OK to use this PSF on Hondas too?
by GSCJR. 05/23/19 10:53 AM
Grease for Toyota Tundra
by diyjake. 05/23/19 10:09 AM
Made in USA?
by buck91. 05/23/19 10:00 AM
Email address for Mobil e check?
by BTLew81. 05/23/19 09:29 AM
OE AC COMPRESSOR?
by FA_WRX. 05/23/19 09:08 AM
Valvoline AFS 5w-30 5k miles in ‘09 5.3 Chevy
by noclutch. 05/23/19 08:58 AM
All American Sharpener
by Duffyjr. 05/23/19 08:49 AM
Help with odd ticking sound please
by Wilvoeka. 05/23/19 08:43 AM
F1 - 2019 Monaco Grand Prix
by gofast182. 05/23/19 07:52 AM
Replacing OEM Car Speakers
by RayCJ. 05/23/19 05:44 AM
Oil for 2000 Honda Insight
by mikecz. 05/23/19 04:56 AM
PP - GF-6 Ready?
by buster. 05/23/19 02:52 AM
Do you label your oil filters when installing them?
by double vanos. 05/22/19 11:54 PM
Up2nogood, JP69, Bluethunder, patcatpat, Wilvoeka
68181 Registered Users
104 registered members (Auae85, addyguy, ABomb369, Alfred_B, 2011335d, 12 invisible), 2,102 guests, and 31 spiders.
Topics289,284
Posts4,966,194
Members68,181
Most Online2,967
Mar 10th, 2019
Floor jack oil recommendation #5080713
04/20/19 11:40 AM
04/20/19 11:40 AM
PA
Patrick0525 Offline OP
PA
I have a 1993 Hein-Werner (Winner series) 2 ton floor jack part code# 68041 and never had the oil changed.
How shall I change it? What is the procedure and is your favorite oil?
It doesn't leak..
'14 Toyota Venza 3.5L 88K mi
TGMO 0W-20
PP 0W-20/Fram Ultra filter(spring/summer)
Re: Floor jack oil recommendation [Re: Patrick0525] #5080720
04/20/19 11:43 AM
04/20/19 11:43 AM
VW Fanboy Island
maxdustington Offline
VW Fanboy Island
Hydro oil. I can't remember the weight.
DO NOT put ATF in there.
03 Jetta AWP/09A 205k kms
Edge 0W40 + Mann 719/30
Re: Floor jack oil recommendation [Re: Patrick0525] #5080739
04/20/19 12:14 PM
04/20/19 12:14 PM
Where the wind comes sweepin'
Reddy45 Offline
Reddy45  Offline
Autozone sells hydraulic jack oil. They will have 1 kind.
Re: Floor jack oil recommendation [Re: Patrick0525] #5080746
04/20/19 12:23 PM
04/20/19 12:23 PM
Hudson, NH
LeakySeals Offline
LeakySeals  Offline
Hudson, NH
I change every 2 years on all 3 of my jacks. They are keeping me alive, the least I can do. There are 2 types.
Regular jack oil.
https://www.walmart.com/ip/Black-Jack-Hydraulic-Jack-Oil-8-fl-oz/17757422
And a "high mileage" version. LOL
https://www.walmart.com/ip/BAR-S-LEAKS-HJ12-Jack-Oil-with-Stop-Leak/16888776
I use the high mileage version, seals are the biggest issues with jacks.
06 Escalade 6.0L LQ9 AWD 167k M1 0w40
03 Maxima 3.5L POS 170k ST HM 10w30
05 Malibu Classic 111k M1 5w30
Re: Floor jack oil recommendation [Re: LeakySeals] #5080752
04/20/19 12:35 PM
04/20/19 12:35 PM
PA
PA
Regular jack oil.
I am sure I need the high mileage oil since I only use the floor jack 3-to-4 time per year since 1993.
TGMO 0W-20
Re: Floor jack oil recommendation [Re: Patrick0525] #5080789
04/20/19 01:16 PM
04/20/19 01:16 PM
Los Gatos, CA
JeffKeryk Offline
JeffKeryk  Offline
Los Gatos, CA
I got some at Wally World; then a bigger bottle from Amazon.
Old floor jacks rock; I just can't pick 'em up anymore.
2018 Lexus RX450h
2013 Lexus GS350 F Sport
2006 Acura TSX
Re: Floor jack oil recommendation [Re: Patrick0525] #5080812
04/20/19 01:45 PM
04/20/19 01:45 PM
Hudson, NH
LeakySeals Offline
LeakySeals  Offline
Hudson, NH
Regular jack oil.
Any pics? I have one old orange 2 ton and over the past 5 years purchased 2 Harbor freight 3 ton (64260). I must admit the cheap HF jacks are good. Flawless actually. Like how fast the "rapid pump" works. So.. if things don't work out with the old jack, consider the HF jacks.
Re: Floor jack oil recommendation [Re: Patrick0525] #5080849
04/20/19 02:26 PM
04/20/19 02:26 PM
The Motor City
Kestas Offline
Global Moderator
Kestas  Offline
Global Moderator
The Motor City
I just bought a floor jack a year ago. How often should the fluid be changed?
Re: Floor jack oil recommendation [Re: Patrick0525] #5080860
04/20/19 02:48 PM
04/20/19 02:48 PM
The Midwest
skyactiv Offline
skyactiv  Offline
The Midwest
Walmart has it the cheapest I'm guessing. Probably near the jacks on the top shelf?
Me: 13' VW GTI 3 door 6 speed manual
Re: Floor jack oil recommendation [Re: Patrick0525] #5080867
04/20/19 02:52 PM
04/20/19 02:52 PM
Columbus,Nebraska
Yah-Tah-Hey Offline
Yah-Tah-Hey  Offline
Columbus,Nebraska
I use Walmart jack oil. Replace it about every two years. Just about any ISO hydraulic oil should work. Probably 32 or 46. Oil for this application is nothing special. ATF will probably work too. Just don't put engine oil or brake fluid in your jack.
Re: Floor jack oil recommendation [Re: maxdustington] #5080911
04/20/19 04:00 PM
04/20/19 04:00 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Whoever told you that you can not use ATF lied to you.
Re: Floor jack oil recommendation [Re: Kestas] #5080912
04/20/19 04:01 PM
04/20/19 04:01 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
I have never changed the oil in a floor jack or bottle jack in over 40 years of owning and using them.
Re: Floor jack oil recommendation [Re: Yah-Tah-Hey] #5080915
04/20/19 04:03 PM
04/20/19 04:03 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
ATF works just fine.
Light engine oil (5W-20, 0W-20, etc ) also works just fine and will not cause any problems.
Brake fluid is not oil. ... not even a little bit.
Re: Floor jack oil recommendation [Re: Linctex] #5080919
04/20/19 04:09 PM
04/20/19 04:09 PM
The Motor City
Kestas Offline
Global Moderator
Kestas  Offline
Global Moderator
The Motor City
I had a cheap floor jack I bought new 20 years ago that gave up. The fluid was black. I wonder if I could have gotten more life out of it had I changed the fluid.
Re: Floor jack oil recommendation [Re: LeakySeals] #5081075
04/20/19 06:59 PM
04/20/19 06:59 PM
PA
PA
Regular jack oil.
The 1993 HW pic.
TGMO 0W-20
