Mopar / MM filter 2AML00339A 5000 miles
by KenshinHimura. 05/27/19 12:43 AM
R.I.P. Bart Starr. NFL legend.
by PimTac. 05/26/19 11:44 PM
94 mazda b4000 diff fluid
by HyundaiAbuser. 05/26/19 11:08 PM
CSB: Getting new wheels installed
by UG_Passat. 05/26/19 10:11 PM
2019 Toyota twin turbo 4.5 litre V8 diesel oil
by Up2nogood. 05/26/19 09:48 PM
Sam’s Club Battery Sale
by oilstudent24. 05/26/19 09:44 PM
4Runner Odometer Rollback
by Maddog1337. 05/26/19 08:38 PM
QSUD $17.97 @ WMart
by wemay. 05/26/19 08:36 PM
M1-AP Price Lowered Again
by Matagonka. 05/26/19 08:33 PM
2 Million Mile Detroit Diesel
by kstanf150. 05/26/19 07:47 PM
Fiat Chrysler close to merging with Renault.
by PimTac. 05/26/19 07:12 PM
Snap On ratchet re-build ?
by hallstevenson. 05/26/19 07:09 PM
benefits of leaving a penetrating oil to soak in
by Number_35. 05/26/19 06:31 PM
S10/c10 seat
by WiskyBadger. 05/26/19 06:09 PM
AAP BOGO 1/2 Off ATF
by Warstud. 05/26/19 05:56 PM
Buying a new Fire tablet from eBay
by greenjp. 05/26/19 05:25 PM
Subaru Super Coolant
by FA_WRX. 05/26/19 05:10 PM
Maxlife ATF for +4 application
by ZraHamilton. 05/26/19 03:43 PM
PL24651 Purolator One 6K Miles
by kstanf150. 05/26/19 02:38 PM
Tbobtrasman, SmallBlockKid, rcork, oats, RXRS6
68221 Registered Users
51 registered members (C6Z06HCI, berlyn, c502cid, CARJ, carlprop, AZjeff, 5 invisible), 962 guests, and 35 spiders.
Topics289,446
Posts4,969,727
Members68,221
Most Online2,967
Mar 10th, 2019
Page 1 of 3 1 2 3
How much balance weight is too much #5081755
04/21/19 02:02 PM
04/21/19 02:02 PM
Switzerland
Hitman70 Offline OP
Hitman70  Offline OP
Switzerland
Hi,
I own a 2015 Jeep Grand Cherokee 5.7 Summit AWD.
I just purchased brand new wheels for summer (I keep my Pirelli Winter tires on stock wheels). Those are American Racing AR893 chrome 20' x 8.5.
I had almost new Goodyear tires 265 50R20 so I decided to install them on the American Racing wheels. I also have new Mopar tire pressure sensors.
When I tried to balanced them, the machine asked about 120 gram (4 oz) per wheel…
I also tried to balance a rim without the tire on it, just for see, and just for the rim it required 60 gramm (2 oz).
Seems a lot!
But of course, the wheels are heavy, about 30 kg (66 lbs) for the combo rim/tire and rim only is about 18 kg (39 lbs). Maybe it's why it needs so much weight...
Is it normal to have so much weight to add for balance my tires?
Thanks
Re: How much balance weight is too much [Re: Hitman70] #5081763
04/21/19 02:06 PM
04/21/19 02:06 PM
Glendale, Arizona
billt460 Offline
billt460  Offline
Glendale, Arizona
Approximately how much does each sensor weigh?
Re: How much balance weight is too much [Re: Hitman70] #5081765
04/21/19 02:08 PM
04/21/19 02:08 PM
ME
eljefino Offline
eljefino  Offline
ME
My 15-16" OE steel wheels, naked, take 0.25 oz of weight. They are very very well made.
Are you sure your AR wheels are hub-centric, that is, can be balanced on the middle hole, without a "spider adapter"?
As you grow in size, I would expect a growth in weight needed, but you seem a bit beyond my norm. If it rolls good, that's all that matters.
Re: How much balance weight is too much [Re: Hitman70] #5081777
04/21/19 02:18 PM
04/21/19 02:18 PM
Cincinnati, USA
Dave9 Offline
Dave9  Offline
Cincinnati, USA
If the rim needs 2oz and with the tire it needs 4oz, rotate the tire on the rim by 180' then check again.
Re: How much balance weight is too much [Re: Hitman70] #5081816
04/21/19 02:53 PM
04/21/19 02:53 PM
Cali's Central Coast Wine Coun...
