Wix XP oil filter deal
by Randy_R. 07/16/19 06:54 AM
How accurate is the octane rating at the pump ?
by Mr Nice. 07/16/19 06:33 AM
NAPA Presents: A Concert Behind Prison Walls
by GumbyJarvis. 07/15/19 11:35 PM
2019 Dodge Ram Warlock
by buster. 07/15/19 11:04 PM
2014 VW Jetta - transmission service
by gregk24. 07/15/19 10:09 PM
I wish my Camaro was this color!
by clinebarger. 07/15/19 09:19 PM
2019 Crosstrek 2500 Mile Review
by Al. 07/15/19 09:00 PM
Panasonic Cockpit Radio
by dishdude. 07/15/19 08:36 PM
97 Honda Civic won't crank
by Merek. 07/15/19 08:22 PM
Farmall alternator
by chilson450. 07/15/19 08:19 PM
30K and Hyundai ATF?
by flinter. 07/15/19 07:43 PM
'03 Suburban Quirks
by A_Spruce. 07/15/19 06:51 PM
new clutch shop $1500
by sirgerman. 07/15/19 06:45 PM
Pain in the rear transmission service...
by 14Accent. 07/15/19 06:38 PM
Longer Canister Fram Ultra Part #?
by gwarrior4u. 07/15/19 06:27 PM
Rats! I need bodywork
by PeterGreen. 07/15/19 06:15 PM
ATF-4?
by WillB. 07/15/19 05:58 PM
EyeglassRepair, Lucas_Jones, cobb_cruiser, robinjeter, SpicySenpai
68670 Registered Users
89 registered members (aquariuscsm, 2009Edge, 97prizm, andyd, 94astro, askani79705, 12 invisible), 1,285 guests, and 26 spiders.
Topics291,926
Posts5,013,515
Members68,670
Most Online2,967
Mar 10th, 2019
'94 Grand Am Steering Column Pivot Pins #5079708
04/19/19 10:02 AM
04/19/19 10:02 AM
northern Alabama
benjamming Offline OP
northern Alabama
I need the (2) pivot pins that hold the steering housing to the steering support. One on each side for a total of 2. Evidently they fell out & are nowhere to be found! I'm not sure what held it into place besides friction.The steering wheel moves all over the place, natch. Does anyone know the p/n for the pivot pins? It's #48 in this parts diagram.
It appears that it may be part of spring kit p/n 26045314. However that kit is discontinued & no longer available from any dealer in the US. I also couldn't find it on ebay or anywhere else.
Any other thoughts on how to make the pivot pins or substitute part? If I had a picture perhaps machine shop could make it or 3D print it.
Thank you.
Re: '94 Grand Am Steering Column Pivot Pins [Re: benjamming] #5079898
04/19/19 12:44 PM
04/19/19 12:44 PM
Michigan
MrHorspwer Offline
MrHorspwer  Offline
Michigan
It's not the pins that wear out, they're made from steel. It's the housing that wears out, it's aluminium. Replacing the pins alone won't fix your problem.
http://www.steeringcolumnservices.com is the place to go. They have oversize pins from GM tilt housings, along with whatever parts you need.
Quote
Typically the holes these pins press into to become oval shaped creating looseness in the tilt. These pins measure .380 diameter shaft, .405 shoulder (.005 oversized from OEM) and .890 tall. This oversized measurement is designed to take up MOST of the play in the column. We cannot guarantee complete tightness as each column is worn differently, but this is the cheapest method in an attempt to remedy the looseness.
Re: '94 Grand Am Steering Column Pivot Pins [Re: benjamming] #5079946
04/19/19 01:29 PM
04/19/19 01:29 PM
northern Alabama
northern Alabama
Thanks for the link! Learn something everyday.
Unfortunately their oversize pins (p/n pin02-over) are too small for my vehicle. All they have are the new OEM original size pins for $48.22 (for a pair) + shipping = ~$60. I wonder if one pin would be sufficient.
"When you install the new pin(s), you will need to ‘peen’ over the aluminum edges of the housing hole to help prevent it from coming out again (or) epoxy the large portion of the pin so it fastens itself to the housing when it dries allowing the smaller portion ro move inside the inner support housing."
