Pulled the radiator out, but the connector on the coolant sensor gave me grief. Like the noob I am I grabbed it with a pair of pliers, just to wiggle it, as the latch was loose but it simply would not pull off--and of course the pliers slipped. And of course I sliced the wire right at the connector. I think the sensor might have leaked coolant into the connector, as the contacts are all black now, but the wire still looks clean (the one that I chopped).
Anyhow.
I'm not seeing what this harness is called, nor where to get one, nor how to repair (surely there is a way to pull the pin).
[I removed the seal in the last photo.]
Anyhow.
