Well I decided to join the Havoline box club today... I had to work for it though. The shelf was empty. A nearby pallet had freight on it. And low and behold there it was... It came in a case of two. So I placed the other one on the shelf in the correct spot. I got the plastic qt container for once I add the bulk of the oil like 4 qts then I will use the small plastic qt container to finish off the rest that will be needed. I like the box myself. The plastic bag inside is not super thick or too thin.
