Just the one website
by Exhaustgases - 08/19/19 03:55 AM
DTD flash sale 8/19 $100 off select tires
by eljefino - 08/19/19 03:51 AM
Thread Repair Question
by The Critic - 08/19/19 02:48 AM
Genuine Mercedes-Benz 229.5 5W-40 Engine Oil
by The Critic - 08/19/19 02:25 AM
Is it safe to use 100% synthetic
by Espada - 08/19/19 02:16 AM
Cobb Air Filter Cleaning
by The Critic - 08/19/19 01:58 AM
PCV side of the engine is cleaner
by OilUzer - 08/19/19 01:50 AM
Which is Better: Old or New Castrol Edge 0W-40?
by nielkfj - 08/19/19 01:18 AM
Discount Tire Warranty
by Maddog1337 - 08/19/19 12:26 AM
Mobil One Super Synthetic Euro 5W-40
by hellokitty - 08/18/19 11:26 PM
Help Me Search
by Gebo - 08/18/19 09:29 PM
2018 Camry Transmission Drain & Refill Procedure
by painfx - 08/18/19 09:11 PM
.325 pitch vs .375 pitch saw chain
by The_Eric - 08/18/19 09:04 PM
House buying opinions on houses.
by ram_man - 08/18/19 08:50 PM
How to get nails out of my driveway?
by Chris142 - 08/18/19 08:37 PM
Used cars imported from Canada to USA on the rise?
by BobsArmory - 08/18/19 08:28 PM
Espada, samhainlimon, CrazyElf, mattkocanda95, HardCoreHawkFan
68995 Registered Users
24 registered members (Bailes1992, Boosted240, 4WD, billt460, ctechbob, 5 invisible), 630 guests, and 28 spiders.
Topics293,499
Posts5,041,237
Members68,995
Most Online3,532
Jul 30th, 2019
Page 2 of 5 1 2 3 5
Re: Any tips to staying awake on the freeway? [Re: das_peikko] #5082327 04/22/19 01:19 AM
4WD Online Confused
Online Confused
Re: Any tips to staying awake on the freeway? [Re: ediamiam] #5082331 04/22/19 01:51 AM
Char Baby Offline
Originally Posted by 69GTX
Listen to a morning radio show that makes you think. Keep your mind engaged for that 40 minutes.
Originally Posted by bubbatime
Listen to audiobooks. Your local library has a free slection, or you could use the Audible app. When I get into a good book, I stay awake.
Originally Posted by ediamiam
I try to listen to talk radio when I'm driving. Keeps my mind active and sometimes my blood boiling.
+4
"Retired"
'15 Nissan Altima 2.5 SV
'15 Honda Civic 1.8 LX
Re: Any tips to staying awake on the freeway? [Re: das_peikko] #5082338 04/22/19 02:52 AM
Dave9 Offline
There is no vehicle issue here
If you are burning the candle at both ends, don't.
Life is too short to do that. It's just transportation.
Re: Any tips to staying awake on the freeway? [Re: Dyusik] #5082343 04/22/19 03:26 AM
O
Oro_O Offline
O
Originally Posted by Dyusik
Coffee is good while caffeine is kicking, and after that theobromine's vasodialation can be felt, especially that early. A drop in blood pressure can rock you to sleep much better than your struts. I have to get up early as well, and don't start my coffee until getting to my destination, of shortly before. Nothing replaces sleep though. If you find yourself falling asleep, try screaming at things, it's unorthodox, but it will work until you can pull over (or get pulled over smile )
Most intelligent answer here.
Don't drink coffee until at least an hour after you wake up. It's a feedback effect - you use the coffee as a stimulant, and your body learns to down-regulate your natural cortisol and other wake-up hormones. Since i quit drinking cofee until AFTER I get to work, I wake up more naturally, fully, and am more functional.
Go to sleep early enough to get enough sleep, don't f' with your bodies natural rhythm with drugs like you are doing.
Re: Any tips to staying awake on the freeway? [Re: Oro_O] #5082345 04/22/19 03:32 AM
4WD Online Confused
Online Confused
Yes … you need water first and coffee can wait …
Re: Any tips to staying awake on the freeway? [Re: das_peikko] #5082353 04/22/19 04:05 AM
M
mcrn Offline
M
Try doing some exercises right before you leave the house.....do some pushups jumping jacks stuff like that.....do you have the same problem when coming home?
