2016 Mercedes-Benz E350 RWD.
This car is driven primarily on the highway. It currently has 85.3K miles.
The rear differential was first serviced at approx 42K by me. When I drained the factory fill it had a grey/green sludgy appearance. Fuchs Titan Sintopoid FE 75W-85 was used to refill since it is a MB 235.7 approved fluid. Differential holds about 1.3 quarts.
I just serviced the rear differential again and this time, the fluid was pitch black. The fluid smells fine but looks very nasty for only 43K. I am not used to seeing rear differential oil looking like this after 43k on a passenger car. Should I send in a sample for an UOA? Or should I just recommend more frequent services to the customer? Any ideas on what may be going on?
