Again, just tossing out 'comparable' ideas...
Many on here are fans of adding MMO to both the oils and gas, as it says to do. In both, it is a general cleaner to remove deposits and keep everything clean.
Some here like to add 2-stroke oil to the gas to lube and clean the fuel system; what about adding it to the oil as a gentle cleaner like you would MMO?
If it has cleaning properties along with lubricating ones, would it not achieve the same thing?
You can add 20% MMO to the crankcase to clean, and it is very light, why not add 20% 2-cycle to do the same?
Go on, fire away.....
