Oil recommendation for 2014 2.5l Suburu Forester
by tomartomau - 12/13/19 10:50 PM
General RT43 or Conti TrueContact Tour
by Propflux01 - 12/13/19 10:16 PM
Mobil 1 0W-40, 2820 Miles, 2000 Mercedes E55 AMG
by Fotoflame - 12/13/19 09:48 PM
Streaming question
by loneryder - 12/13/19 09:43 PM
Anyone use 75w-85 instead of 75w-90
by jqgz - 12/13/19 09:42 PM
Cooper Discoverer AT3 4S - Thumbs Up!
by Nick1994 - 12/13/19 09:24 PM
Vortex 6.0 water pump
by chilson450 - 12/13/19 08:51 PM
Transmission fluid dilemma, need advice
by Sumo91 - 12/13/19 08:49 PM
Should I replace the Sonata?
by Nick1994 - 12/13/19 08:20 PM
Best P185/65R15 on the market? (+Low RR)
by Vern_in_IL - 12/13/19 08:17 PM
15 focus oil choice
by gabriel9766 - 12/13/19 07:58 PM
Building Up a New Stash
by Mr_Luke - 12/13/19 07:19 PM
acdelco DEXOS2 made by
by jkhawaii - 12/13/19 06:54 PM
UOA Corvette Z06 LS7
by randomhero439 - 12/13/19 05:34 PM
CCA va Reserve Capacity
by Gebo - 12/13/19 04:51 PM
Key fob 3v
by Duffyjr - 12/13/19 04:47 PM
car fax Diy uploads
by WhyMe - 12/13/19 04:43 PM
Jeep 4.0 - 6400MI - 22k on XG8A(Fram Ultra) - Particle Count
by thescreensavers - 12/13/19 04:34 PM
Penrite base oils
by KiwiBiker - 12/13/19 04:31 PM
chadder1313, Sumo91, CleanSump, Phillip0web, puppykat33
70121 Registered Users
75 registered members (2strokeNorthstar, Astro14, AP9, addyguy, 8 invisible), 1,194 guests, and 23 spiders.
Topics298,784
Posts5,141,004
Members70,121
Most Online3,589
Nov 2nd, 2019
HVAC Tech Says to Block Off Crawl Space's Return Vent #5069375 04/09/19 01:25 PM
L
LoneRanger Offline OP
L
Conditioned crawl space, no foundation vents. One supply duct blows heat or cool into crawl space, open ended w/ no register grill. Approx. 6 - 8 ft from this single duct that supplies conditioned air to crawl space, there is a return opening that draws crawl space air into the system, intermixing it with return air from the living space above.
Yesterday, an HVAC technician recommended blocking off that crawl space return. Said when their company does new construction rough-ins they never put returns in conditioned crawl spaces, only supply registers, and if you *are* going to have a return in there that intermixes crawl space air with living space air then you should consider having a UV light treatment system installed on the return plenum (in a serviceable area, usually on return plenum near where it connects to furnace) as well as a dehumidifier installed in crawl space.
I tend to agree with this guy. I don't think the rough-in contractor back in 2003 when house was built should've put a return opening in the crawl space. I am going to take the advice of yesterday's technician (from company that installed the new Amana system in February) and block off the crawl space return vent. May also install dehumidifier in crawl space as well, could be plumbed into sump pump's drain pipe with relative ease.
'19 Ford F150 2.7 twin turbo GDI V6 .....(Motorcraft 5W30 SN+)
'19 GMC Terrain 1.5 turbo GDI I4...........(GM 0W20 dexos)
'16 Moto Guzzi 1151cc air cooled v-twin (Eni 10W60)
Re: HVAC Tech Says to Block Off Crawl Space's Return Vent [Re: LoneRanger] #5069407 04/09/19 01:52 PM
Donald Offline
Why even supply air from the HVAC into crawl space? Does it ever need heat? Dehumidifier is a good idea. As is a remove RH gauge in living area. They typically use expensive basement or crawl space dehumidifiers in crawl space. Aprilaire is a good brand.
I have home in DE. No freezing issues in crawl space. The home HVAC is not doing anything with the air in the crawl space. The dehumidifier is. Keep it 45 to 50 RH.
2015 Ford F250 w/Powerstroke
Re: HVAC Tech Says to Block Off Crawl Space's Return Vent [Re: LoneRanger] #5069440 04/09/19 02:23 PM
B
BMWTurboDzl Offline
B
There's nothing wrong with putting a return in a conditioned crawlspace. There's no need for a dedicated UV filter for the crawl either. If you want a UV filter have it installed near the filter for the furnace so that all of the return air is sanitized.
435i
Re: HVAC Tech Says to Block Off Crawl Space's Return Vent [Re: LoneRanger] #5069637 04/09/19 05:35 PM
F
Fitter30 Offline
F
What type of floor is in the crawl space?
Re: HVAC Tech Says to Block Off Crawl Space's Return Vent [Re: Fitter30] #5075886 04/15/19 02:27 PM
L
L
Plastic vapor barrier laid over pea gravel.
Re: HVAC Tech Says to Block Off Crawl Space's Return Vent [Re: LoneRanger] #5076021 04/15/19 04:32 PM
Donald Offline
If you want to really do the crawl space properly you need to redo the plastic sheeting with a proper vapor barrier for the floor and walls with everything taped and sealed. A lot of work. Not cheap to hire a pro. In my crawl space in my DE home the height is between crawling on my belly and crawling on my hands and knees.
Once done properly then a dehumidifier can easily bring down the RH to 45% to 50%.
Re: HVAC Tech Says to Block Off Crawl Space's Return Vent [Re: LoneRanger] #5076145 04/15/19 07:17 PM
Z
zzyzzx Offline
Z
No basement in Delaware?
Re: HVAC Tech Says to Block Off Crawl Space's Return Vent [Re: Donald] #5084070 04/23/19 05:57 PM
5
5AcresAndAFool Offline
5
And if you do all this you might as well have a basement. Here in our part of Indiana basements can be fairly rare, Many crawl spaces I have been in, which numbers at least 200, have had moisture issues and a shoddily installed vapor barrier with pea gravel on it. My favorite one had a sump pit in it which was in the higher part of the crawl so water ran away from it and it had no drain tiles running into it so it was effectively useless.
I have been in one that was completely sealed with a pool liner like material, it was clean, dry and conditioned. Once you factor in the expense of doing this plus the expense of conditioning it, I figure you might as well have a basement, even if just for storage.
In the heat of the summer most crawl spaces here have moisture condensing on almost everything it can. IMHO here it is just to cold and damp and hot and humid most of the time to have a crawl space vented to the outside and not expect moisture in there. It gets so ungodly humid here its ridiculous.
What aggravates me is the work is a lot easier and cheaper to do if its done right after the block is laid. but its seems like out of sight out of mind when they build these homes and someone 15 or 30 years later has to deal with the problems the poor preparation creates.
