Mopar / MM filter 2AML00339A 5000 miles
by KenshinHimura. 05/27/19 12:43 AM
R.I.P. Bart Starr. NFL legend.
by PimTac. 05/26/19 11:44 PM
94 mazda b4000 diff fluid
by HyundaiAbuser. 05/26/19 11:08 PM
CSB: Getting new wheels installed
by UG_Passat. 05/26/19 10:11 PM
2019 Toyota twin turbo 4.5 litre V8 diesel oil
by Up2nogood. 05/26/19 09:48 PM
Sam’s Club Battery Sale
by oilstudent24. 05/26/19 09:44 PM
4Runner Odometer Rollback
by Maddog1337. 05/26/19 08:38 PM
QSUD $17.97 @ WMart
by wemay. 05/26/19 08:36 PM
M1-AP Price Lowered Again
by Matagonka. 05/26/19 08:33 PM
2 Million Mile Detroit Diesel
by kstanf150. 05/26/19 07:47 PM
Fiat Chrysler close to merging with Renault.
by PimTac. 05/26/19 07:12 PM
Snap On ratchet re-build ?
by hallstevenson. 05/26/19 07:09 PM
benefits of leaving a penetrating oil to soak in
by Number_35. 05/26/19 06:31 PM
S10/c10 seat
by WiskyBadger. 05/26/19 06:09 PM
AAP BOGO 1/2 Off ATF
by Warstud. 05/26/19 05:56 PM
Buying a new Fire tablet from eBay
by greenjp. 05/26/19 05:25 PM
Subaru Super Coolant
by FA_WRX. 05/26/19 05:10 PM
Maxlife ATF for +4 application
by ZraHamilton. 05/26/19 03:43 PM
PL24651 Purolator One 6K Miles
by kstanf150. 05/26/19 02:38 PM
Tbobtrasman, SmallBlockKid, rcork, oats, RXRS6
68221 Registered Users
45 registered members (BlakeB, Ag76, Blkstanger, berlyn, c502cid, 2 invisible), 865 guests, and 29 spiders.
Topics289,447
Posts4,969,734
Members68,221
Most Online2,967
Mar 10th, 2019
2012 chevy equinox transmission fluid #5081876
04/21/19 03:50 PM
04/21/19 03:50 PM
Missouri
krdoss Offline OP
krdoss  Offline OP
Missouri
What is the best dextron vi oil would everyone recommend?
Re: 2012 chevy equinox transmission fluid [Re: krdoss] #5081882
04/21/19 03:57 PM
04/21/19 03:57 PM
USA
slacktide_bitog Online content
slacktide_bitog  Online Content
USA
welcome
Any licensed Dexron VI will be fine, so just shop on price smile
I like Castrol's Full Synthetic ATF. It often goes on sale a few times a year at the parts stores for $5/qt. Castrol Full Synthetic is licensed Dexron VI
Maxlife ATF is also very popular on here, even though it is not licensed. Widely available at Walmart at a great price. The best choice if you're out of warranty.
Re: 2012 chevy equinox transmission fluid [Re: krdoss] #5082001
04/21/19 06:19 PM
04/21/19 06:19 PM
Central Virginia
Silverado12 Offline
Silverado12  Offline
Central Virginia
My wife had a 2012 2.4 Equinox and I did the fluid on hers with Castrol Dex VI. You'll get about 4 quarts out but it's important to check the level. You can do it from the driver's side if you turn the wheel all the way to the right. You'll see the plug as GM doesn't use dipsticks anymore. There isn't a filter to change either. Edit you can di it on the ground. No need to put the car on a lift.
12 Chevy Silverado ext. cab LS, 2WD 4.3 auto
18 Mustang GT 5.0 auto
07 Harley Dyna Street Bob 96 c.i. 6 sp.
00 Mustang GT auto
Re: 2012 chevy equinox transmission fluid [Re: krdoss] #5082030
04/21/19 06:50 PM
04/21/19 06:50 PM
Maricopa Arizona
dave1251 Online happy
dave1251  Online Happy
Maricopa Arizona
All the DEXRON VI preforms the same buy the cheapest and be happy you saved money.
don't use.
Re: 2012 chevy equinox transmission fluid [Re: krdoss] #5082277
04/21/19 10:51 PM
04/21/19 10:51 PM
Washington
Dylan1303 Offline
Dylan1303  Offline
Washington
I used maxlife and lubegaurd red
12 cruze rs 1.4t 6spd pp 5w30 tuned on 22psi
13 equinox 2.4 awd pp 5w30
Re: 2012 chevy equinox transmission fluid [Re: krdoss] #5082433
04/22/19 07:18 AM
04/22/19 07:18 AM
Missouri Ozarks
CompGUY Offline
CompGUY  Offline
Missouri Ozarks
I have had good luck with the max life in our 2013 escape :-)
Re: 2012 chevy equinox transmission fluid [Re: krdoss] #5082436
04/22/19 07:20 AM
04/22/19 07:20 AM
Georgia, USA
XL1200RFan Offline
XL1200RFan  Offline
Georgia, USA
I have a client with a 2014 Equinox 2.4L. At 64K he noticed it wasn't shifting as smoothly as he thought it should; I performed a double drain & refill with Amsoil Signature Series Fuel Efficient ATF. He is very happy with the results..."like new" he says.
John
2016 F-150 3.5 CE EP 5W-30
2014 Volvo XC60 3.2 CE 0W-40
2003 Chevy Express 2500HD 6.0 M1 EP 5W-30
2000 Jeep Wrangler Sahara 4.0 VML 10W-30
1986 F-350 4x4 7.5 VML 10W-30
Re: 2012 chevy equinox transmission fluid [Re: krdoss] #5086461
04/25/19 09:13 PM
04/25/19 09:13 PM
Central Iowa
TiredTrucker Offline
Central Iowa
One can do a complete fluid change on a Nox / Terrain real easy.
https://www.youtube.com/watch?v=1_GaZnwYknw&t=210s
Freedom is not about having the choice to do what you want, but the choice to do what you ought.
Re: 2012 chevy equinox transmission fluid [Re: krdoss] #5086824
04/26/19 08:24 AM
04/26/19 08:24 AM
Montague, NJ
repairman54 Offline
repairman54  Offline
Montague, NJ
I used Amalie full synth VI IN MY 16 NOX 3.6 . Got a good online by the case price can't remember the cost right now but I service my fleet by the severe Duty schedule which is 40000 miles in the nox on trans fluid. If you have AWD do not forget to do the transfer case.
John
Anything you say can & will be misquoted & used against you
'16 Equinox 3.6 AWD
'11 Tahoe LTZ
'09 2.4 Malibu
FLHR
Doo 1200 GSX
Sea Doo GSX
Re: 2012 chevy equinox transmission fluid [Re: TiredTrucker] #5088672
04/27/19 08:28 PM
04/27/19 08:28 PM
Central Iowa
Central Iowa
wrong response
Re: 2012 chevy equinox transmission fluid [Re: repairman54] #5088674
04/27/19 08:29 PM
04/27/19 08:29 PM
Central Iowa
Central Iowa
And the differential! I did the Transfer and Diff last night on the wife's 2017 Nox she bought last weekend. Very easy and only a total of 1.5 qt of 75w90 to do both of them. Also did the MAF and Throttle Body cleanings. Very easy little gem of a vehicle to work on. Just have transmission left to do.
