Rut Roh!😂
by Mad_Hatter - 08/19/19 04:40 PM
Oil for vintage Mopars
by 440Magnum - 08/19/19 04:37 PM
M1-102 vs M1-103
by Deontologist - 08/19/19 04:06 PM
Why no love for M1 gear oils?
by zuluplus30 - 08/19/19 03:02 PM
2005 Chrysler 300 HEMI cam position sensor diagnosis
by 53' Stude - 08/19/19 02:38 PM
Noisy idle in gear but not neutral or park
by cwilliamsws6 - 08/19/19 02:30 PM
Driven 10W-30 conventional $28.63 case of 12
by Randy_R - 08/19/19 02:16 PM
Ford Dealer wanted $320 to Flush Tranny
by Mr_Luke - 08/19/19 02:05 PM
Best retail product for convenience?
by buster - 08/19/19 01:42 PM
Shell Gas Truck oil...Im giving it a try...
by Navi - 08/19/19 01:10 PM
Quiet tire for 2018 Civic Hatchback
by Blue_Goose - 08/19/19 12:25 PM
SP-10 vs PAG-46 Compressor oil
by nwjones18 - 08/19/19 12:08 PM
Jeep's, Late YJ/Early TJ
by wings&wheels - 08/19/19 11:46 AM
Determining base oil composition
by Jimmy_Russells - 08/19/19 10:50 AM
Mobil ATF 320
by BlueSky - 08/19/19 10:34 AM
Question about diagnostic procedure
by Dave Sherman - 08/19/19 10:05 AM
1980 Yamaha MX175 Two stroke issue.
by Panzerman - 08/19/19 09:41 AM
serhat, BlueSky, 444samc, Espada, samhainlimon
68998 Registered Users
96 registered members (440Magnum, 65convertible, 4WD, 2010Civic, 2K2AcuraTL, 9 invisible), 2,397 guests, and 24 spiders.
Topics293,530
Posts5,041,771
Members68,998
Most Online3,532
Jul 30th, 2019
11 year coolant drain and refill #5074354 04/14/19 08:20 AM
W
willbur Offline OP
W
Greetings-
BITOG paranoia set in and I finally decided to drain the OE coolant in my 2008 Honda v6 (100K miles). Came out crystal clear and the inside of radiator neck showed a like new appearance. Voltage readings were well below allowable limits, too. Refilled with Zerex Asian blue.
Honda coolant probably could have lasted for another 11 years.
Re: 11 year coolant drain and refill [Re: willbur] #5074370 04/14/19 08:38 AM
B
Blueskies123 Offline
B
My Toyota was the same way.
Re: 11 year coolant drain and refill [Re: willbur] #5074384 04/14/19 09:00 AM
L
Lubener Offline
L
Drained coolant for the first time last summer on my father's 2003 Mercury. Came out clean but did it one more time later to be safe.
The "thinking" man's friend.
Re: 11 year coolant drain and refill [Re: willbur] #5074410 04/14/19 09:36 AM
Snagglefoot Offline
The truth is that some of these coolants are excellent. It used to be coolant were good for 3 years, then 5 years and some manufacturers are now suggesting 10 years. The coolant manufacturers are putting themselves out of business. I use 5 years. No problems. smile
If you want the job done right......do it yourself.
Re: 11 year coolant drain and refill [Re: Snagglefoot] #5074429 04/14/19 09:47 AM
A
atikovi Offline
A
Probably the increased use of all aluminum engine blocks and heads has something to do with it. Whenever I changed the coolant on an iron block years ago, the fluid always looked rusty.
Re: 11 year coolant drain and refill [Re: willbur] #5074571 04/14/19 11:29 AM
W
Warstud Offline
W
Originally Posted by willbur
Voltage readings were well below allowable limits, too. Honda coolant probably could have lasted for another 11 years.
Can you elaborate?
Re: 11 year coolant drain and refill [Re: Warstud] #5074601 04/14/19 12:10 PM
Y
y_p_w Offline
Y
Can you elaborate?
