belt squeaking suddenly
by dogememe - 02/24/20 11:45 PM
Is Mobil 1 advanced synthetic a full synthetic?
by apollo18 - 02/24/20 11:08 PM
what stocks to buy?
by daves66nova - 02/24/20 08:55 PM
I thought Windows 7 would be insecure now?
by atikovi - 02/24/20 08:48 PM
When to replace struts
by ram_man - 02/24/20 08:40 PM
Fluid Film + Cayenne Pepper
by pitzel - 02/24/20 05:22 PM
Ford Focus RS Oil Advice!
by fastsvo - 02/24/20 04:23 PM
Cleanest wheels on same axle or same side of car?
by atikovi - 02/24/20 04:13 PM
Mixing 2 stroke oils
by Hirev - 02/24/20 03:57 PM
Insa Turbo Ecosaver Plus
by faramir9 - 02/24/20 03:45 PM
Repair Rusted Rocker Panels Without Welding
by Fitz98 - 02/24/20 03:33 PM
Stalwart tools
by P10crew - 02/24/20 03:32 PM
VOA Eneos Racing Street 0w-50
by zip15 - 02/24/20 03:09 PM
What is your favorite Candy Bar?
by ZZman - 02/24/20 02:27 PM
Help me understand
by 1978elcamino - 02/24/20 02:25 PM
2019 VW Passat Trip Mileage
by Boomer - 02/24/20 01:13 PM
Changed my ATF, difference is crazy!
by cwilliamsws6 - 02/24/20 12:36 PM
Specs on Conventional Oils 4 Comparing
by Perseus - 02/24/20 12:32 PM
EarlT500, Newbie111, Boris_Be, NHR, zip15
70798 Registered Users
29 registered members (carviewsonic, Dave_Mark, Bogdon, Bailes1992, CATERHAM, AnthemBassMan, 1 invisible), 1,257 guests, and 21 spiders.
Topics301,894
Posts5,204,872
Members70,798
Page 3 of 3 1 2 3
Re: Best Mercon LV replacement fluid [Re: slacktide_bitog] #5082807 04/22/19 01:23 PM
H
hallstevenson Offline
H
Originally Posted by slacktide_bitog
no-no
That is NOT the same thing as officially licensed!
On a model-specific forum I asked about using Castrol ATF since it's officially licensed, approved, etc by Ford. The Amsoil-fanboys had to chime in to plug Amsoil ATF. I reiterated that Castrol is approved by Ford and Amsoil isn't. They referred me to the "right" product, presuming I was looking at the wrong ATF and said it's "listed under the AMSOIL Signature Series". Another followed-up with a screenshot. They are both equating that "Amsoil says it's okay", i.e. "recommend for" with "Licensed and approved for use in: All Ford vehicles requiring MERCON LV"
Re: Best Mercon LV replacement fluid [Re: slacktide_bitog] #5084355 04/24/19 02:30 AM
F
Fifty150 Offline
F
Castrol is licensed Mercon LV. Maxlife is not smile
[Linked Image]
Hot Tranny Fluid
no-no
While I agree it is more than ok to use where LV is required, it doesn't carry formal approval from Ford. Some people find this important when the car is still under warranty.
Amsoil, Lucas Oil, RedLine, Royal Purple.........none of those are licensed.
None of the multi-vehicle ATF used by nationwide lube shop chains are "officially licensed".
Some will point out the obvious. Officially licensed products meet OEM spec.
Others will point out that the licensing is just a scam to try to squeeze money out of other brands.
I see that Dexos spec oil is called for with certain cars......and none of those cars have blown up from an unlicensed product. I've used dozens of gallons of ATF in Ford transmissions, which did not have Mercon V license. Boutique brands which allegedly meet and/or exceed Mercon V spec. Since I'm not a "fan-boy" of any of those boutique brands, I'll let someone else vouch for them. But none of that ATF was off-brand product from a questionable discount retailer.
Everybody should do their own research, and decide what they want to do with their own car. My only conclusion, for my own circumstance, is that using those boutique brands of automotive fluid was jjust a waste of money. Sure, they worked just as well without being "officially licensed". But they did nothing special, offered no advantage, and my cars would have ran fine with OEM spec product at a much lower price point........Okay! I'll say it. I could have used SuperTech from Wally*World, and it would not have made a difference!
Re: Best Mercon LV replacement fluid [Re: kstanf150] #5084449 04/24/19 06:08 AM
Diesel12 Offline
Another to add to the list 205A Dexron® VI/Mercon® Automatic Transmission Fluid
https://www.schaefferoil.com/205-atf-fluid.html
1998 Dodge Neon-Rebuilt 2.4L-Schaeffer 10w-30
2014 Dodge Durango 3.6, 66K- Schaeffer 10w-30
2002 Ram 2500 Cummins 125K- Schaeffer 5w-40
2008 Dodge Avenger 232K Schaeffer 10w-30
Re: Best Mercon LV replacement fluid [Re: Diesel12] #5084498 04/24/19 07:01 AM
K
kschachn Offline
K
Which of course also is neither dexron nor Mercon licensed, just like the rest in this thread.
1994 BMW 530i, 252K
1996 Honda Accord, 288K
1999 Toyota Sienna, 434K
2000 Toyota ECHO, 284K
Re: Best Mercon LV replacement fluid [Re: kschachn] #5084519 04/24/19 07:26 AM
Diesel12 Offline
While you are correct the OP never asked for a "Licensed" fluid but options, so i chimed in. Approvals arent deciding factors for some people.
Re: Best Mercon LV replacement fluid [Re: Diesel12] #5084533 04/24/19 07:49 AM
K
kschachn Offline
K
Actually reading through the thread the OP did seem interested in actual licensed fluid. My point is that the way your post is worded:
makes it seem as though it is. Although if you know better you can tell from the way it is written that it is not.
1994 BMW 530i, 252K
Re: Best Mercon LV replacement fluid [Re: kstanf150] #5089417 04/28/19 11:42 AM
K
kstanf150 Offline OP
K
Ford MERCON® LV Approval (License Nos. MLV 140601, MLV 140602, MLV 140603)
Pennzoil license #
Re: Best Mercon LV replacement fluid [Re: pbm] #5092192 04/30/19 08:54 PM
F
Fifty150 Offline
F
Originally Posted by pbm
....Valvoline Maxlife is much more reasonable and many have said it works well in their Ford.
As of today, Valvoline MaxLife is $17.97 per gallon @ Wal*Mart. Wal*Mart's own SuperTech LV was $6.97 per quart. I bought the Valvoline because it is cheaper. Works fine. Nothing special about it. More importantly, no problems with it.....yet.
[Linked Image]
Re: Best Mercon LV replacement fluid [Re: Fifty150] #5092240 04/30/19 10:03 PM
dave1251 Offline
[Linked Image]
I have Maxlife in a Mercon LV application nothing bad to report.
don't use.
Page 3 of 3 1 2 3
