Tires for my 2007 Dodge Grand Caravan
by diyjake - 11/21/19 10:26 AM
Fair price for a brake job?
by Ddub - 11/21/19 10:09 AM
Anyone backing up their data online?
by gonefishing - 11/21/19 09:52 AM
Fram Ultra C&P
by mpgo4th - 11/21/19 09:19 AM
2001 Nissan Sentra / trans issue?
by Mark72 - 11/21/19 09:10 AM
CVT Maintenance for CVT Dummies
by Brons2 - 11/21/19 09:00 AM
Wix/ Napa best oil Filters
by edward51956 - 11/21/19 08:54 AM
Mahle OC84, 1974 BMW 2002
by wings&wheels - 11/21/19 08:48 AM
Oil is staying clean on Kubota L3560!
by Rglossip - 11/21/19 08:41 AM
7317 or 6607?
by cwilliamsws6 - 11/21/19 08:00 AM
Dana S110 Lube change
by Parkman - 11/21/19 07:21 AM
2003 GMC Sierra 1500HD 6.0L
by Redright9 - 11/21/19 07:17 AM
Canadian Tire Early Black Friday
by Snagglefoot - 11/21/19 07:07 AM
Viscosity at 85°C vs 100°C
by doyall - 11/21/19 06:58 AM
New tires for 1988 Toyota Pickup 4x4 22re
by Yota88 - 11/21/19 04:18 AM
Jeep Cherokee Rumble
by Nick1994 - 11/20/19 11:48 PM
Andrewm72, FarmGuy, ImBoosted, XpressAuto, Jmpage388
69926 Registered Users
95 registered members (77GrandPrix, 1WildPig, 28oz, 379KITTY, 2015_PSD, 8 invisible), 1,957 guests, and 25 spiders.
Topics297,722
Posts5,121,287
Members69,926
Most Online3,589
Nov 2nd, 2019
Alignment problem - help me understand #5084675 04/24/19 10:15 AM
SlavaB Offline OP
Hey folks, I hoped I can get some input from you on a weird issue I'm experiencing.
I've changed tires on my 17 Sportage recently, when arrived for a rotation/balancing was informed my alignment is bad, there was a side wear as well as tires thread was at 4 mm.
I kinda new it already so asked them what did they have in stock.
My OE size is 225/55/18 and the shop had only 235/55/18 in stock, they claimed it's not a big deal so I got that installed.
After the installation, I did feel that my car is leaning to the right a bit, I concluded for myself that it makes sense since the alignment still needs to be performed.
Yesterday I went into a local shop to get an alignment, and after they've performed it - the car is still leaning right.
I came back and was presented the pictures of the computer monitor they use to do alignments.
It looks perfect on those pictures, except for the fact the left bottom corner says 13 Sportage, while mine is 17 Sportage. I pushed that argument and it went nowhere - they keep saying
they know what they're doing and the alignment is perfect, ignore the "13 Sportage" text.
Any idea of where should I go from here?
I have 3 concerns here and please help me understanding if they make sense:
1. Tires are a bit bigger
2. Alignment was performed wrong (using "13 sportage" alignment runbook or whatever it's called)
3. Maybe the balancing wasn't performed properly
Will appreciate any input
17 Kia Sportage EX 2.4 GDI / PYB 5w20, OF4459-MO9688
15 MB GLA250 4Matic 2.0T / Mercedes OEM 5w40, OEM filter
Re: Alignment problem - help me understand [Re: SlavaB] #5084677 04/24/19 10:16 AM
SlavaB Offline OP
If I'm not mistaken, these are before the alignment pictures
Re: Alignment problem - help me understand [Re: SlavaB] #5084682 04/24/19 10:21 AM
E
Eddie Offline
E
I would not have put on a larger size tire because, it will decrease the performance and the speedometer will be incorrect. I would get the correct size tire for your vehicle and then get a proper alignment elsewhere. . I think the person doing the alignment did a very poor alignment.
2014 CX5 Touring 2.5L :-)
Re: Alignment problem - help me understand [Re: SlavaB] #5084723 04/24/19 11:08 AM
Q
Quest Offline
Q
If they use 2013 Kia Sportage spec to align 2017 Kia, that's wrong.
This could be the reason why your caster is off.
Assuming your last pic is the "after" pic, then your camber and toe-in are ok.
How much do you weigh? If you weigh too much, and assuming your camber is off (before), steering will pull....
2c's worth.
Q.
"Internet discussion boards act as echo chambers for conspiracy dittoheads" A.Allen
Re: Alignment problem - help me understand [Re: Eddie] #5084724 04/24/19 11:09 AM
G
geeman789 Offline
G
Originally Posted by Eddie
I would not have put on a larger size tire because, it will decrease the performance and the speedometer will be incorrect ...
