Originally Posted by joekingcorvette
My 2005 Corvette has the key slot back by the license plate and it is pointing down and you cannot see it unless you bend down and look up. You open the rear hatch and climb through the back of the car and then you can open the door or hood if the battery is dead.
My 2018 has that as well and I hope I never have to test it out! I have heard a couple of guys that couldn't get in even with that key in the back, and I think they had to remove the tail lights in order to gain access.
BTW, you don't need to climb into the car once you get the hatch open though, there is a pull cable hidden under the side panels that will pop the driver's door open.
