5W40 oil is too thick for your F-150. Ford requirement is 5W20 Motorcraft blend. You can get by with 5W30.
FLUIDS AND CAPACITIES
Engine oil: SAE 5W-30 synthetic blend (2.7L, 3.5L), SAE 5W-30 diesel motor oil (3.0L diesel), 5W-20 synthetic blend (3.3L, 5.0L); capacity is 6.0 quarts (5.7 liters) - 2.7L, 3.3L, 3.5L; 6.5 quarts (6.15 liters) - 3.0L diesel; 8.8 quarts (8.3 liters) - 5.0L
Coolant: Motorcraft Orange; capacity is 15.1 quarts (14.3 liters) - 2.7L; 13.7 quarts (13.0 liters) - 3.0L diesel; 13.6 quarts (12.86 liters) - 3.3L; 15.2 quarts (14.35 liters) - 3.5L; 13.9 quarts (13.2 liters) - 5.0L
Brake fluid: DOT 4 LV High Performance Motor Vehicle Brake Fluid
Automatic transmission fluid: Mercon LV - 2.7L, 5.0L; Mercon ULV - 3.0L diesel, 3.3L, 3.5L; capacity is 13.1 quarts (12.4 liters)
Diesel exhaust fluid: Capacity is 22.5 quarts (21.3 liters)
Also, 87 octane gas containing 10% ethanol isn't that great. It may be okay for a 1987 Oldsmobile beater with 8.5:1 compression ratio.
