Tacoma fuel filter cut open
by funflyer - 05/31/20 06:53 PM
Electronic Octane Testers on eBay
by smonska - 05/31/20 05:35 PM
0W-8 is here: JASO GLV-1
by Gokhan - 05/31/20 05:26 PM
2010 Corolla What oil ??
by GMguy84 - 05/31/20 05:19 PM
Knock While Cruising, None While In Boost
by gathermewool - 05/31/20 04:11 PM
Replaced Golf Sportwagen with an Alltrack
by dareo - 05/31/20 03:27 PM
TW Ceramic Spray First Time
by Toros - 05/31/20 02:49 PM
The perfect tractor oil
by Chris142 - 05/31/20 02:42 PM
5.7 HEMI Lifter/cam failure cause
by Skippy722 - 05/31/20 02:38 PM
Battery 2013 4Runner 4WD
by Gebo - 05/31/20 02:29 PM
Supermarket Heroes 500 at Bristol
by bdcardinal - 05/31/20 01:55 PM
More M1 changes
by Flashlightboy - 05/31/20 01:49 PM
Car Reviewers
by borgward - 05/31/20 01:43 PM
Final charge global extender
by mker - 05/31/20 01:15 PM
Rotella Multivehicle 5W-30
by js1956 - 05/31/20 10:54 AM
Tesla Model 3 Driving Guide
by JeffKeryk - 05/31/20 10:41 AM
Keep OE carb vs replacement
by JHZR2 - 05/31/20 10:00 AM
Gave away some of my stash
by Chris142 - 05/31/20 08:32 AM
Haywood, ToOliwer, AbbeyRoad, RPF, Rayi
71586 Registered Users
91 registered members (10WSmuckers, ABN_CBT_ENGR, 53' Stude, Avery4, 55hambone, ammolab, 13 invisible), 2,306 guests, and 44 spiders.
Topics306,102
Posts5,286,487
Members71,586
Interested in those self adjusting wire strippers #5082660 04/22/19 11:09 AM
J
joegreen Offline OP
J
I found a thread on these wire strippers but it was last responded to in 2014 so i decided to make a new post. I am interested in the self wire strippers and how they compare to manual wire strippers. What do you use manual or automatic strippers? What style do you recommend? What brand do you use and how has it held up. Its easy enough to strip the insulation on larger wires 10 gauge or less but i am looking for something that can strip wire from say 14 gauge up to 26 gauge. basically cat5e cable will be the smallest wire i will be stripping with most of the wire gauges falling into the automotive size spectrum.
1978 Chevrolet k20
Engine: Delo 10w30xle
Transmission: Castrol transmax dex/merc
1984 Mercedes-Benz 300 turbo diesel
Engine: Delo 400 15w40le
Re: Interested in those self adjusting wire strippers [Re: joegreen] #5082664 04/22/19 11:13 AM
B
bmwpowere36m3 Offline
B
Re: Interested in those self adjusting wire strippers [Re: joegreen] #5082680 04/22/19 11:36 AM
Quattro Pete Offline
I picked this one up for about $10 from some Chinese website. So far I've mainly used it for stripping speaker wire. Works OK.
[Linked Image]
2002 530i   2015 Q5 3.0T   2018 Charger SRT
Re: Interested in those self adjusting wire strippers [Re: joegreen] #5082711 04/22/19 12:18 PM
Saul Offline
I have a pair similar to those linked. I prefer just a manual pair of Klein.
Re: Interested in those self adjusting wire strippers [Re: joegreen] #5082729 04/22/19 12:33 PM
R
ruhroh Offline
R
I won't use it often so I bought the $8 Harbor Freight one. It works surprisingly well. Just don't hesitate as you squeeze the handle when using it or else it'll just chew up the insulation instead. It made rewiring a few lights really fast & easy especially when I'm on a ladder. The grabber will leave some indentations in the wire so for more precise stripping, it's hard to beat the manual stripper but that'll also take much longer to use. I've used some cat5 wires for some basic soldering stuff and the stripper pulls but fail to completely strip the insulation maybe 1/5 times. Can be manually adjusted using the knob but I never bothered.
Re: Interested in those self adjusting wire strippers [Re: joegreen] #5082752 04/22/19 01:08 PM
T
Trav Offline
T
I have one from Hazet and one from Knipex, both work great.
https://www.amazon.com/Knipex-12621...;qid=1555956421&s=gateway&sr=8-1
Select 7.25 for a single piece.
Re: Interested in those self adjusting wire strippers [Re: joegreen] #5082759 04/22/19 01:18 PM
R
Reddy45 Offline
R
The pair I own don't work well on stranded wire in "cheaper" setups. You'll lose a few of the strands each time. On solid core it'll work great.
Re: Interested in those self adjusting wire strippers [Re: joegreen] #5082803 04/22/19 02:17 PM
W
WyrTwister Offline
W
https://www.homedepot.com/p/Ideal-7...-Stripper-Wire-Stripper-45-615/300500669
I use wire strippers like this . Simple & easy . Reasonably priced
Wyr
God bless
Re: Interested in those self adjusting wire strippers [Re: joegreen] #5082974 04/22/19 05:04 PM
E
eljefino Online Content
Online Content
E
I like my Kleins.
Sometimes cheesy wire with PVC insulation has the insulation stretch and bounce back. Typically Cat 5. I can cut a little extra then trim the copper if this is a real problem.
Re: Interested in those self adjusting wire strippers [Re: joegreen] #5082980 04/22/19 05:10 PM
T
TheLawnRanger Offline
T
I got a pair at home depot for around $10. The tool worked great so I was pleasantly surprised. However, after a few months, the rubber grips started coming off revealing why they were inexpensive.
2011 Impala
2012 Colorado
Oil: 5w30 synthetic
Filters: Wix 51522 for both
Re: Interested in those self adjusting wire strippers [Re: joegreen] #5083103 04/22/19 07:26 PM
das_peikko Offline
I highly recommend these Craftsman, but they are made by Stride-Imperial in the USA.
[Linked Image]
Re: Interested in those self adjusting wire strippers [Re: joegreen] #5083320 04/23/19 01:49 AM
Silk Online Content
Online Content
I've had Vessel wire strippers for over 40 years, they still work perfectly.
][Linked Image]
1987 BMW R65 - Penrite VTwin 20-50
2005 Nissan Expert - 5W-30 Castrol Edge
1996 Volvo T5 - Penrite HPR15 - 15W-60. Ryco syntec filter.
Re: Interested in those self adjusting wire strippers [Re: Silk] #5083328 04/23/19 02:50 AM
stoan Offline
][Linked Image]
This is my favorite style as well. Mine are Ideal and Greenlee, but the same thing. Of course you need a good pair of compact manual strippers for tight areas, but this is what I reach for first.
Re: Interested in those self adjusting wire strippers [Re: joegreen] #5084609 04/24/19 10:18 AM
J
joegreen Offline OP
J
thanks for the input
1978 Chevrolet k20
Re: Interested in those self adjusting wire strippers [Re: joegreen] #5152207 07/05/19 12:53 PM
J
JLawrence08648 Offline
J
I love these 45 yr old self adjusting wire strippers from Speedex Manufacturing. I've been so happy with them I'd like to expect positive performance from any manufacturer of similar design.
2019 Hyundai Santa Fe SEL Plus, 2.4
1992 Acura Vigor GS, 2.5
