Computer - Hypervisor - Increase I/O Performance
by brueggma1 - 06/06/20 03:30 PM
Inside of new windshield fogs up
by mclasser - 06/06/20 02:51 PM
Oil considerations Duratec 3.0 V6, 85k miles
by 97tbird - 06/06/20 02:22 PM
Best way to charge and maintain a battery?
by Avery4 - 06/06/20 02:10 PM
HM oils vs HM oils
by aquariuscsm - 06/06/20 12:37 PM
Confusion: oil grades, yellow metal, vintage
by LouK2 - 06/06/20 12:21 PM
New Rad needed Nissens vs APDI
by Bluestream - 06/06/20 11:58 AM
Oil filter cap wrench suggestions.
by RichR - 06/06/20 11:55 AM
AC Woes
by artbuc - 06/06/20 11:44 AM
Part source Canada TOTAL QUARTZ 9000 50% no tax
by Bluestream - 06/06/20 11:18 AM
Pressure washer foam gun
by Donald - 06/06/20 10:50 AM
Pentastar oil changes
by 4WD - 06/06/20 10:25 AM
Oil Pan Plug Problem
by 2015_PSD - 06/06/20 10:14 AM
Continentals out of balance
by wolf_06 - 06/06/20 10:04 AM
2017 Toyota Sienna AWD
by 92saturnsl2 - 06/06/20 09:33 AM
Wix 57045
by electricmarquis - 06/06/20 08:42 AM
VW GTI
by greenjp - 06/06/20 08:25 AM
Mower Engine Got Drenched With Oil
by viscous - 06/06/20 08:19 AM
Mobil 1 versus Motul for a 2020 Camry 0w16
by Amkeer - 06/06/20 05:52 AM
viscous, Roamingtxn, 3Dperf, LouK2, Michael328i
71618 Registered Users
73 registered members (4WD, ArrestMeRedZ, 762fermeandyou, 86cutlass307, 55hambone, Astro14, 7 invisible), 1,967 guests, and 36 spiders.
Topics306,299
Posts5,289,808
Members71,618
Engine oil flush treatments. #5079614 04/19/19 08:32 AM
T
Tikka Offline OP
T
Hi Gents
Did a search but found nothing much, so sincere apologies if this is 'old ground'.
Engine oil, pre change flush chemicals such as, https://products.liqui-moly.com/engine-flush-plus-3.html, for example. They use words and phrases like 'removes troublesome deposits', 'sludge' and 'lacquers'. Words to frighten the layperson.
Are they a useful 'tool' that will help keep your engine in tip top condition?
OR
Total waste of money and of no benefit in a correctly maintained engine, one that has oil changes done at the recommended intervals, using quality Oil of the correct specification.
My unqualified take on this is as follows. If an engine has 'troublesome deposits', 'sludge' and 'lacquers' then your Oil change regime is wrong. Use better oil and change more frequently.
Difference maybe in Gas or Diesel engines?
That may well be a gross over simplification so I would appreciate some opinions Gents please
Many thanks
Tikka.
Re: Engine oil flush treatments. [Re: Tikka] #5079645 04/19/19 08:58 AM
K
krismoriah72 Online Content
Online Content
K
There are plenty of engines that have had the best oil and frequent changes that are sludged deposited... but mostly from manufacturing defects such as poorly designed PCV and also defective rings.
Re: Engine oil flush treatments. [Re: Tikka] #5079679 04/19/19 09:24 AM
J
JC1 Offline
J
I've used those treatments before on used vehicles I have bought. There were no signs of neglect. Given what I've learned here, I wouldn't bother using them.
Are you trying to fix a problem motor?
2015 Grand Caravan SXT Plus 0w-20 Pennzoil Ultra/Fram Ultra Filter
1997 Honda Civic CX 5w-30 PPPP/Fram Ultra Filter
Re: Engine oil flush treatments. [Re: Tikka] #5079695 04/19/19 09:49 AM
M
maxdustington Offline
M
I'd rather internal sludge than external oil leaks. Why even bother.
99 Toyota Tercel CE 5EFE/C151
PUP 5W30/Ultra
Re: Engine oil flush treatments. [Re: JC1] #5079741 04/19/19 10:32 AM
T
Tikka Offline OP
T
Hi
I have no problems that I am aware of on my OM642 Merc' unit. But then I have not got x-ray vision smile
As I am about to perform an oil and filter change I wondered if these pre change flushes had anything solid to offer. I note that a lot of garages offer them but I just presume they look on it as a money spinner. I am always the cynic.
