Toyota factory pink mixed with zerex coolant
orlando,FL
2014 Toyota Camry 2.5l 98k mileage
I bought 1 Toyota pink coolant because Toyota told me I only need a 1 gallon and today was Sunday so dealership are closed. After 1 gallon of Toyota coolant added then I need a more coolant so I mixed with the zerex coolant.
Do I need to worry? If I do then I need to change it tomorrow with 2 gallon of factory Toyota pink coola.
Unless it is the Zerex ASIAN coolant, then you need to flush it good.
(yes there is a Zerex for Toyota called Zerex for Asian vehicle at WM).
The Asian coolant has no silicates.
If that Zerex have silicates then it will gel when mix with no silicates coolant.
You need to check the label in the container.
Check Google for info.
Next time if you run out, you can just use DI or Distilled Water and you are set instead of putting another type of coolant.
You can always add the right coolant later closer to winter since you probably need to add some anyway.
I've mixed Toyota PINK and Zerex ASIAN coolants in yotas with no issue.
