bathroom toilet leaking help
by FirstNissan - 06/04/20 02:52 AM
Scored some NOS old dogs
by GMguy84 - 06/04/20 01:56 AM
Chevy Positraction 1057721
by rorty - 06/04/20 12:42 AM
Moving up to 5w30. How thick is too thick?
by BTLew81 - 06/03/20 11:15 PM
Renting UHaul Truck to Tow Your Own Trailer?
by Miller88 - 06/03/20 09:40 PM
First Oil Change Recommendation
by gtpimp - 06/03/20 09:20 PM
GM 10L80 Issues
by shimps1 - 06/03/20 08:26 PM
Brake/Carb cleaner issue.
by Jarpin - 06/03/20 07:27 PM
sharp oil pressure drop-off > 130C
by bbrtuning - 06/03/20 06:48 PM
Warranty work
by t1snwrbrdr12 - 06/03/20 06:10 PM
AC Flashing Light
by artbuc - 06/03/20 05:13 PM
Watches
by Passport1 - 06/03/20 03:57 PM
best budget tire
by VQLT - 06/03/20 03:33 PM
Castrol EDGE turns black/red FAST
by Silver - 06/03/20 03:20 PM
Our van feels "Darty" or twitchy" on the highway
by 1911CHAMPION - 06/03/20 02:55 PM
You guys who pile the miles up weekly on your ride
by Speak2Mountain - 06/03/20 02:22 PM
'19 + '20 Kicks w/C.V.T. : Any owners or know
by odie - 06/03/20 01:38 PM
Securing rubber hose to metal tubing?
by joshuawesl - 06/03/20 01:15 PM
Extremely rare Honda
by wings&wheels - 06/03/20 12:36 PM
Kernal, AB_Indian, rorty, Ghosty, zmann96
71604 Registered Users
23 registered members (BlakeB, dlundblad, 4WD, dervdave, Darren_L, 3 invisible), 784 guests, and 37 spiders.
Topics306,116
Posts5,287,810
Members71,604
Piston Temperatures of an Air Cooled Engine #5082412 04/22/19 06:43 AM
Shannow Online Content OP
OP Online Content
Finally Found the paper again...
Interesting in the viscosity and piston temperature, and how much (little) effect was gained by cutting off access to oil spray under the pistons, indicating that viscous shear on the cylinder walls played more of a part than "cooling" from the oil.
(Yes it's old)
http://naca.central.cranfield.ac.uk/reports/1940/naca-report-698.pdf
If it's the truth....it can handle the pressure !!!
Re: Piston Temperatures of an Air Cooled Engine [Re: Shannow] #5082600 04/22/19 10:21 AM
F
FlyNavyP3 Offline
F
Really cool article Shannow! Thanks for sharing!
Luke
Re: Piston Temperatures of an Air Cooled Engine [Re: FlyNavyP3] #5082964 04/22/19 04:56 PM
OP Online Content
No probs...I'e been trying to (re) find it for months and months
Re: Piston Temperatures of an Air Cooled Engine [Re: Shannow] #5087936 04/27/19 07:17 AM
53' Stude Offline
Good read so thank you mate smile
Cheers Cheers1
2009 Toyota Camry LE
Re: Piston Temperatures of an Air Cooled Engine [Re: Shannow] #5089717 04/28/19 06:14 PM
MolaKule Offline
Global Moderator
Global Moderator
Didn't you and I both prove some time ago, on separate continents, that a reduction in engine oil viscosity resulted in cooler head temps using riding mower engines and IR guns?
As I recall(?), I went from from a 15W50 to a 15W40, to a 10W30, to a 5W30 and noticed head temp reduction each time.
"As engineers [and scientists] we are wired to solve problems and to create new things, to challenge the status quo and push the limits..." Ken Hurt, Embry-Riddle University, Class of '97.
Re: Piston Temperatures of an Air Cooled Engine [Re: Shannow] #5090045 04/29/19 01:10 AM
OP Online Content
Molakule,
yep, you did the heads, I did the bulk oil with a type K thermocouple down the dipstick on 5W20 through 20W60.
Given that the temperature DRIVEs heat expulsion, through radiative (T^4) and convective (T^2) mechanisms from an air cooled engine, clearly the oils were generating less heat, not carrying away more.
Cheers2
Re: Piston Temperatures of an Air Cooled Engine [Re: Shannow] #5095545 05/04/19 09:15 AM
R
Rand Offline
R
Interesting, however I dont think it will sway me to go thinner in the 1980's tractors.
1 jd316 had been running thousands of hours on 20w50, now it probably has another 1000+hours on 15w40 (purchased new ?1986?)
the hour meter doesnt work now.
we have 2 more of this series tractor and they all have provided no oiling issues on 15w40..(less history with these 2 they were purchased well used)
they get worked hard.. not sure a 30wt would protect as well when they are run hard mowing fields and such.
(if it aint broke dont fix it)
In fact I snagged a case of havoline 20w50 for $1/qt that will be going in the 3000hr+ jd316.
Thanks for posting that article.. was a good read.
Re: Piston Temperatures of an Air Cooled Engine [Re: Shannow] #5095635 05/04/19 11:46 AM
MolaKule Offline
Global Moderator
Global Moderator
Since most 4-cycle air cooled engines used in Outdoor Equipment specify somewhere around a 30 grade, and if i had a mowing and landscaping service, I think I would use this:
10W-30/SAE 30
Re: Piston Temperatures of an Air Cooled Engine [Re: Shannow] #5188079 08/15/19 04:36 PM
R
red7404 Offline
R
WAY over my head..
Re: Piston Temperatures of an Air Cooled Engine [Re: Shannow] #5229220 10/03/19 10:01 AM
B
Bighorn2500 Offline
B
10W30 Rotella or 5W40 T6 HDEO work well in my air cooled OPE
2012 Ram 2500 SLT 6.7L Cummins 4x4
2018 Dodge Durango GT 3.6L 4x4
Re: Piston Temperatures of an Air Cooled Engine [Re: Shannow] #5234447 10/09/19 02:52 AM
J
jakewells Offline
J
I tried multi weight in a air cooled and didn't like having to keep it topped off due to consumption. I went back to mono weight and no more oil burning and if it runs hotter so be it.
2001 Mercury Cougar base 2.5l CD4E automatic.
Re: Piston Temperatures of an Air Cooled Engine [Re: Shannow] #5238072 10/12/19 07:47 PM
Cujet Offline
I own a Cessna 177RG with the air cooled Lycoming IO360 angle valve, 200HP engine. Using thin oil (15W-50) results in higher oil consumption and lower oil pressure. Some people claim the thinner oil may result in faster ring and cylinder wear in hot conditions. Not sure I accept that.
But oil temperature is lower by about 20 degrees.
I'd use the straight 50 viscosity oil, however, the semi-synthetic oil prevents exhaust valve sticking our operations.
