Forgotten baby syndrome
by doitmyself. 05/23/19 02:53 PM
Missouri Tornado
by kstanf150. 05/23/19 02:28 PM
Monroe Econo-matics on '07 RAV4 - horrible
by MoreCowbellAz. 05/23/19 01:48 PM
2019 Crosstrek
by Al. 05/23/19 01:47 PM
Sam's club tire sale
by zmelli. 05/23/19 01:27 PM
Craftsman floor jack rebuild
by i6pwr. 05/23/19 01:14 PM
Napa 1334 Now made in South Korea
by Valkyrie_Rider. 05/23/19 12:22 PM
2004 Prius - Repair or Sell?
by The Critic. 05/23/19 11:57 AM
Get mechanic to check out used car?
by AuthorEditor. 05/23/19 11:24 AM
OK to use this PSF on Hondas too?
by GSCJR. 05/23/19 10:53 AM
Grease for Toyota Tundra
by diyjake. 05/23/19 10:09 AM
Made in USA?
by buck91. 05/23/19 10:00 AM
Email address for Mobil e check?
by BTLew81. 05/23/19 09:29 AM
OE AC COMPRESSOR?
by FA_WRX. 05/23/19 09:08 AM
Up2nogood, JP69, Bluethunder, patcatpat, Wilvoeka
68181 Registered Users
134 registered members (2003f7, 28oz, 53' Stude, 2strokeNorthstar, 19 invisible), 2,234 guests, and 24 spiders.
Topics289,300
Posts4,966,493
Members68,181
Most Online2,967
Mar 10th, 2019
Router died after power went out #5081090
04/20/19 07:08 PM
04/20/19 07:08 PM
MO
RhondaHonda Offline OP
MO
I have 2 Netgear routers in different areas of my house. The power went out briefly during a storm overnight and one of them was not online the next morning. There are no lights at all that are on when it is plugged in now. It wasn’t on a surge protector, just a power strip. I’m thinking that maybe the power supply bit the dust when the power came back on. They both have different power supply specs so I didn’t want to swap the good one without checking here first. The dead one says .6A input and 1.5A at 12v output. The good one is 1.0A input and 2.5A output. Is there any harm in trying the good one before calling this router dead or ordering another power supply?
Re: Router died after power went out [Re: RhondaHonda] #5081094
04/20/19 07:17 PM
04/20/19 07:17 PM
Illinois
javacontour Online content
javacontour  Online Content
Illinois
The router won't draw more current than it needs. So if the plug that goes into the router is the same for both, the higher capacity power supply will provide power to the router that draws less power.
It's actually the other way around that often doesn't work. A lower capacity power supply connected to a higher demand device is asking for trouble.
network down, IP packets delivered via UPS -BOFH
Re: Router died after power went out [Re: RhondaHonda] #5081106
04/20/19 07:27 PM
04/20/19 07:27 PM
USA
mk378 Offline
mk378  Offline
USA
Some routers are 5 volt but most are 12 volt. Of course don't plug 12 volts into a 5 volt router or vice versa. The power requirements of the router will be on its nameplate. If you have a supply with the same output voltage and the output current rating is equal or higher then you can use that power supply. The input current does not matter.
Re: Router died after power went out [Re: RhondaHonda] #5081115
04/20/19 07:35 PM
04/20/19 07:35 PM
Illinois
Illinois
Also, is the 2nd PS also 12v output? As mentioned above, you can use the PS if the output voltage is the same and the current output is equal or more.
Re: Router died after power went out [Re: RhondaHonda] #5081134
04/20/19 08:00 PM
04/20/19 08:00 PM
MO
MO
Yes, both are 12v. Thanks guys. I’ll swap them and see what happens.
Re: Router died after power went out [Re: RhondaHonda] #5081195
04/20/19 09:21 PM
04/20/19 09:21 PM
Upstate NY
Donald Online content
Donald  Online Content
Upstate NY
replace them both with mesh.
Routers and mesh are getting so cheap these days. Maybe a UPS also.
I have my routers and modem on a UPS. That way I can contact NYSEG and tell them the power is off.
Recent power outages I have been able to keep on working on laptop connected through router (on UPS) and it lasted long enough until power cam back on.
2015 Ford F250 w/Powerstroke
Re: Router died after power went out [Re: RhondaHonda] #5081219
04/20/19 09:55 PM
04/20/19 09:55 PM
Ohio
hallstevenson Online content
hallstevenson  Online Content
Ohio
Get the power requirement specs from the device, not the 'plug' that it's connected to. As others have said, the router will only draw 'x' amount of power. The numbers/specs on the plug list the maximum that it can supply.
Re: Router died after power went out [Re: RhondaHonda] #5081227
04/20/19 10:04 PM
04/20/19 10:04 PM
Ontario, Canada
OVERKILL Offline
OVERKILL  Offline
Ontario, Canada
As long as the output voltage on the other adapter is the same as the one you suspect being dead and the output current is the same or greater, it is perfectly suitable for testing as to whether it is the adapter or not.
2016 Grand Cherokee SRT - Ravenol SSL 0w-40, FRAM Ultra
Re: Router died after power went out [Re: RhondaHonda] #5083060
04/22/19 06:48 PM
04/22/19 06:48 PM
MO
MO
I swapped AC adapters and it powered right up. Just ordered a replacement for $9.95. I’ll get a surge protector too. I’ll read up more on the mesh thing as well.
Re: Router died after power went out [Re: RhondaHonda] #5083483
04/23/19 07:56 AM
04/23/19 07:56 AM
USA
mk378 Offline
mk378  Offline
USA
When you need to replace one of these, most thrift stores have a "[censored] box" of orphaned cables, plugs and adapters.