2012 Nissan Rogue
Re: Any tips to staying awake on the freeway? [Re: das_peikko] #5082361 04/22/19 04:47 AM
M
michaelluscher Offline
M
That doesn't sound good.
You should investigate possible Sleep Apnea/Diabetes
I generally cruise with a window down, and the sunroof open, and the radio going
But my commute isn't as soothing, any attempts at sleep behind the wheel will result in death, or driving off a bridge or two
'06 Toyota Camry SE V6 3MZ-FE 124k
'01 Mercury Villager Estate VG33E 52k
'06 Ford Taurus SE Vulcan 60k
Re: Any tips to staying awake on the freeway? [Re: das_peikko] #5082368 04/22/19 05:19 AM
P
PumpPusher Offline
P
I'll take melatonin before bed to help me get restful sleep even if it's only 6 hours. Talk radio helps because it gives your mind something to think about. Sipping on soda also helps.
Re: Any tips to staying awake on the freeway? [Re: Oro_O] #5082380 04/22/19 05:50 AM
AZjeff Offline
and don't start my coffee until getting to my destination, of shortly before. )
And if the coffee at work sucks and no place is open to buy coffee before 5 am? I leave at 4 am as well with a 40 minute commute much like the OP. It's not a perfect world..
I use talk radio.
86 Samurai 1.3 leftovers
14 RAV4 2.5 5W-20 PP
18 Nissan Titan 5.6 DI, QSUD
The most important thing to do in your life is to not interfere with someone else's life. - Frank Zappa
Re: Any tips to staying awake on the freeway? [Re: AZjeff] #5082383 04/22/19 05:54 AM
javacontour Offline
I make a thermos full so it stays warm and I don't have to keep the burner on. (Or I've made a liter in the french press.)
It will stay warm all day long, so it's there for me to refill my mug. I'll do it this way even if I'm working from home.
network down, IP packets delivered via UPS -BOFH
Re: Any tips to staying awake on the freeway? [Re: ammolab] #5082386 04/22/19 06:04 AM
Silverado12 Offline
Originally Posted by ammolab
Sleep Apnea? any chance this is a factor? GET TESTED. It is something you can have at a life threatening level and not be aware of.
I have it and had no clue. Sleep lab testing estimated I was getting 8 minutes of sound sleep a night.
This. I work nights and am not tired all the time once I got diagnosed. I had no idea either, but my wife is a respiratory therapist and she noticed I quit breathing at night. I sleep with a CPAP machine now, but it was a little hard to get used to. I can't sleep w/o it now.
12 Chevy Silverado ext. cab LS, 2WD 4.3 auto
18 Mustang GT 5.0 auto
07 Harley Dyna Street Bob 96 c.i. 6 sp.
00 Mustang GT auto
Re: Any tips to staying awake on the freeway? [Re: das_peikko] #5082395 04/22/19 06:19 AM
skyactiv Offline
Exercise before work.
My wife does a lot of traveling for her job and works out everyday before work. She has a home gym in the basement and also has a gym membership.
Me: 13' VW GTI 3 door 6 speed manual
2018 Elantra Sport 6 speed manual
Re: Any tips to staying awake on the freeway? [Re: das_peikko] #5082404 04/22/19 06:32 AM
M
MoneyJohn Offline
M
I won't give any suggestions because there may be variables that are not mentioned in the OP. Would suggest one thing though, search for Matthew Walker on YouTube. He wrote the book 'Why We Sleep'. He has a lab at UC Berkeley. In short youtube video snippets, he has explained a lot of things on how our behavior (including what we eat, when we eat, how we eat, etc) affects sleep. Hopefully, you will find your answer there. There is never 'one size fits all' answer when it comes to sleep, because of the complexity in the sleep process.
Somebody mentioned sleep apnea, look into that too.
Re: Any tips to staying awake on the freeway? [Re: Reddy45] #5082418 04/22/19 06:51 AM
A
aquariuscsm Offline
A
Originally Posted by Reddy45
Open all windows. Hard to fall asleep when you're being blown around.
This is what I do. Works like a charm! Especially if it's cool outside.
1996 Nissan 300ZX 5-speed,Arctic Pearl(#175 of 300)
Quaker State Ultimate Durability 10W30
2012 Honda Accord Coupe EX-L 2.4,auto,San Marino Red
Re: Any tips to staying awake on the freeway? [Re: das_peikko] #5082425 04/22/19 07:02 AM
R
Rmay635703 Offline
R
Wear a tens unit and set it to a uncomfortable level
Page 2 of 5 1 2 3 5