Corrosion is somewhat of an electrical process. I guess he was checking for the potential for there to be corrosion.
I remember in some of my engineering classes I was hearing about a certain voltage placed on pipelines to reduce the amount of corrosion. I looked it up, and it's called "impressed current cathodic protection". Steel is protected with a sacrificial zinc coating (galvanized steel), since the zinc corrodes before the iron.
Re: 11 year coolant drain and refill [Re: y_p_w] #5074630 04/14/19 12:42 PM
W
Warstud Offline
W
Can you elaborate?
I think he means the PH Balance (acidity) is within the allowable limits. But acidity isn't the only reason to change the coolant. The inhibitors wear out over time.
Re: 11 year coolant drain and refill [Re: Warstud] #5074643 04/14/19 12:51 PM
W
willbur Offline OP
W
Can you elaborate?
Thank you-
I did not think of acidity but corrosion byproducts due to electrolysis increasing electrical conductivity as an indicator of coolant degradation. Lots of internet info. Just google "coolant voltages" for good explanations. Acidity using voltages is an interesting concept. Hmmm...
I thought about acidity and corrosion. Acidity increases electrolysis which leads to corrosion which then leads to conductive by products and is reflected by observed increase in voltage. Any chemists here to comment?
Re: 11 year coolant drain and refill [Re: willbur] #5074764 04/14/19 03:04 PM
G
gregk24 Offline
G
Good to hear. I change mine every 3 years or so. cool
2012 Honda Accord EX-L K24z3
58,xxx miles
PPPP 0w20 / Fram Ultra
2014 VW Jetta SE 1.8T ea888
48,xxx miles
Castrol Edge 0w40 / OEM filter
Re: 11 year coolant drain and refill [Re: Snagglefoot] #5077509 04/17/19 07:46 AM
R
Railrust Offline
R
Agreed and I think just the whole cooling systems have evolved as well. Everything is sealed and I just don't see many issues anymore. Yeah you get the water pump failures, of course, but the coolant always looks great for what seems like forever. Even Dexcool and GM products look great for a long long time now.
Re: 11 year coolant drain and refill [Re: willbur] #5079238 04/18/19 08:06 PM
M
mightymousetech Offline
M
Honda coolant is rated to last 10 years. Pretty normal that it was fine at 11 years.
Mighty Mouse Tech
BMW Diagnostic and Alignment Tech
2013 BMW 135i M Sport Edition Motul 0W40, MTL/MT-LV
2010 BMW 328i X-Drive, Castrol 0W40, MT-LV
Re: 11 year coolant drain and refill [Re: mightymousetech] #5079378 04/18/19 11:57 PM
Y
y_p_w Offline
Y
My wife's went 17 before there was ever a change. I actually had a bottle about 5 years ago, but it just sat in the cabinet because I wasn't sure how messy it would be. When I finally did it I found that it was ridiculously easy to just drain it. Kind of slow, but the spigot on the petcock goes straight down rather than sideways. I didn't spill a drop on the ground, although I did lay something under it.
Still - there's always something about the initial fill that's different. I remember back in the day of Honda green (not green Type 2) a typical recommendation would be 3 years/45k mile on the factory fill, then 2 years/30k miles after that. The current recommendation seems to be 10 years on the factory fill then 5 years afterwards. I'm guessing part of it is that a drain and fill is only about 75% being replaced. It might even be a little bit conservative.
Re: 11 year coolant drain and refill [Re: mightymousetech] #5079513 04/19/19 06:51 AM
W
willbur Offline OP
W
Thank you Mighty etc-
I was unaware the Honda coolant is good for 10 years. Where did you find this info? Does the 10 year lifetime spec apply to the original fill 11 year old coolant as manufactures change specs and formulations frequently?
Re: 11 year coolant drain and refill [Re: willbur] #5079820 04/19/19 11:34 AM
M
M
I was an Acura/Honda tech for 16 years.
The timing belt is normally due before the coolant, and we always did the water pump with the belt as the pump most likely would not last till the second belt change. So, you normally get a coolant change every time the timing belt is done.
Mighty Mouse Tech
