Seems like some dealers are willing to let these cars go for $10K off MSRP, although not in my area.
I started reading up on them. Some reviews give the transmission some negative marks, but otherwise, no major negatives. I guess you'll be fine if you don't expect to drive this car in a sporty manner. There is no 'S' mode. Car And Driver called this transmission recalcitrant.
Originally Posted by Car and Driver
But the TourX has its own gearbox woes. The eight-speed automatic upshifts as early as it can, often lugging the engine below 2000 rpm in seventh or eighth gear, as if following the commands of some phantom eco mode. But the TourX has no such setting—nor any sport mode, although it surely could use one. At most cruising speeds, the TourX feels as if it has half its horsepower, with anything less than mashing the accelerator producing only a lethargic climb in revs. When the transmission does eventually downshift, it rarely snaps cleanly into the appropriate second or third gear without first landing at some intermediate step along the way. The solution is to shift it yourself, which means prodding the gearshift lever fore and aft, as the TourX lacks paddle shifters. Even then, shifts are sedately delivered, leaving the driver plenty of time to ponder why this transmission is in this car. The answer: Buick reps have said that the Aisin eight-speed is just a stopgap measure until it can start using GM's nine-speed unit, perhaps as early as next year. Hope springs eternal.
That was written a year ago. The 2019 MY still has the same 8-speed Aisin trans. There are also rumors this vehicle might get scrapped altogether, given the change of ownership. It was announced in January of this year that production at German plant where this car is made is being cut in half. Given that America hates station wagons, it's probably just a matter of time.
