Price of Diesel vs Gasoline 1980-2018
by SubLGT - 10/15/19 08:43 AM
Shield Rebate
by hatt - 10/15/19 08:43 AM
Intermittent shake
by supton - 10/15/19 08:11 AM
0W 20 in place of 5W 30 in First Gen CRV?
by Revrick - 10/15/19 07:29 AM
Servicing '13 Cadillac SRX AWD Haldex unit
by gd9704 - 10/15/19 06:15 AM
Possible WIX failure?!?
by AutoNotifier - 10/14/19 11:59 PM
Possible WIX failure?!? What could have happened?
by tony1679 - 10/14/19 11:48 PM
Anyone use a radiant barrier?
by daves66nova - 10/14/19 10:13 PM
FS- Corolla 15 inch hubcap
by bowlofturtle - 10/14/19 10:04 PM
tire wear from -0.5 degree of camber
by bowlofturtle - 10/14/19 09:48 PM
E85 fuel composition?
by JorgeSimon - 10/14/19 09:12 PM
Microsoft enables Tamper Protection for Home Users
by Jimmy9190 - 10/14/19 08:13 PM
Need rotary hammer for chiseling tile & glued floor laminate
by JLawrence08648 - 10/14/19 08:06 PM
Super Auto of2500x (57045) cut open
by Inlo - 10/14/19 08:01 PM
Detailed the new Renegade!
by HoosierJeeper - 10/14/19 07:34 PM
All My Filters
by kstanf150 - 10/14/19 07:07 PM
Hoffy1, joy786, robinasu, TriniDerian, kaspurr
69565 Registered Users
107 registered members (2015_PSD, Al, alarmguy, A310, 2004tdigls, 2009Edge, 8 invisible), 1,838 guests, and 55 spiders.
Topics295,985
Posts5,088,701
Members69,565
Most Online3,532
Jul 30th, 2019
Page 2 of 2 1 2
Re: Craftsman/Kohler Riding Mower Battery Connected in Reverse [Re: benjamming] #5080043 04/19/19 03:57 PM
M
mk378 Offline
M
When measuring ohms, a single "1" on the left side of the screen means an open circuit. It is the same as you see with the probes not touching anything. This is usually good when you are checking for shorts.
A one piece ignition coil mounted next to the flywheel is self-powered. It doesn't connect to the battery system at all. The only connection to the controls is the single "kill wire" which will stop the engine when the wire is connected to ground. That happens when the key is turned off or if one of the safety circuits activates, such as having the blade engaged with the seat unoccupied.
You can easily find out shorted regulator by leaving it disconnected and see if the fuse holds and the rest of the mower works.
Re: Craftsman/Kohler Riding Mower Battery Connected in Reverse [Re: benjamming] #5083004 04/22/19 05:43 PM
B
benjamming Offline OP
B
Voltage regulator & ignition module have been replaced. The issue now is that it dies & blows the fuse when I engage the blade.
Page 2 of 2 1 2