SLO_Town Offline
SLO_Town  Offline
For a 66lb wheel/tire combo, I do not think 4oz of weights is too much.
Scott
03 BMW E46 330Ci ZSP (BMW TPT 5W-30)
10 Honda Element SC (Kendall GT1 Max 5W-30)
11 BMW E90 328i M-Sport (BMW TPT 5W-30)
16 VW Passat VR6 3.6L SEL Premium (Euro Castrol 0W-40)
Re: How much balance weight is too much [Re: Hitman70] #5081828
04/21/19 03:06 PM
04/21/19 03:06 PM
The Motor City
Kestas Offline
Global Moderator
Kestas  Offline
Global Moderator
The Motor City
I once had to add 8 oz to balance a tire. The tire had other problems, like it caused the car to wiggle at 15 mph, then again at 70 mph. It also wasnt vary round.
Re: How much balance weight is too much [Re: Dave9] #5081840
04/21/19 03:14 PM
04/21/19 03:14 PM
VA
Gebo Offline
Gebo  Offline
VA
+1 Seems like a very reasonable suggestion...
'98 LEX LS400 295K
'02 4Runner 235K
'05 Lex LS430 85K
'07 Lex GX470 65K
Schaeffer Oil
Toyota ATF's and Coolant
Amsoil Gear Oil and Grease
(Subject to Change as the Wind Blows)
Re: How much balance weight is too much [Re: Hitman70] #5081841
04/21/19 03:15 PM
04/21/19 03:15 PM
Florida
DONWATERS Offline
DONWATERS  Offline
Florida
American racing wheels are notorious for being out of balance. If its aluminum try grinding a non critical area from the wheel itself on the heavy side on the back.
Re: How much balance weight is too much [Re: Hitman70] #5081843
04/21/19 03:19 PM
04/21/19 03:19 PM
Switzerland
Hitman70 Offline OP
Hitman70  Offline OP
Switzerland
Thanks for your answers.
I'll try to rotate the tire by 180' and balance again.
I'm surprise that the rim without tire already requires 2 oz btw.
If nothing changes and if it's not too much, I'll just add the 4 oz if it's safe to do this.
We balanced it by the middle hole without any adapter, like we do with others rims. How can I know if it's not hub.centric?
Re: How much balance weight is too much [Re: Hitman70] #5081851
04/21/19 03:28 PM
04/21/19 03:28 PM
Cincinnati, USA
Dave9 Offline
Dave9  Offline
Cincinnati, USA
It's not hub centric if the wheel bore is larger than the vehicle hub bore, to fit a variety of vehicles with different hub sizes. If hub centric there will be very little slop before the lug nuts are on. OEM wheels are almost always hub centric. Aftermarket would only be if you pay attention to that detail when selecting them or are intended for specific vehicle hub sizes.
Re: How much balance weight is too much [Re: Dave9] #5081905
04/21/19 04:29 PM
04/21/19 04:29 PM
Switzerland
Hitman70 Offline OP
Hitman70  Offline OP
Switzerland
Thanks for the information.
I haven't yet removed the OEM Wheels from the car, so I don't know if the AR wheels bore is larger than the car Wheel bore.
I'll take a look on AR website, maybe I can get the bore size.
Re: How much balance weight is too much [Re: Hitman70] #5081916
04/21/19 04:42 PM
04/21/19 04:42 PM
Switzerland
Hitman70 Offline OP
Hitman70  Offline OP
Switzerland
[Linked Image]
Bore is 78.30.
So I've just to find Grand Cherokee Hub Bore size and i'll know if it's centred or not?
Re: How much balance weight is too much [Re: Hitman70] #5081927
04/21/19 04:58 PM
04/21/19 04:58 PM
Marshfield , MA
andyd Offline
andyd  Offline
Marshfield , MA
Am I just showing my age? 265 50R20 on a Jeep? And this is a good idea because? shrug
Thick oil is better grin2
Re: How much balance weight is too much [Re: Hitman70] #5081933
04/21/19 05:09 PM
04/21/19 05:09 PM
Switzerland
Hitman70 Offline OP
Hitman70  Offline OP
Switzerland
265/50R20 is OEM size btw
Re: How much balance weight is too much [Re: andyd] #5081947
04/21/19 05:34 PM
04/21/19 05:34 PM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
It's not a real Jeep.
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Page 1 of 3 1 2 3
