Drive In Movies
by 53' Stude - 09/15/19 08:49 AM
Oil/Gas prices gonna go up?
by Mad_Hatter - 09/15/19 08:10 AM
Ordering parts
by tiger862 - 09/15/19 07:44 AM
Shell conventional @ Menards. $1.99
by Kruse - 09/15/19 07:33 AM
How do I update my profile?
by ernied - 09/15/19 07:07 AM
Most dangerous job ever?
by Mad_Hatter - 09/15/19 07:06 AM
04 Grand Marquis
by mrjlube - 09/15/19 07:01 AM
Engine burning oil
by Espada - 09/15/19 06:49 AM
Walmart near me do not sell havoline oil
by MetalSlug - 09/15/19 04:11 AM
Wanted: Inexpensive car
by FirstNissan - 09/15/19 02:53 AM
Do all replacement LED headlight bulbs suck?
by Nick1994 - 09/15/19 12:56 AM
5 qt Chevron Supreme 5w-30 for $12.42 @ walmart.com
by gallydif - 09/15/19 12:03 AM
how effective is spray scotchgard?
by WhyMe - 09/14/19 11:39 PM
Want opinion of disc brake pad wear
by boulderdentist - 09/14/19 11:08 PM
Mercedes’ dealer oil filter panel/board
by SlavaB - 09/14/19 11:08 PM
Mercedes damage code
by SlavaB - 09/14/19 11:00 PM
Restoring the paint on the Crown Vic
by Colt45ws - 09/14/19 10:39 PM
Hyundai Ioniq
by WhyMe - 09/14/19 10:08 PM
Grooves in windshield due to wiper blades
by dx92beater - 09/14/19 09:43 PM
KevATL, DragSGT, Gbenitez, DoctorPc, FarmerDan
69277 Registered Users
96 registered members (53' Stude, atikovi, Amenhotep, 08z06, ARCOgraphite, aleneros, 8 invisible), 1,642 guests, and 22 spiders.
Topics294,563
Posts5,062,455
Members69,277
Most Online3,532
Jul 30th, 2019
What would you do, engine code for Thermostat? #5081037 04/20/19 06:26 PM
Y
Yuk Offline OP
Y
2007 Mazda 6 2.3L 4 cylinder
Engine light came on after driving 25 minutes on the highway. Engine is running fine. As much as I can tell, fuel economy is normal.
Code indicates a problem with the thermostat. There is heat in the interior and the engine temperature remains normal.
Have now driven about 50-75 km since reseting the light. That car continues to run well.
Question:
Would you change the thermostat now, or wait for the car to show a code again?
Re: What would you do, engine code for Thermostat? [Re: Yuk] #5081044 04/20/19 06:32 PM
supton Offline
I'd get one of those ELM327 dongles, download Torq for my phone, and then see what temp the engine is running at. If not something for the smartphone then something that can read what the ECU thinks the engine is running at.
If the car is overdue for a coolant exchange, or you have other reason to touch the cooling system, then sure, mess with the t-stat. Otherwise I'd wait for the diagnostic tool and confirm it.
2011 Toyota Camry, base, 2.5L/6MT, 189k, hers
2010 Toyota Tundra DC, 4.6L/6AT, 153k, ours
1999 Toyota Camry LE, 2.2L/4AT, 211k, his
Re: What would you do, engine code for Thermostat? [Re: Yuk] #5081046 04/20/19 06:36 PM
W
Warstud Offline
W
What Temp is it running ?
Re: What would you do, engine code for Thermostat? [Re: Yuk] #5081055 04/20/19 06:39 PM
Donald Offline
The thermostat should be considered a maintenance item. I would replace it. It's cheap enough.
Has the coolant been changed recently?
2015 Ford F250 w/Powerstroke
Re: What would you do, engine code for Thermostat? [Re: Warstud] #5081056 04/20/19 06:40 PM
Y
Yuk Offline OP
Y
Don't have an actual number, just a Hot/cold gauge. The needle has been sitting in the middle the whole time.
Re: What would you do, engine code for Thermostat? [Re: Donald] #5081059 04/20/19 06:43 PM
Y
Yuk Offline OP
Y
Coolant was probably changed 3-4 years ago (approx. 50,000 km) with a 5 year mix.
Re: What would you do, engine code for Thermostat? [Re: Yuk] #5081061 04/20/19 06:44 PM
9
92saturnsl2 Offline
9
Which thermostat code is it? Not getting up to temp fast enough?
An ELM327 dongle is inexpensive and in minutes it will let you know if your problem is just a minor "taking too long to get to temp" which can probably be ignored if you need to or if it's something more serious like the temp running too hot or too cold for long periods of time. Many times a high or low temp won't show up on the temp gauge as most modern gauges are just glorified idiot lights (thank you Ford for starting that!) So you might be running 220F, which isn't overheating, but still hotter than the OEM intended and the gauge a lot of times won't reflect that. Same if the engine is running 160F, it's still technically "warmed up" and might show normal on the gauge, but that temp is too cold for the engine to run at peak efficiency.
I consider any coolant temperature problems to be semi-serious and would put thermostat replacement on my high priority to-do list if I were getting a thermostat code.
1985 F-250HD 7.5L 4x4 135k- Castrol GTX 15w-40
04 Odyssey EX 190k Valv. Durablend 5w-30
96 Maxima GLE 268k Shell Rotella T5 10w-30
07 Chrysler Pacifica Limited 4.0L 140k Castrol Edge 0w-30 Euro
Re: What would you do, engine code for Thermostat? [Re: 92saturnsl2] #5081070 04/20/19 06:52 PM
Y
Yuk Offline OP
Y
Originally Posted by 92saturnsl2
Which thermostat code is it? Not getting up to temp fast enough?.....
I didn't scan it, the neighbourhood shop diid, so I don't know.
I have the thermostat, so I can change it. Since the light hasn't come on again, I thought maybe I'd wait for a nicer day. It's a tight, knuckle scraping squeeze to get to the thermostat. Serp belt has to come off and the power steer pump has to come out. I'm probably just being lazy.
Re: What would you do, engine code for Thermostat? [Re: Yuk] #5081078 04/20/19 07:01 PM
K
KrisZ Offline
K
I forget the code, but my Mazda 3 had the same thing, reaching temperature taking too long. I reset it and it came back after few days. The dummy temperature gauge was behaving normally. Change the thermostat. In rare cases it may be the temp. sensor, but most of the time this code is for the thermostat.
2015 Grand Caravan 3.6L - 31k miles.
2006 Mazda 3 2.0L - 171k miles
Re: What would you do, engine code for Thermostat? [Re: KrisZ] #5081086 04/20/19 07:06 PM
9
92saturnsl2 Offline
9
If you have thermostat code and the gauge appears normal, 90% of the time it's the "taking too long to reach operating temp" code. Those can be safely ignored, but even though you might not notice it, emissions and fuel economy will suffer, the degree of which depends on how much longer the engine is taking to reach operating temp, if it's even reaching full operating temp at all.
Re: What would you do, engine code for Thermostat? [Re: Yuk] #5081089 04/20/19 07:08 PM
Y
Yuk Offline OP
Y
Thanks! I'll change it.
