Pennzoil GF-6 & Low Viscosity Q&A
Click here to participate in the Pennzoil Q&A
VOA - HCF-2, Eneos Import CVT Model H, Eneos ECO CVT
by Stucker21trt. 06/26/19 06:48 PM
2012 Mazda3 iTouring
by Kira. 06/26/19 06:46 PM
Blazer Chalet
by dishdude. 06/26/19 06:27 PM
So confused about Hemi oil
by TN Tracker. 06/26/19 06:20 PM
Gabby Chaves’ mobile oil change business
by Pat in Speedway. 06/26/19 06:03 PM
PUP 5w-30 - 2016 GS F - 5,051 miles
by Tiir. 06/26/19 05:41 PM
I-CAR Gold Class Car Wash...
by Vern_in_IL. 06/26/19 05:36 PM
Kia manual allows 5w20 and 5w30 but not 0w20?
by Whammo. 06/26/19 05:31 PM
Buy A Car...Get Freebies
by GrtArtiste. 06/26/19 05:09 PM
by Stucker21trt. 06/26/19 04:31 PM
Radar Dimax AS-8 Diamond in rough
by spiderbypass. 06/26/19 04:06 PM
icy hot additive for oils
by 1978elcamino. 06/26/19 03:33 PM
Why does diesel stink so much less than gas?
by atikovi. 06/26/19 02:29 PM
Mackay radiator hoses?
by atikovi. 06/26/19 02:21 PM
1962 Cub Cadet Original
by Phishin. 06/26/19 01:27 PM
2008 Yamaha VX 1100 oil filter choice
by ledslinger. 06/26/19 01:09 PM
GM's HD Truck Line $100k
by earthbound. 06/26/19 12:17 PM
Huge shark York Beach Maine
by LeakySeals. 06/26/19 12:05 PM
Soflonole27, Bungalowbill, jefferylhenry, dead_bird, mikem350
68501 Registered Users
107 registered members (928, ad244, 53' Stude, Aero540T, 9050lx, 2015_PSD, 7 invisible), 2,086 guests, and 28 spiders.
Topics291,012
Posts4,996,958
Members68,500
Most Online2,967
Mar 10th, 2019
Fortnine Chain Lube Comparison #5081484
04/21/19 08:43 AM
04/21/19 08:43 AM
WI
troop Offline OP
troop  Offline OP
WI
As always, Ryan is pretty entertaining smile
https://www.youtube.com/watch?v=VnPYdcbcAe0
Re: Fortnine Chain Lube Comparison [Re: troop] #5081539
04/21/19 09:48 AM
04/21/19 09:48 AM
Katy, Republic of Texas
blupupher Offline
blupupher  Offline
Watched it last night.
I always wondered what the point of lubing a sealed chain was, and did not know the difference between an x-chain and o-ring chain.
Not an issue for me, I prefer shaft drive, but still some good info.
'18 Santa Fe: PP 10W-30/OEM/5k
'12 xB: M1 EP 0W-20/CQ Blue/5k
'07 Vue: Synpower 5w-30/Ecogard Syn/OLM
'02 F150: Magnatec 5W-20/Bosch D+/1yr
'94 VT1100: Peak 15W-40/Bosch D+/1yr
Re: Fortnine Chain Lube Comparison [Re: troop] #5081588
04/21/19 10:47 AM
04/21/19 10:47 AM
Deep in the heart of Jersey
BigCahuna Offline
BigCahuna  Offline
It seems to me the parts in the drive train that should be lubricated, but because of their design, lends itself to be "lubricant flingers", are the drive gear and rear sprocket. Dirt and grit can be stuck to them, and will help grind gear teeth pointy. High horsepower bikes will stretch chains no matter what you apply for lubrication. Sticky type lube will keep dirt and grit stuck to whatever it's applied to. I personally am glad I no longer have to deal with external drive chains. Belts aren't as fussy, and shaft drive bikes make maint even easier.,,
Re: Fortnine Chain Lube Comparison [Re: troop] #5081616
04/21/19 11:18 AM
04/21/19 11:18 AM
Southeastern USA
FowVay Offline
FowVay  Offline
Southeastern USA
It would seem logical that a high tack chainsaw bar lubricant would surpass all of these if rust prevention and minimal sling are desired. It wouldn't do well with regard to the stickiness test though.
I might put some gear lube in a squirt bottle and try that. I have been using Honda's white moly chain lube for years and I get tens of thousands of miles out of the OEM chains.
Re: Fortnine Chain Lube Comparison [Re: troop] #5081635
04/21/19 11:42 AM
04/21/19 11:42 AM
Fort Lauderdale, FL
DoubleWasp Offline
DoubleWasp  Offline
Fort Lauderdale, FL
Very informative.
Now to launch into debate over which gear oil works best. LOL
Re: Fortnine Chain Lube Comparison [Re: troop] #5081696
04/21/19 12:46 PM
04/21/19 12:46 PM
The Canyons
02SE Offline
02SE  Offline
The Canyons
I've tried every chain lube specific product I could find over the years. Far more than his small sample, plus gear oils, ATF's, motor oil, etc., etc.
To date, I still like the Pro Honda HP chain lube (in the white and red can) the best. When applied to a hot chain and allowed to dry, it generally stays on the outer rollers for a couple hundred miles, and on the sprockets until it's cleaned off with kerosene. The chains and sprockets last the longest for me using this product.
As for holding grit, I use the same lube on our dirtbike chains. We're at the sand dunes this weekend, and taking a break from riding for lunch. I lubed the chains last night, and let them dry. Just looking at them now, there is very little sand stuck to the chains. Gear oil holds more sand on the chain.
Re: Fortnine Chain Lube Comparison [Re: troop] #5081697
04/21/19 12:47 PM
04/21/19 12:47 PM
WI
troop Offline OP
troop  Offline OP
WI
I've been using Maxima chain wax spray for years. Having a H-D, I have plenty of 75w-140 syn gear oil on hand. Gonna give that a try. Just ordered a .80 cents 4oz squirt bottle on ebay to pack for trips.
Re: Fortnine Chain Lube Comparison [Re: troop] #5081893
04/21/19 04:13 PM
04/21/19 04:13 PM
Great White North.. eh
webfors Offline
webfors  Offline
Wurth HHS 2000
Lube every fill up, or after driving in rain. Takes 30 seconds. Never do anything else, not evening cleaning.
Member on Stromtrooper gets 50K miles per chain with that regimen. Good enough for me.
17 Cadillac ATS 2.0T, Edge D1G2 5w30, Champion COS10590
17 Dodge GC, VWB 5w30, Mopar MO-349
18 DL1000XT, Valvoline Dino 20w50, Suzuki OEM OF
Small engines; RT5 10w30
Re: Fortnine Chain Lube Comparison [Re: troop] #5082324
04/22/19 12:57 AM
04/22/19 12:57 AM
PNW
ZeeOSix Offline
ZeeOSix  Offline
PNW
Yep, as he finally discussed, lubing the chain is mostly to keep the chain rollers (inside and out) and sprocket teeth lubed to reduce wear. He's wrong about the lube on rollers "going away instantly" ... maybe with some lubes, but not with good lubes.
I've used Maxima chain was for decades. It almost seems better now than it was 30 years ago. I can usually get 300~400 miles until the rollers start to look shiny, which is the sign to clean and relube.
Another trick I do is when the chain is nice and warm from a long ride, is to put a rubber glove on and respread the lube that has worked it's way to the outside of the links due to centripical force back on to the outside of the rollers. Gives me quite a few extra miles until the rollers get shiny again.
