OK, cross your fingers and hold your breath. Here goes...
Rotella T6 supplemented with Redline oil additive.
From Polaris:
Truck Odometer: 536374 mi
Miles on oil: 34000
11 quarts of makeup oil added.
Fleetguard LF16035 filter.
Polaris Comments:
Flagged data does not indicate an immediate need for maintenance action. Continue to observe the trend and monitor
equipment and fluid conditions. Chrome is at a MINOR LEVEL and is possibly coming from piston ring plating.
Iron is low. Other wear metals are really boring, TBN is still strong, negligible soot loading, no water, no fuel dilution.
Engine still dripping or consuming about a quart per 3000 miles.
Really pleased with the low soot and fuel dilution because the engine had a lot of idle time on cold overnight stays.
Added another parameter to the spreadsheet to show uncorrected Iron wear rate.
From Polaris:
Miles on oil: 34000
Polaris Comments:
