Of course the bolt that was broken was in the rear. I've been at this for quite a few hours, never has a bolt given me this much grief.
All the bolts didn't need too much to break free, maybe 40-50 foot pounds. This bolt has been broken for years, I'm going to replace the exhaust manifold so this needs to come out.
So far I have drilled and tried some Irwin EZ outs. I have tried to heat the aluminum, freeze the bolt, used quite a bit of penetrating oil, tried left hand bits,.....I think I managed about 1/4 turn but no more.
I did get the hole centered, if I drill any more I will be too close to the threads. I tried two sizes of the EX-Outs, they bite hard, but when it feels like it's going to give, the extractor gives.
Can I use a mig welder and fill the hole, then try some vice grips? I want to say that's my only bet unless I go all the way to a Heli-Coil and I'm trying to avoid that.
The hole is the lower left. Bolt size is M8X1.25.
Edited to add: I just ordered the Irwin Tools Hanson 53227 Hex Head Multi-Spline Screw Extractor Set, 25 Piece and will give that a try before building up a weld.
