Originally Posted by ofelas
Ah, dustyroads, gotcha re the DD13, thought you were speaking about the F150 in your signature
BTW, there's CK4 oils with plenty zinc & phos too, I don't believe the 40 grades are are subject to the low levels restriction?
Right, the 5W-40 and 15W-40 oils are limited to 1200 ppm phosphorus. I had contemplated trying Delo XLE in my F150, but I'm very happy with Castrol Edge in the coyote.
Not sure where this fits into the equation -
https://www.youtube.com/watch?v=bAdGTsOeQVQ
As much as I like CK-4 oils, even I wouldn't use it for a high performance gas engine with flat tappets during a break in, nor after break in. I'd use an application specific oil for such an engine. His mentioning that CK-4 oil produced/allowed twice as much wear as CJ-4, well..... He left the door wide open with no information whatsoever. I didn't see any signs of a follow up, either.
Maybe the day will come when I truly regret using the low P oils, but it sure seems to be working fine so far. The proclaimed benefit of improved oxidation stability is proving true in my usage of CK-4.
