Yesterday, I was at my local Walmart, and the new CK4 formulation of Super Tech 15W40 was stocked on the shelves. It appears that the new CK4 formulation is making its way into Walmarts as the inventory of CJ4 is depleted.
Below is the technical summation of the Super Tech 15W40 CK4 PDS from Warren Distribution:
Gravity, °API ASTM D287 31.37
Specific Gravity @ 60°F (15.6°C) ASTM D4052 0.8688
Flash Point, °C ASTM D92 224
Flash Point, °F ASTM D92 435
Viscosity @ 40°C, cSt ASTM D445 116.9
Viscosity @ 100°C, cSt ASTM D445 15.44
Viscosity Index ASTM D2270 139
Pour Point, °C (°F) ASTM D5950 -36°C (-33°F)
Cold Cranking Simulator at (°C), cP ASTM D5293 5970 (-20)
High Temperature / High Shear Vis at 150°C, cP ASTM D5481 4.11
Noack Volatility, % loss ASTM D6375 12
Color ASTM D1500 3.5
Zinc, wt. % ASTM D5185 0.126
Phosphorus, wt. % ASTM D5185 0.115
Calcium, wt. % ASTM D5185 0.181
Sulfur, wt. % ASTM D4951 0.306
Magnesium, wt. % ASTM D5185 0.041
Molybdenum, wt. % ASTM D5185 0.006
Sulfated Ash, wt. % ASTM D874 0.99
Nitrogen, wt. % ASTM D4629 0.044
Pumping Viscosity at (°C), cP ASTM D4684 24,000 (-25)
TBN, mgKOH/g ASTM D2896 9
