02 Honda Accord V6 Aluminum Radiator
by David1 - 09/21/19 01:55 AM
Difinitive Answer for SCA, Silicates, and Diesels
by ErikLeifson - 09/20/19 11:11 PM
Quart bottle cap
by maverickfhs - 09/20/19 11:11 PM
Dexron vi
by charmer37 - 09/20/19 10:22 PM
Deposit Shield
by TheLawnRanger - 09/20/19 10:00 PM
Atlanta Airport - Excellent History
by ctechbob - 09/20/19 09:56 PM
Angry at Walmart service center
by Jetsfan421 - 09/20/19 09:52 PM
Fuel System Cleaners
by ZeeOSix - 09/20/19 09:22 PM
Milwaukee 1/2 impact
by wensteph - 09/20/19 09:10 PM
Windows 7 Use After Support Ends
by ZeeOSix - 09/20/19 08:29 PM
Walmart Poulan chainsaws 50% off
by bubbatime - 09/20/19 08:10 PM
Vintage "Ultra Lube" Grease (show & tell)
by GaryPoe - 09/20/19 08:09 PM
Impact driver for auto work?
by Klutch9 - 09/20/19 07:27 PM
2000 Honda CR-V Ex transmission fluid?
by taztheman - 09/20/19 05:36 PM
Pennzoil Launches Four New Motor Oils
by jayjr1105 - 09/20/19 05:25 PM
Strange TPMS ID and no tire warning yet
by Patrick0525 - 09/20/19 05:18 PM
HF Icon Tool Storage - A Game Changer?
by user52165 - 09/20/19 04:39 PM
Update on my sister's oil burning Tucson
by carviewsonic - 09/20/19 04:37 PM
Shell Spirax 85W-140
by kstanf150 - 09/20/19 03:03 PM
TungGT, ErikLeifson, Kinnes25, Bamajoe, Aleksandar
69347 Registered Users
14 registered members (A_A_G, BeerCan, Char Baby, Bailes1992, David1, FordCapriDriver, 3 invisible), 676 guests, and 27 spiders.
Topics294,845
Posts5,067,808
Members69,347
Most Online3,532
Jul 30th, 2019
What do I set my torque wrench to in this example? #5081869 04/21/19 03:42 PM
A
atikovi Offline OP
A
Tightening a camshaft sprocket bolt and no room to get the torque wrench on it directly. It calls for 66 lb. ft. The distance from the center of the box end wrench to the square drive of the cheater bar is 18 inches. What do I set the torque wrench to?
[Linked Image]
Re: What do I set my torque wrench to in this example? [Re: atikovi] #5081875 04/21/19 03:49 PM
Cdn17Sport6MT Offline
Here you go
Mazda6 GX (Sport in the 'States), 6MT, 2017
Moto Guzzi 850 T5 (Euro version), 1985
Honda Civic Si (EX 2 dr. in the 'States), A/T, 1997
Toyota Camry CE, 5MT, 1999
VW (Type2) Kombi, 4MT, 1979
Re: What do I set my torque wrench to in this example? [Re: atikovi] #5081877 04/21/19 03:51 PM
When at 90 degrees, there is no modification. When "A" is negative... you have to have a higher indicated torque on the wrench.
Re: What do I set my torque wrench to in this example? [Re: atikovi] #5081878 04/21/19 03:52 PM
skyactiv Offline
Make sure the bolt isn't a torque to yield bolt if your reusing it. If the vehicle is European, there's a good chance it is.
Me: 13' VW GTI 3 door 6 speed manual
2018 Elantra Sport 6 speed manual
Re: What do I set my torque wrench to in this example? [Re: atikovi] #5081885 04/21/19 04:01 PM
G
GeorgeKaplan Offline
G
Re: What do I set my torque wrench to in this example? [Re: atikovi] #5081894 04/21/19 04:16 PM
A
atikovi Offline OP
A
Thanks. Also found this http://www.fordservicecontent.com/renderers/torquewrench/wrench_formula_main_en.asp
Wouldn't a torque to yield bolt have a + angle to it? There is no mention of replacement in the repair manual.
Re: What do I set my torque wrench to in this example? [Re: atikovi] #5081898 04/21/19 04:22 PM
A
andyd Offline
A
Total Wild Guess. 44 should be plenty 18 is 3/2 of 12 and 44 is 2/3 of 66. Never used a torque spec when tightening a sprocket bolt . hide
Thick oil is better grin2
Re: What do I set my torque wrench to in this example? [Re: Cdn17Sport6MT] #5081909 04/21/19 04:32 PM
E
eljefino Offline
E
Yeah this. You can get a little ratchet with 3/8" or 1/2" drive in-and-out if the setup you have won't give you 90.
OT That cheater bar looks neet.
Re: What do I set my torque wrench to in this example? [Re: eljefino] #5081914 04/21/19 04:38 PM
SLO_Town Offline
It does! I just ordered one from Bezos.
Scott
03 BMW E46 330Ci ZSP (BMW TPT 5W-30)
10 Honda Element SC (Kendall GT1 Max 5W-30)
11 BMW E90 328i M-Sport (BMW TPT 5W-30)
16 VW Passat VR6 3.6L SEL Premium (Euro Castrol 0W-40)
Re: What do I set my torque wrench to in this example? [Re: atikovi] #5081930 04/21/19 05:03 PM
R
Rand Offline
R
so you would take the org length of the torque wrench (L)
find the total length the wrench and cheater bar (A)
and then divide [L /(L+A)] x required torque(66)
Which in this case I think you would end up at about half or 33lb-ft
example numbers if the torque wrench is 16" and the cheater/wrench combo is 18"
you would take 16/(16+18) or .47 x 66 =31
Re: What do I set my torque wrench to in this example? [Re: SLO_Town] #5081941 04/21/19 05:27 PM
Astro14 Offline
Scott
Me too!
Far more elegant (and likely to fit) than my current cheater pipe (an old jack handle).
32 Packard 15W40
01 Volvo V70 T5 0W30 AMSOIL SS
02 Volvo V70 T5 0W30 Edge
02 Volvo V70 XC 0W40 Edge
05 MB S600 0W40 M1
Re: What do I set my torque wrench to in this example? [Re: Astro14] #5081952 04/21/19 05:39 PM
SLO_Town Offline
Scott
Me too!
See, aitkovi, you're good for something! :-)
Scott
Re: What do I set my torque wrench to in this example? [Re: Rand] #5082002 04/21/19 06:20 PM
That looks right to me..
Re: What do I set my torque wrench to in this example? [Re: atikovi] #5082465 04/22/19 07:47 AM
A
atikovi Offline OP
A
It's called a wrench extender. Great for getting more leverage on a wrench when a pipe wouldn't fit over the end of it. Much safer than latching two wrenches together.
