Fuel in cylinders
by Smittyzzz - 11/18/19 08:07 AM
PG2222 vs PG2500
by mpack88 - 11/18/19 07:20 AM
Bought a Powermate 5500 Generator
by Miller88 - 11/18/19 06:10 AM
Amateur Paint Questions
by The Critic - 11/18/19 04:15 AM
Twisted drive shaft real or fake?
by Mad_Hatter - 11/18/19 03:53 AM
Neighborhood Etiquette
by The Critic - 11/18/19 03:41 AM
AME 37330 Hub Cleaner for Impact Wrench
by The Critic - 11/18/19 01:54 AM
Plastic bag vs Car
by The Critic - 11/18/19 01:50 AM
Fram XG7317 20k miles cut open
by dbeau - 11/17/19 09:46 PM
2021 Ford Mach-E Electric SUV
by KeithS_NW_Ohio - 11/17/19 09:05 PM
Walker mower Oil
by Joey737 - 11/17/19 09:03 PM
Rough service tough light bulb 1¢ at Home Depot
by JLawrence08648 - 11/17/19 08:40 PM
2015 F150 5.0; 10w-30/5w-40 mix 8.6k miles
by Buzzinhalfdozen - 11/17/19 08:36 PM
MOPAR MO-285 FACTORY OIL FILTER CUT OPEN
by 53' Stude - 11/17/19 07:43 PM
Best Garage Door Seals
by Gebo - 11/17/19 07:18 PM
Bar oil as fogging oil
by WA1DH - 11/17/19 06:47 PM
Fram PH2 ExtraGuard Cut Open
by A310 - 11/17/19 06:38 PM
C&P Pentius UFXL PH16-equiv.
by 92saturnsl2 - 11/17/19 06:18 PM
Fleetguard WF2074 Coolant Filter Cut Open
by Pyrotechnic - 11/17/19 05:24 PM
leafuntec, wolf777, SONICMASD, Smittyzzz, JimBobSeeker
69903 Registered Users
102 registered members (aquariuscsm, 379KITTY, alarmguy, 330indy, 64bawagon, Alfred_B, 10 invisible), 2,022 guests, and 20 spiders.
Topics297,577
Posts5,118,462
Members69,903
Most Online3,589
Nov 2nd, 2019
Accord AC Issue #5078687 04/18/19 09:54 AM
M
maverickfhs Offline OP
M
On recently acquired 07 Accord, AC is throwing warm air, it gets slightly cold but then again it's warm.
Could it be that system needs a charge? Or can be something else? Appreciate any advice and help. thumbsup
2006 Civic EX 205K/AT
2006 Acura TSX 187K/AT
2007 Accord VP 151K/AT
Re: Accord AC Issue [Re: maverickfhs] #5078698 04/18/19 10:01 AM
J
JeffKeryk Online Content
Online Content
J
Do a charge and see what happens. It worked for out low mileage 1998 Accord LX.
2018 Lexus RX450h
2013 Lexus GS350 F Sport
2006 Acura TSX
Re: Accord AC Issue [Re: maverickfhs] #5078700 04/18/19 10:02 AM
J
JMJNet Offline
J
You have to measure the refrigerant pressure.
There is a tool called pressure gauge specifically made for checking AC system.
There is no way to determine from your information given to us, all we know is that the AC is not working.
If you ask here, I suspect, you don't have the tool.
So you need to buy it or bring it to someone who has the tool and knowledge to use it.
That someone can be a mechanic shop or a friend.
So, if there is no pressure, why?
Is there leaks, or the compressor gave up or the clutch in the compressor give up, etc.
For leaks, we need to investigate where.
You can use sniffer or put dye on the refrigerant then use a special uv light to see it.
  • 2017 Toyota Sienna
Re: Accord AC Issue [Re: maverickfhs] #5078705 04/18/19 10:06 AM
M
M
I think some of the auto stores have a loaner for AC gauges and I can get those to test the system, have seen some youtube videos on it.
Yes, I do not have the tools(gauges) .
Re: Accord AC Issue [Re: maverickfhs] #5078709 04/18/19 10:13 AM
M
mattwithcats Offline
M
On systems at least ten years oil, that are getting cool, but slowly, try adding a oil charge.
This is 1 ounce Pag oil, 1 ounce R134a, and 1 ounce “Performance Enhancer”...
Only do this once in the life of the system, or you will drown it!
https://www.walmart.com/ip/Ac-Pro-R-134a-PAG-100-Oil-Charge-with-Ice-32-Oil/509467516
2009 Smart Pure
Pennzoil Platinum Euro 0W-40, Wix XP 51356 filter, 45 mpg...
185/55R15 General HP tires, "H" speed rated, 44 psi (300 kpa)
Re: Accord AC Issue [Re: maverickfhs] #5078761 04/18/19 11:09 AM
Chris142 Offline
Could be low. If it is it has a leak. Could be a bad expansion valve,bad pressure switch etc. What are the high and low side readings along with the ambient temp?
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Accord AC Issue [Re: maverickfhs] #5078880 04/18/19 12:58 PM
V
vw7674 Offline
V
A/C do lose refrigerant through compressor shaft seal over time, most top-off starter kits come with a handy gauge to tell you when to
charge the system while the engine is on powering the compressor. It's a 1-2-3 kind of procedure. Re-charged a warm air
blowing ancient Infiniti last summer & it's still blowing cold air today. You do need to know how many ounces are needed to
get to full capacity. (the Infiniti was 16.+.) sometimes you need to buy the kit with gauge plus an extra bottle to fully charge the system.
Re: Accord AC Issue [Re: maverickfhs] #5078888 04/18/19 01:01 PM
M
madRiver Offline
M
A simple issue common is bad ac relay. I believe it’s around $10 for a new one.
Re: Accord AC Issue [Re: madRiver] #5078911 04/18/19 01:24 PM
M
M
Any idea what are the symptoms of it?
Re: Accord AC Issue [Re: maverickfhs] #5078969 04/18/19 02:08 PM
M
M
Usual source of leaks are the Schrader valves...
These can be replaced without opening the system,
but specialized tools are needed..
2009 Smart Pure
Re: Accord AC Issue [Re: maverickfhs] #5079558 04/19/19 06:44 AM
W
wag123 Offline
W
Honda had a problem with A/C compressor clutches during that era. They have a warranty extension for this problem on some models. There are several Youtubes from people showing how to diagnose and repair the problem on the cheap.
Re: Accord AC Issue [Re: maverickfhs] #5079568 04/19/19 06:55 AM
M
mk378 Online Content
Online Content
M
Check if the compressor is staying engaged. If the compressor doesn't engage it could be the relay or other electrical problem. If the compressor is turning but it doesn't cool, then you need to get pressure readings.
Also the condenser fans should run continuously or most of the time (depending on system design) when the car is sitting still with the A/C on.