The tire size is fine ... the 235 is less than 1/2 an inch taller in diameter, and only 10 mm wider. The speedometer will read about 1 mph slow, showing 59 mph at a true speed of 60 mph, and because factory speedometers nearly always read higher than true speed, may in fact make the speedometer MORE accurate.
Any performance decrease will be too small to notice ...
As far as alignment goes, a 13 Sportage is going to have the same basic alignment specs as a 17. The only adjustable specs are usually toe and camber ... toe is usually zero , camber will be zero to slightly negative for the front, and slightly more negative in the rear. Caster is not usually adjustable ... and the caster may be the one spec that might be different for a 13 vs 17.
Looks fine ... but if you think it was done wrong, try a different shop ...
2011 SUBARU Impreza 5-door manual / 2016 HONDA Pilot / 2011 MAZDA 2 auto
Re: Alignment problem - help me understand [Re: SlavaB] #5084741 04/24/19 11:27 AM
M
MParr Offline
M
Oh man! Where should I start? I’m afraid that you have been taken. Remedy? Make sure all of the tires are the same size, same brand and have the same air pressure (35psi). Now, take it to the KIA dealership and get a proper alignment. Finally, DO NOT USE THAT TIRE DEALER AGAIN. DON’T EVEN GO BACK FOR A ROTATION. This wasn’t a Firestone store, was it? It sure sounds like one.
2019 VW Tiguan SE Now: Mobil 1 ESP 5W30 & OE VW/Mann
2017 Ford Escape SE 2.0T Now: Motorcraft 5W30 SynBlend & NAPA Gold 1348
Re: Alignment problem - help me understand [Re: SlavaB] #5084749 04/24/19 11:35 AM
M
mk378 Offline
M
Check the pressure in all four tires.
Re: Alignment problem - help me understand [Re: SlavaB] #5084768 04/24/19 11:54 AM
B
benjy Offline
B
if you go to the stealers be sure they use vaseline before you get the bill!
Re: Alignment problem - help me understand [Re: MParr] #5084794 04/24/19 12:37 PM
G
geeman789 Offline
G
Originally Posted by MParr
Now, take it to the KIA dealership and get a proper alignment ...
At most auto dealerships, you will have a flat rate tech working as FAST as he can ... usually giving you a GOOD ENOUGH alignment ... at a premium price.
How is that better ?
Re: Alignment problem - help me understand [Re: geeman789] #5084796 04/24/19 12:38 PM
The Critic Offline
Most A/B techs are paid on flat-rate - dealer or independent.
2011 Toyota Prius 1.8L - 199K - Pennzoil Platinum 0W-20
2007 Honda Accord 2.4L - 140K - Valvoline Premium Blue Restore 10W-30
Re: Alignment problem - help me understand [Re: SlavaB] #5084798 04/24/19 12:41 PM
Dave1027 Offline
Maybe. Sometimes going up a size like that is beneficial. It was for my Toyota pickup. It actually reduced most of the existing speedometer error and rides better too.
Also, to add, the program this shop is using is terrible. It looks like a child's toy and what's with all those question marks? I wouldn't trust them to do a good alignment. Go elsewhere.
Re: Alignment problem - help me understand [Re: SlavaB] #5084849 04/24/19 01:35 PM
Ded Mazai Online Content
Online Content
I would expect all the readings to be in the green area. Why are they not?
Re: Alignment problem - help me understand [Re: SlavaB] #5084857 04/24/19 01:40 PM
SlavaB Offline OP
Thx everyone for answers, I'll go to the local dealer instead who charges around $90 for the alignment.
Will see how it goes
Re: Alignment problem - help me understand [Re: SlavaB] #5084883 04/24/19 02:07 PM
M
MParr Offline
M
SlavaB
Once you get this straightened out, you will not need to have an alignment done unless you hit something or have some suspension components replaced. When I say suspension components, I’m talking about tie rod ends and ball joints. Don’t let a tire shop sell you an alignment when you buy new tires or have them rotated. It’s a gimmick they all use and most times they mess things up. I can’t remember when the last time I had an alignment done on my cars.
Re: Alignment problem - help me understand [Re: SlavaB] #5084958 04/24/19 03:15 PM
P
PandaBear Offline
P
225 and 235 are not noticeably different, I run 245 instead of 255 all the time too. Also tire change should not affect alignment either.
What you have seen is likely their machine out of calibration, or the guy didn't do it right, etc. Bring it to another shop to align and then bring the receipt back to ask for a refund (if they are different or if the new alignment shop fixed it).
"You keep asking questions PandaBear and you'll end up a vegetarian like my wife" - Camu Mahubah