Tikka.
Re: Engine oil flush treatments. [Re: Tikka] #5079757 04/19/19 10:41 AM
SubieRubyRoo Offline
Kreen is probably the strongest internal cleaner, and like $16/quart, which is enough for two treatments. Search for a thread on it by Trav, lots of great info there. But, unless you can look through the fill hole or remove the valve cover and see there are issues, it's probably not necessary. Another, more costly option would be to run the Valvoline Premium Restore (search for a thread by JAG on it), which is specially formulated to clean and free up ring lands and other areas. But it's $74/gallon.
De omnibus dubitandum.
Re: Engine oil flush treatments. [Re: Tikka] #5079773 04/19/19 10:58 AM
J
JC1 Offline
J
Originally Posted by Tikka
Hi
Tikka.
Of course they want to flush your wallet with needless services. Some people use kerosene to flush the motor as well. Lots of these flushes are made up of kerosene.
If you cannot open up the motor to have a look cut open the oil filter and see if anything was caught in the pleats.
Re: Engine oil flush treatments. [Re: JC1] #5079868 04/19/19 12:13 PM
L
Linctex Offline
L
A guy I knew bought a can of "engine flush" (it was 100% metal can) ............. "name brand" stuff
He opened it, and it was just a quart/liter of Red Diesel fuel. Nothing different at all about it - just plain red diesel.
Re: Engine oil flush treatments. [Re: Tikka] #5083830 04/23/19 02:42 PM
DGXR Offline
I use engine flush products around 100,000 miles. If your engine design has known problems with blow-by, sludging or deposits, more often would be a good idea. Or just get a better vehicle that has no issues with the engine design.
1995 Corvette coupe LT1 6-speed
2006 Tacoma 2.7 Base SR5 AC
1999 Yamaha YZ400FL
2003 Honda XR400R
Re: Engine oil flush treatments. [Re: Linctex] #5083866 04/23/19 03:19 PM
R
Rmay635703 Offline
R
A question on an engine with minor sludging issues would you
After draining oil for an oil change dump a small amount of virgin off spec motor oil through the top load filter and oil fill point to clear some more of the sludge?
I have inherited many bottles of antique oil from the 80’s I can’t use along with mmo and figure I could dump it in once the drain is nearly over and get more gunk out.
I tried it and it seems to at least cosmetically get the filter housing clean and it does appear to drain out after a while.
Only takes a couple ounces to clean out, just not sure to what degree it ends up basically stuck in the engine and apart of my fill or not.
Re: Engine oil flush treatments. [Re: Rmay635703] #5084396 04/24/19 05:53 AM
crainholio Offline
I do a similar procedure on my project 4Runner which was neglected by the original owner. Oil drain plug is on the driver's side bottom of the sump, dipstick is on the passenger side of the engine. I put the vehicle passenger side front & rear on ramps to tilt it toward the drain plug. After draining the oil, I pump around 1/2 quart of Supertech oil down the dipstick hole...it washes across the oil sump and pushes out sludge that would otherwise have stayed in the sump as shown in the attached pics. I put a clean paper towel across the drain funnel after the drain, and then pumped oil down the dipstick tube, this crap came out.
Re: Engine oil flush treatments. [Re: Tikka] #5116612 05/26/19 06:48 PM
DoubleWasp Offline
Well, you can't argue with that.
Re: Engine oil flush treatments. [Re: Tikka] #5396158 04/07/20 08:20 AM
Danr42 Offline
I've been told by old mechanics to add a quart of ATF 10-15 miles before an oil change. I've done it to flush engines before with relatively new oil still light brown and after 10 miles with ATF it is black.
Re: Engine oil flush treatments. [Re: Danr42] #5396159 04/07/20 08:22 AM
spasm3 Offline
Atf has little detergents, little cleaning ability. It only thins out your oil and dilutes the add-pack. I would not use that.
13 elantra 84k 5w30 synpwr
17 mazda cx-5 19000 miles m1 0w30
Re: Engine oil flush treatments. [Re: Danr42] #5396220 04/07/20 09:19 AM
demarpaint Offline
Not a good idea, as mentioned above.
God Bless Our Troops
