAC optional) and am still running an HDEO.
I would gather you're considering one of the Amsoil options, and I would have no reservations about that over and above any other HDEO.
Not concerned about warranty [list of reasons here]; I agree that Amsoil's offerings are very good, but between my change in driving habits from more than 20,000 miles per year to 12,000 - 15,000 miles/year and their price increases, they've priced themselves past where I'm seeing the value in the SS...and I can get Schaeffer 9000 for less than the XL so that's the 5w-40 I'm considering. I made a mistake earlier, actual HTHS is 4.05.
Originally Posted by Linctex
Pep Boys clearanced out some Chevron Delo 5W-40 Synthetic HDEO, and I think I got 6-7 gallon jugs.
It works great in everything in pour it into. I ran it for 17,000 miles last year in my 4.6 liter Ford with a Fram Tough Guard
I'm curious also, if this was one long OCI or if there was a change in there...and how much make up oil was added?
Originally Posted by Donald
Originally Posted by JLTD
So in reading the overseas manual for my 4Runner, I see that up to 15w-40 is specified (albeit with a lower temperature limit). I am considering running a 5w-40 with HTHS 4.1. I know there will be a slight hit on mpg, and right now this is a rhetorical question since I'm not due for fresh oil until September.
Wanted to pick the collective brains here for opinions, fact and speculation, so thanks in advance--
Is it SN rated?
Not specifically since it's a diesel oil, but it exceeds CK-4, which to my understanding matches SN.
Originally Posted by tig1
What benefit are you looking for?
As stated, right now it's a rhetorical question; but to give an answer, I'd like to maximize engine life. I'll likely end up running 5w-30 or maybe even a -20, but am interested in testing the waters and running each oil to see how they do.
Originally Posted by rideahorse
08 Ford Edge with the 3.5. Its had 15w-40 HDEO in it since new. 226,000 miles. Runs like new. This is in Iowa.
Me, too...winter? Is it garaged or have a pan heater, or just started right up when it's cold?
