Fleetguard Fuel Filter FF5301 (4)
by Bighorn2500 - 08/18/19 02:04 PM
AC Compressor
by borgward - 08/18/19 01:40 PM
MK7.5 GTi- Oil and Injector cleaner
by Striker - 08/18/19 12:17 PM
Cheap Hack for Cheap Sunglasses
by RayCJ - 08/18/19 10:55 AM
Detailed Engine using Infinity Wax Rubber Wax
by buster - 08/18/19 10:52 AM
Nissan 15208 9E01A oil filter
by passgas55 - 08/18/19 10:35 AM
by buster - 08/18/19 10:01 AM
Bad oil pressure sensor?
by HoosierJeeper - 08/18/19 10:00 AM
So many oil changes, so little time....
by cwhard - 08/18/19 09:10 AM
What oil did iroc use?
by Red91 - 08/18/19 09:09 AM
Differential cover "load bolts"?
by kehyler - 08/18/19 07:39 AM
Havoline Box
by JLTD - 08/18/19 07:17 AM
Best Oil Change Ramps ??
by billt460 - 08/18/19 05:20 AM
About the original manual recommended viscosity
by dolala - 08/18/19 05:19 AM
Is Z&P concentration extrapolable from SAPS % ?
by FordCapriDriver - 08/18/19 01:36 AM
Funny oil change moment
by cwilliamsws6 - 08/17/19 10:38 PM
High pitched squeal from new muffler
by Mark72 - 08/17/19 10:19 PM
AGs61Vette, KsEXL, madscientist7, DennisR, CatCam2
68989 Registered Users
79 registered members (AdditiveOCD, 53' Stude, Best F100, 2010Civic, bdcardinal, atikovi, 11 invisible), 2,256 guests, and 35 spiders.
Topics293,462
Posts5,040,737
Members68,989
Most Online3,532
Jul 30th, 2019
Polishing Wheels #5081176 04/20/19 09:00 PM
SubyRoo Offline OP
So I spent a little while on this rainy day polishing some wheels. Two down two to go.
1999 Acura Integra GS-R 273K
1998 Honda CR-V EX 261K
2010 Mazda 3 60K
Re: Polishing Wheels [Re: SubyRoo] #5081184 04/20/19 09:11 PM
E
ecotourist Offline
E
I assume you started with something like the bottom one and ended up with the top 2. Looks good. How are you doing it?
2000 BMW 528i 5MT M Sport
2007 Honda Accord EX-L 4Door V6 6MT
Re: Polishing Wheels [Re: ecotourist] #5081194 04/20/19 09:20 PM
SubyRoo Offline OP
Exactly, I used 220 grit sandpaper to remove the deep scratches then work to 2000 grit before using some metal polish.
2010 Mazda 3 60K
Re: Polishing Wheels [Re: SubyRoo] #5081283 04/20/19 10:48 PM
W
Warstud Offline
W
Looks good....are you gonna clear coat or ceramic coat them ?
Re: Polishing Wheels [Re: SubyRoo] #5081315 04/20/19 11:24 PM
E
ecotourist Offline
E
Are they clear coated, or just polished metal?
The reason I ask is that my Honda's wheels look similarly bad but I suspect they're clear coated. Which might make working on them easier, or harder!
Re: Polishing Wheels [Re: ecotourist] #5081455 04/21/19 08:00 AM
L
Langanobob Offline
L
Looks like you did a great job. All hand work or did you use a random orbital sander? Something very rewarding about taking a grungy aluminum part and making it look good again.
Re: Polishing Wheels [Re: Langanobob] #5082452 04/22/19 07:35 AM
SubyRoo Offline OP
They were clear coated but it was flaking off on two of them. If you don't have any deep scratches and the clear coat on yours is still pretty good you could try some rubbing compound first and see how that does.
Well I would like to coat them in some way to keep them looking nice but I don't know if clear coat would adhere to a polished surface. I haven't ever used any ceramic coatings so if you have any recommendations Im open to that as well.
Thanks! The initial sanding to remove the leftover clear and scratches I did with a random orbital sander. I used several grits after that by hand, once you get the coarse scratches sanded out it doesn't really take much sanding between each following step.
2010 Mazda 3 60K
