Oil recommendation for 2014 2.5l Suburu Forester
by tomartomau - 08/23/19 11:32 PM
Castrol 5W50
by Snagglefoot - 08/23/19 11:29 PM
Camry Broke Down
by Nick1994 - 08/23/19 10:51 PM
Pumpkin Beer
by Capt - 08/23/19 09:26 PM
Possible bad Iridium plug
by Eric Smith - 08/23/19 08:57 PM
Is the 5.7gm engine still made brand new?
by motor_oil_madman - 08/23/19 08:19 PM
Motomaster OEPlus MOPH/MOCH Filters
by gamefoo21 - 08/23/19 07:29 PM
Man's best friend!
by Mad_Hatter - 08/23/19 06:53 PM
2007 Ford Fusion Cam Pics
by tig1 - 08/23/19 05:31 PM
Cloning a Lexus key
by Nayov - 08/23/19 04:23 PM
2011 GMC Acadia Shock/Strut Replacement
by panthermike - 08/23/19 03:49 PM
Confusion on oil to use on BMW 328i 2010
by goldenjava - 08/23/19 03:21 PM
ProSelect 27356 cut open
by Sayjac - 08/23/19 03:04 PM
Electrolux - Dryer reliability warning.
by pezzy669 - 08/23/19 02:37 PM
Microfiber Towels for different applications?
by Quattro Pete - 08/23/19 01:53 PM
Coated vs. painted rotors
by atikovi - 08/23/19 01:13 PM
New spark plugs, occasional misfire
by avacado11 - 08/23/19 12:34 PM
Boogyman, GeoffPD, CabanaBanana, tblack, goldenjava
69048 Registered Users
24 registered members (2002 Maxima SE, 4WD, Bellavita, Anduril, Bailes1992, 4 invisible), 725 guests, and 19 spiders.
Topics293,713
Posts5,045,454
Members69,048
Most Online3,532
Jul 30th, 2019
Page 2 of 2 1 2
Re: Platinum spark plug lifespan [Re: supton] #5083188 04/22/19 09:09 PM
Nick1994 Offline
Originally Posted by supton
I've only changed the downstream O2 sensor; I only got some of the prior owner's repair records, so all I know is the charcoal cannister was replaced--I got it at about 140k and in short order threw at it an intake hose, TB, water pump, T-stat, plugs, wires, PCV valve, struts. That was 2 years ago, 50-60k depending upon the item. Downstream O2 sensor was Sept '17, only has 45k on it. Upstream I have to assume is original, along with nearly everything else on the motor. Maybe it's time for that too--maybe when I have the radiator out I should hammer on the O2 sensor and see if wants to loosen up (with the radiator out of the way, less things to break!).
Have you logged in to the Toyota Owners site to check any dealer repairs/maintenance done?
2015 Hyundai Sonata 2.4L 101k STP Synthetic HM 10w30 & OEM
2000 Toyota Camry 2.2L 234k Mobil Super HM 10w40 & Fram Ultra
1996 Jeep Cherokee 4.0L 149k Mobil 1 HM 10w40 & Fram Ultra
Re: Platinum spark plug lifespan [Re: y_p_w] #5083225 04/22/19 09:54 PM
B
bbhero Offline
B
Originally Posted by y_p_w
Originally Posted by zzyzzx
At least 100K miles. I would regap them periodically though.
These are funky double-electrode platinums. Not sure they're supposed to be regapped since the gap is sideways. Either Denso PK20TR11 or NGK BKR6EKPB11.
[Linked Image] [Linked Image]
Yep... The Denso one I put in my lady's Camry 98 2.2 L car... And they certainly don't need to be gapped. That is already set. Just plug and go.
Nissan Altima 3.5 Coupe
Cam2 Dexos1 Gen 2 5w30 Wix 57356 Oil filter
"Treat your family like your friends and treat your friends like your family."
Re: Platinum spark plug lifespan [Re: clinebarger] #5083229 04/22/19 09:56 PM
B
bbhero Offline
B
Originally Posted by clinebarger
Originally Posted by slacktide_bitog
60k seems about right. The hiccup could also be caused by something else, too.
Just be glad you don't have the 1MZ! Then you'd need 6 of those expensive 2-prongers, and it's impossible to get to the rear bank! mad
The only multi-prong iridium I've ever seen available for these Toyotas was the old Bosch Platinum-Ir Fusion, but they don't make them anymore. They are a MUST in the 1MZ because iridium is good for 100k, so you wouldn't have to do them again for a long time!
The good news is that you don't need to track down those Bosch iridiums for your car because they're easy to do in yours. So a 60k platinum is fine. Also remember that Denso makes good ones for your car, too, and they cost less than NGK smile
[Linked Image]
This is the craziest post I have seen on here yet LOL
Really funny and simply AWESOME...
Re: Platinum spark plug lifespan [Re: supton] #5083277 04/22/19 11:19 PM
B
BobGoblin Offline
B
Acording to my service manual my NGK sparkplugs for KIA Ceed (iridium) are rated for 175.000 kilometers on MPI engine (on GDI it is shorter interval by half for same plugs)
Re: Platinum spark plug lifespan [Re: supton] #5083374 04/23/19 05:21 AM
G
GMBoy Offline
G
It could simply be a coil. I usually see Platinum plugs lasting easily 60k miles with most able to hit 100k miles. Check your coil(s).
Re: Platinum spark plug lifespan [Re: Nick1994] #5083462 04/23/19 07:30 AM
supton Offline OP
"Sharp/Biting" Misfires under load are usually Secondary Ignition related......
*At night or in a dark area......Mist the plug wires & ignition coils with some water from a spray bottle & watch/hear for arching.
*Water &/or Oil in the Plug wells.
*Pull all the plugs & check for cracked Isolators(Ceramic).
will keep that in mind, thank you. Didn't do anything today, so maybe it was in my head. It was not a steady miss, just feel like a random miss, like a handful at most on one hill.
Coils, now I have heard complaints about those going, perhaps it's time for me to pick one up for a spare.
Forgot that I had set that up. Go figure, absolutely nothing comes up for that car for records. Nothing.
On the flip side I saw that my truck had the throttle body cleaned at 60k. I cleaned it at 110k or 120k as it had an idle issue. So it sounds like... I'll be cleaning it again soon enough.
Also came across that it had an ECU reflash back in 2014. Which makes me sad as I am getting close to end of warranty on the AIP--but the blockoff / bypass stuff only works if the ECU wasn't reflashed. frown
2011 Toyota Camry, base, 2.5L/6MT, 187k, hers
2010 Toyota Tundra DC, 4.6L/6AT, 153k, ours
1999 Toyota Camry LE, 2.2L/4AT, 209k, his
Page 2 of 2 1 2
